Blog The Grove: Personal and Commission Works
Discussion in 'Personal Paint Logs' started by Snoopdeville3, Jan 12, 2016.
  1. Crowsfoot
    I don't know they look cool to me, I have loads of skink bits and I'm going to use them for the display board.
    Snoopdeville3 likes this.
  2. Snoopdeville3
    Snoopdeville3 Well-Known Member
    Thanks! Ya to save $40+ i said screw it lets do it lol. Awesome post some pics when you're done!
  3. Crowsfoot
  4. Snoopdeville3
    Working on the horns... its taking a while... so many different paint coats.... very tedious
    Black, Rhinox Hide, Screaming Skull, then White from the Badger Minitaire line. All with multiple then coats... been working on it for a week now.
  5. StealthKnightSteg
    StealthKnightSteg Well-Known Member
    But they already look AWESOME!
  6. Bracnos
    Bracnos Well-Known Member
    Wow those horns look amazing how did you do that... (I suck at the horns...)
  7. Jorgik
    Jorgik Well-Known Member
    Awesome stegadons!!
    HAHA so funny :D good sarcasm. It took me 1 week to paint 5 saurus HAHA ;)
  8. n810
    I took me over a month per Steg... :sorry:
    Jorgik likes this.
  9. Jamie Searle
    Jamie Searle Member
    I love the dark Steg, really nice colours.
    Snoopdeville3 and Toltecatl like this.
  10. Fhanados
    Fhanados Well-Known Member
    I'd like to know your recipe for the flesh on the white and purple steg. Not that I don't like the black and red one, it's great, but I have a lot of trouble with fleshtones
  11. Snoopdeville3
    Thanks for all the love guys!
    Everything is very thing thin layers...painting basically spears at the start of the horn while going more full towards the end of the horn.
    Primer - either white or black
    Base coat - Black - I think I used Badger Minitaire Black
    Layer 1 - GW Rhinox Hide - covering almost all of the black
    Layer 2 - GW Rhinox Hide - This paint tends to go on really thick so I water both layer down a good mount.
    Layer 3 - GW Bestial Brown (Mournfang Brown) - Bestial Brown goes on really nice even when water down, this just needed one coat. Covering most of the Rhinox Hide.
    Layer 4 - GW Screaming Skull - Covering most of the Bestial Brown
    Layer 5 - GW Screaming Skull
    Later 6 - Badger Minitaire I believe Skull (or Snow) White - covering much of the Screaming Skull
    Layer 7 - *
    --- I usually airbrush horns and such.. and now I remember why ... because its 1000x faster... but I just finihed these yestrday and it looks wayyyyyy better.
    --- Another tip, dont just paint lines that dont connect until the very tip, which is what I used to do. Connect the colors much sooner. I believe I screwed this up on my Lord Kroak that I painted. I left the colors separated much further on Kroak and it looks no where near as good. I hope this makes sense.\
    White Primer
    Base - Badger Minitaire - Ancient Bone - Two coats
    Layer 1 - Badger - Ghost Ink: Brown - i believe i did the whole model
    Highlight - Ancient Bone - pick out almost all areas except recessed shaded
    Shade - GW Devon Mud - Only really recessed areas and deep muscle lines.
    Highlight/Drybrush - GW screaming skull - only the most raised areas.
    Hope this helps! If you are using GW paints you can make it work with those as well. Let me know if thats what you're using.
    I will hopefully have more pics soon! Stayed tuned way more to come! I'm going to throw down on a Carnosaur (bright yellow and blue themed) as well as some Terradons, Chameleon Skinks, Skink Priest, and Temple Guard! I am sure much more after that as well!
    AngelRaven, Jamie Searle and Bracnos like this.
  12. Fhanados
    Yeah I use GW paints but my assortment of colours goes back to the good (bad) old days of Bleached Bone, Chaos Black and Chestnut Ink. I love the new paint ranges and would love to update my pallet but it's something I'm doing gradually.
    Great writeup and thanks for the tips!
  13. Snoopdeville3
    Ok it would be white primer, bleached bone layers, chestnut ink watered down and applied in all the crevices, screaming skull drybrush on raised areas, then chestnut ink in the inner most crevices (the darkest parts.)
    Fhanados likes this.
  14. Fhanados
    I thank you good sir, and hope to one day show my results using this method.
  15. Snoopdeville3
    Got a little more work done. I was hoping I would have progressed further but work has got me busy. More updates once I get back from Houston in a few days!
    Toltecatl, Tip4Tap, Bracnos and 3 others like this.
  16. Tip4Tap
    Tip4Tap Member
    These look amazing! I can't wait to see how everything turns out! It took me seven months to paint a 1500 point Grey Knight army which is like 20 models so I wouldn't worry about time :)
  17. Snoopdeville3
    Ya my last commission job was a black gk army. It was 2 dreadknight nights, 2 librarians, 28 terminators. .. I got it done in 2 months but it was a struggle... very boring painting the same armore over and over.
    Tip4Tap likes this.
  18. Tip4Tap
    Tip4Tap Member
    I found it a struggle as well. I ended up airbrushing much more than I had originally intended too.
  19. Crowsfoot
    Do you do a lot of commissions?
    I have thought about starting to do some but unsure if there is a need.
  20. Snoopdeville3
    I do them here and there. I am not super aggressive trying to get commissions. I mostly advertise on dakkadakka.com My gallery there is a lot bigger. I've done some pretty big armies, mostly 40k. My last was a pretty big Grey Knights army. I mostly paint and sell my stuff on ebay. Sucks you have to pay fees but this way I can paint what i want and sell it.
    SlanntaClause likes this.
