AoS Taking Slann with SCE.
Discussion in 'Seraphon Discussion' started by SkinkBait, Apr 16, 2020.
  1. Killer Angel
    You need a citation of a FAQ or something similar.
    The core rule is that you cannot attempt to cast the same spell more than once in the same turn (even with a different wizard).
    To bypass this rule with endless spells, you need a rule that specifies that endless spell don't fall under that limitation, otherwise you cannot.
    Erta Wanderer likes this.
  2. Erta Wanderer
    i think he means the turn after you cast it. so you would cast it and then the next turn dispell and then cast it again
    Nart likes this.
  3. Killer Angel
    Well, in that case yes.
    You can dispel a ES and cast immediately the same spell. You just cannot cast it twice in the same turn.
    Grotpunter and Erta Wanderer like this.
  4. Grotpunter
    Grotpunter Well-Known Member
    Yeah this is a case where an endless spell has been casted in a previous turn. When it is your hero phase, you start by dispelling and then recast it. There is nowhere it says dispelling = casting, so you can totally remove an endless spell and cast it in a better location in the same turn.
    Killer Angel and Erta Wanderer like this.
  5. Nart
    Nart Well-Known Member
    Yes, that's what I mean. I remembered, for some reason, that you cannot dispel and then cast a spell either. That's wrong, fortunately.
  6. Satoabe
    Satoabe Member
    If you take Kroak could you also take a bound Purple Sun?
  7. SkinkBait
    SkinkBait Active Member
    No. Bound endless spells are part of the Seraphon army.
