AoS Stumped, for a list I need to rebuild in 3 days
Discussion in 'Seraphon Army Lists' started by Dreamer74, Jul 24, 2018.
  1. Dreamer74
    Dreamer74 Active Member
    Need to remake a list for a CTA tourny and they now just applied the FAQ which kinda stumped Kroak for my list.
    Anyone got suggestions.. as I can't think of anything (And I can't practice as Im away from models till the begining of the month.
  2. Lezlor
    Lezlor Active Member
    What sort of games will you be playing, the matched play ones?
  3. Dreamer74
    Scenarios
    Duality of Death (GHB 2018)
    The better part of valour (GHB 2018)
    Focal point (GHB 2018)
    Gifts from the heavens (Core Rules)
    Relocation orb (GHB 2018)
    I have a list I think could work.. just need realm and Artifacts
  4. Dreamer74
    What I've come up with, one drop just need artifacts, and see what works now.
  5. Aginor
    I think that one can work fine.
    I'd probably take Hysh artefacts:
    The Lens was nerfed but I think it is still worth it against Death or Tzeentch (or other Seraphon) to block spell damage from the most severe spells, and the other ones:
    Aetherquartz brooch might be cool, because it is pretty likely that you will receive one or two CPs using it.
    Cuirass, Coronet, or Glittering Blade can help with survivability.
    But also take a look at Ulgu, that Realm also has some nice stuff that could fit.
  6. Dreamer74
    I am undecided between Ulgu and Hysh still.. anyone else got a suggestsions.. maybe even Shysh?
  7. Aginor
    Shyish isn't bad either. To be honest if you need 2-3 artefacts almost every Realm has some nice stuff.
  8. Dreamer74
    Yeah, just hard to chose which ones to work best.
  9. Jbird460
    Jbird460 Member
    I qould consider dropping one engine for a larger units of kinghts and maybe cogs or Balewind. You could in theroy teleport the slann in close then drop kinghts and scarvet and maybe some skink screens9 away. with plus 3or 4 and rerolling 1 on the charge that is a fairly easy first turn charge. With 3 battilions you have 4cp so you can give a 10 man unit of knights 60 attacks with there mounts.
  10. Dreamer74
    Sadly I'm still waiting for knights to arrive and lost is due today
  11. Dreamer74
    So, after your advise, did fianly changed before submitting it, also gonna drop with the knights a Skink priest to add double damage for the bites on 6's and to dispell atleast one spell near them (Hopefully) I'e got some ideas in mind as how to play it.. thinking a Slann driveby with room to move if the teleport (2nd one) fails https://drive.google.com/file/d/1gBr-5gHCWiLelmYaUZWtnZJ0LZAuBk-H/view?usp=sharing
    Aginor and Jbird460 like this.
  12. Jbird460
    Jbird460 Member
    I hope it works well let us know how it turns out.
