AoS Sunclaw Starhost in 1K Battles
Discussion in 'Seraphon Tactics' started by Vexcor, Jul 3, 2018.
  1. Vexcor
    Vexcor Well-Known Member
    Sunclaw Starhost sounds good on paper, but 130 points is a lot in 1K Battles.
    is it worse it? or just drop more units on the board?
    have you made any expierences?
  2. Aginor
    I don't have any practical experience with it, but IMO it can work in 1k battles.
    Sunblood
    Priest
    Starpriest
    Sunclaw bataillon
    40 Warriors
    10 Warriors
    10 Warriors
    should be 970 points if I am not mistaken.
    The Skink Priest is for rerolling run,charge, and save rerolls and the Starpriest is for Serpent Staff and magic.
    These days I would probably not risk to go without the Starpriest because of the fact that a Purple Sun of Shyish or something like that can ruin those Warriors and without a wizard there isn't much you can do against it.
    Will it win tournaments? ... Probably not. But it is not a bad list.
    Lezlor likes this.
  3. tom
    tom Member
    I agree with you that any battalion in 1k is a questionable choice. I have tried eternal and just couldn't win with the low model count. Sunclaw isn't as bad given you get twice as many saurus but I can never get past the fact that you could have another unit.
    The only reason it might be worthwhile would be to 1 drop or if you have a particular plan with the extra artefact .
  4. Lezlor
    Lezlor Active Member
    I play it against same size units of clanrats where the rend and extra bites makes all the difference. Add their +1 battleshock with a banner too and they usually flee in droves. So against an army with 6+ save chaff units it’s a really good battalion. Against tougher opponents they can drop like flies unfortunately. Hope that helps out
