Fiction The Outland Legion
Discussion in 'Fluff and Stories' started by J.Logan, Jun 10, 2024.
  1. J.Logan
    J.Logan Well-Known Member
    Battle on the Mud - The Central Conflict
    Northern Middenland
    Battle Duration: 4 hours
    Solin ducked, heard the whistle of air parting before the keen edge of the glaive as it sailed overhead. Planted one hand in the thick mud, pushed, used that hand as a pivot point to swing a leg around until his heel slammed into the ghoulish samurai's face with a loud crack.
    The samurai staggered back, grunting in what sounded to be a mix of pain and disgruntlement. Wasn't enough to keep him distracted for long, even before Solin had straightened himself back to his feet—hand absently shaking off the mud before returning to the hilt of his blade—the samurai had already regained his wits and hopped back, twirling his polearm with dexterity borne of mastery.
    Solin hissed softly, hopped back a few steps himself, widened the gap between them for a brief moment and allowed his eyes to drift—never so far as to have the samurai gone from his vision, but enough to get a sense of their surroundings. Blood stained the mud, bodies littered the ground—mostly Chaos. But Solin couldn't ignore the sight of his own dead. Red coats, muted by the sodden mire, the wool heavy with water and streaked with filth.
    No time to mourn, just don't let their deaths be a waste.
    He ducked and weaved through the flurry of strikes, each swing of the glaive cutting the air where his neck had been moments before. Stepping back, he felt the disturbed breeze of another near-miss. He twisted, avoiding a thrust aimed to skewer him, then bent low, ducking beneath a horizontal swipe.
    His blade flashed up, parrying with a clang, though not fast enough to avoid the sting of a shallow slice across his forearm. Blood welled, but he felt no pain—just another nick among many. Swung in a counter-strike that was in turn avoided. Leapt back, twisted his body around, rolling in the air, putting distance between them while also evading the attempt to sweep at his ankles. Landed lightly, looked no more ruffled for the abrupt somersault than if he had simply skipped jovially.
    Solin tightened his grip, not by much, but enough so for the leather wrapped around the hilt to groan in protest. Exhaled, adjusted his stance, lowering his left hand while raising his right, guiding the greatsword until it was held parallel to the ground. Eyes locked onto the samurai, watched as the ghoulish champion adjusted his own stance in answer. Assessed, considered.
    The proper thing to do would have been to re-adjust, shift his feet and alter the blade's position. But Solin chose not to. Deliberately kept his stance in one that was apparently weak to that of the samurai. Mind raced, considered. Tensed.
    The samurai, seemingly recognising that Solin wasn't about to shift his stance—had decided to keep this posture—flew forward, bladed polearm swinging.
    Again, the proper thing to do, would have been to parry, riposte and counter. But their fight had gone long enough that Solin already knew how that sequence of events would pan out. History was rife with the mistakes of the past being repeated time and time again. Sometimes, the proper thing to do was not the right thing to do. Sometimes, a chance needed to be taken. A momentary break from the established rules.
    If he parried, history would just repeat.
    So Solin would not repeat himself pointlessly.
    Ducked, used the slick mud to fall to one knee while twisting his body around. Released his right hand's grip on his weapon, and snatched at the haft of the glaive. Fingers coiled around the weapon, chilling cold spreading from that physical contact, unnatural and numbing.
    Couldn't hold for long, not when the corruption of Malice was so pervasive from so simple a touch. Didn't need long. Pulled, didn't expect to upend the samurai's balance, even if the Chaos champion was taken by surprise, his discipline and experience would most likely already be compensating, body reacting to the apparent threat before the mind could catch up.
    Except pulling over the samurai wasn't the goal. He let the mud work for him, pulled, and allowed his body to be pulled forward, feet sliding back under him and then he was upright again. Didn't stop the momentum, didn't even try.
    Forehead met forehead.
    Solin might not have been gifted with the typical bone crown of the standard saurus spawning, but never let it be said he didn't have a hard head. The crack when they made contact echoed loudly, almost like another gunshot. The samurai flinched back, lidless eyes momentarily clouded from startled pain.
    Swung his zweihänder, tried to take advantage of the opening afforded to him. The samurai reacted even before his eyes cleared—a testament to his skill as a warrior, able to react to threats even when dazed—tried to dodge aside. The samurai wasn't fast enough, the armour affixed to his shoulder—the sode, if Solin had his Nipponese terminology correct—failed to hold back the Gromril blade, was cleaved into, a thick gauge carved into the rectangular plate.
    At the instant Solin's blade bit into flesh, the samurai let out a startled cry—and then his body darkened. A loud, ominous buzzing filled the air. Resistance vanished, sending Solin's sword lurching forward, nearly throwing him off-balance.
    The samurai's body continued to darken, turned into a shadow, which split apart into a mass of droning shapes. It took a blink of the eyes before it registered that the squirming mass were hornets, each formed of the same black shadow. Solin swallowed back a startled oath, fought down the instinctual panic at hornets being so close to his person.
    The swarm of insects floated in the same space previously occupied by the samurai, then flew, still together in a thick swarm until they took up a space a rute away. They swirled in that space for two seconds before condensing together, and the buzzing of their wings was silenced. In their place was once again the samurai, clutching at the shoulder that Solin had managed to injure, breathing heavily, almost panting.
    What was that? Solin wondered privately, racing through what he knew of magic. Some form of Steed of Shadows? Or does Malice have a variation of Skitterleap?
    'Kisama,' the samurai called out. Solin reckoned that the samurai would have been gritting his teeth, if his rictus grin hadn't already forced that permanently upon his features.
    Solin didn't understand the word that the samurai had used, but the tone was clue enough that it wasn't complimentary. Some things just transcended the language barrier. He chose not to answer verbally, instead lifted his zweihänder into a mocking salute while he assessed and considered his next options.
    The samurai growled, then grimaced when he moved his injured shoulder. Solin couldn't help but tilt his head in curiosity at the way that the samurai's attention shot to the injured shoulder with the closest approximation of surprise that could be managed with his ghoulish face.
    Curious. What's got him so shocked? Or is he only just registering the pain?
    While the distance between them existed, Solin took the moment to just watch, resting his blade against his shoulder, one eye affixed to the samurai while he turned his head this way and that, kept the other eye open for any of the lesser Chaos warriors who might suddenly think themselves capable of getting involved.
    Fortunately, it seemed that the warriors of Malice had largely learnt to keep their distance. Cut enough of them down without them even counting as an afterthought, that was a lesson they were quick to take in. It was a little regrettable, it would have been better if they had constantly come at Solin with the belief that they were capable of fighting him—the more who tried to involve themselves with Solin and this samurai's duel, the less pushing against Solin's subordinates.
    It wasn't normally an issue, but this samurai was just as prone to cutting down anything that got too close, friend or foe. So the lesson had been taught, Solin plus champion in a duel equalled death to anybody close.
    The samurai finally seemed to get over the injury to his shoulder after he tested his mobility and found that he could still use the shoulder through the apparent pain. The samurai twirled his glaive and shifted into a ready stance. Solin waited for a moment, eyes locked onto the champion, before widening his stance and tensing. But he remained still, waited for the Malice champion to make the first move.
    A gunshot from somewhere in the background echoed through the grove.
    The samurai moved—lunged forward with a new furious energy.
    Mex ducked under the swing of a wicked-looking halberd, the black metal of the weapon stark against the gleaming white armour of its wielder. The saurus hissed softly, twisting his body as he drove his spear forward. The blade pierced through the uncanny white plate and buried itself deep in the chest of the Chaos thrall.
    A wet, gagging cough escaped the warrior—a grotesque signal of death unacknowledged by the body. Mex kicked the thrall away, wrenching his spear free with a sickening sound. He spun on his heel, scanning for the next threat.
    Exhaled softly, twirled his spear to a more comfortable position and back-stepped, fell in-line with another trio of saurus, formed an improvised phalanx with them even as they continued to steadily retreat. They were near the edge of the grove, the only natural obstacle left being the pond that marked the fallback point.
    A narrow bridge spanned the pond's centre—the only practical crossing without circling around the grove's edge, which would leave anyone exposed, or wading through the water. Mex doubted the Chaos warriors would take to swimming, not while clad in their hellforged plate armour.
    That bridge was the grove's only true chokepoint, and their final chance to hold this patch of contested ground. With the constant stream of Chaos warriors in their gleaming white armour, swarming forward with numbers and reckless abandon? That small chokepoint was their last chance to keep the grove as contested territory, to hold back the warriors and deny them the cover of the trees to get close to the central hill where the Legion was stationed.
    Mex felt the weight of the pistol tucked away inside his coat; it seemed to grow heavier the longer the fighting carried on, the closer that the warriors of Malice got to reaching that proverbial line upon which it had to be acknowledged that the Legion couldn't hold the grove.
    Thrust his spear as another warrior charged forward, joined by his brothers-in-arms. They linked up with more saurus, all of whom had been pulling back. Skinks ran past, took up positions behind the wall that the saurus formed.
    'Are there any more coming?' he asked, raising his voice to be heard despite the constant roar of violence filling the air with noise, while he glanced at the latest saurus to appear.
    Fighting retreats were slow, and with their forces within the trees scattered and out of sight, it got difficult to tell who had fallen, and who was still yet to arrive because they were moving slowly.
    There was a volley of gunfire from the skinks. As the sound of thunder faded, the saurus Mex had spoken to looked toward him, eyes narrowed in consideration.
    'I saw a few more saurus and skinks a way behind us,' the saurus rumbled at last.
    Mex considered that for a moment, frowning in thought.
    'Skinks, form firing lines on the other side of the pond. Saurus, form a phalanx on the bridge, but leave a gap one side so any of our kin still out there can get through,' he ordered in a sharp tone.
    For a brief moment, his mind recalled that the colonel was among those fighting among the trees. It had been a while since that particular storm of violence had been sighted. Considering they weren't being attacked by the Nipponese warrior? It was clear that Solin hadn't fallen.
    Or if he has, he took down the champion with him, a traitorous corner of his mind whispered.
    A sharp shake of the head and a hiss of self-reproach dispelled such thoughts. Not the time for doubt. He has survived centuries of conflict, this won't be the moment he dies.
    Ground his teeth and hurried to join the formation of saurus on the bridge. He took his place in the centre of the front rank, shoulder-to-shoulder with the saurus standard-bearer. As the highest ranking saurus among them. this was his place—at the front, where the risk was greatest. It was both his duty and his honour, no matter the danger.
    Kordak wasn't like many of the followers of Malice, who had only come to serve the Lord of Anarchy after coming to realise the shortcomings of the Gods they had previously served. Kordak had served Malice all his life, had come from one of few hearths that worshipped Malice exclusively.
    Didn't begrudge the other warriors. They had at least made the right choice eventually, learnt that the other gods were lesser and had survived whatever ordeal had caused that revelation. They were now fighting for the true god of Chaos.
    Growled lowly, wrenching his axe free from the lizard's back, the red coat it wore darkening to a near black as the wool was stained by blood. Turned and swung his axe at another lizard, forcing aside billhook that was aimed at him, then swung again, cleaving through flesh and bone, shortened its height by a head. Shouted, bellowed out a challenging cry, an invitation to any other lizards to come and try their luck, he was waiting for a challenge. He was ready for them.
    Except the lizards apparently were cowed by him, more and more as the fight in this grove had continued, they had been pulling back. Less willing to engage in straight combat, even less willing to be underhanded and try stabbing him in the back, which Kordak was of mixed opinions about. It was a valid tactic, he wasn't some honour-bound lout who would be looking down his nose at such methods, but on the other hand, the absence of such attempts was a relief. Having to constantly look over one's shoulder got tiring.
    'Cowards!' he eventually bellowed in a fury. 'Stop fleeing and face me!'
    He didn't flinch at the crack of a gunshot, merely raising an unseen eyebrow as a comrade staggered and fell, a hole punched clean through his helmet. Kordak let out an irritated breath, grabbed a discarded spear—no, wait, this was one of the lizards' billhooks—and after a moment of testing the weight, hurled the polearm. The small lizard who had fired the handgun dropped the weapon and gargled, blood pooling from its mouth. The thrown weapon had punctured through its body and pinned it to the tree it had been standing beside, leaving it to let out its death rattle.
    Kordak let out a huff of satisfaction and surveyed the scene, before feeling his satisfaction shift, morphing instead into irritation.
    'Come on," Kordak growled, waving his axe toward the retreating lizards. "They're pulling back—this way.'
    He led the warriors, his forehead aching from the force of the frown that was painted across his features, not that such was visible behind his horned helmet. Surely if they want to keep us from passing this grove, they wouldn't be retreating to the edge that we want to be reaching. Or are the lizards just that badly on the backfoot?
    Even as that question reached his mind, he shuddered, absently turning his head to the direction that Lord Soulshriver had last been seen fighting that lizard champion. Had to be a champion to be capable of matching ghoulish samurai. Too many warriors had been cut down for trying to get involved in that duel. If Soulshriver hadn't been leading this push into the grove, hadn't been there to distract that particular lizard, how bloodied would the warriors of Malice be? How many deaths just to fight one single lizard?
    If the lizards had been depending on that champion as the key focus of their defence, then it was no wonder they were on the back foot. But yet, something about that comment didn't ring true to Kordak.
    Kordak would never make claims to being intelligent. Even in combat, he wasn't a strategist, he had only the barest grasp on proper tactics. He was a fighter, he was aware of that, proud of it even. He knew his role, and that was to be the hammer smashing down the enemy.
    But even with that lack of intelligence, he didn't feel himself stupid. He knew when something was wrong. The lizards' retreat was not a panicked withdrawal. It was calculated. He could see that, he just couldn't fathom why. Why pull back and allow the warriors of Malice to come deeper into the territory they were trying to take? Maybe if one of the more knowledgeable or one with a grasp of strategy were nearby he could ask. Unfortunately, those gifted with that kind of a mind were either relegated to the back of the formation, to protect that precious resource, or they were champions and warlords, and none of those were nearby, excepting Lord Soulshriver, and Kordak was not feeling any real desire to die a pointless death trying to get close to that.
    Pushed through the overgrown vegetation, and paused a moment, taking in the sight. It was a large pond, or a small lake. The specifics weren't important, what was important was that it was blocking any more forward movement without either swimming across, circling around—which could very well mean leaving the grove at the sides—or crossing that stone bridge in the middle, where the larger variety of the lizards had formed up into tightly packed overlapping lines, their billhooks held at the ready.
    Once again, Kordak wasn't stupid. He might not have the intellectual grasp of strategy, but even he could see just how that position, how their overlapping lines of billhooks had just made that bridge a very dangerous chokepoint to attack head-on.
    Even if Kordak wanted to command the warriors of Malice to circle the large body of water, the smaller lizards, the ones with the handguns, had lined themselves on the opposite shore—does it count as a shore when it's a pond?—and would no doubt be shooting at any warriors who was foolish enough to not stand with the larger lizards blocking their line of sight.
    'Bastards.' He spat out the insult.
    His eyes drifted to the water, tried to puzzle out how deep the murky waters truly were. There was no chance that any of the warriors of Malice would be swimming across, not while wearing armour. But if was shallow enough, it would be uncomfortable, but they could wade across.
    No way to tell how deep the water was though.
    Let out a frustrated breath and glared at the lizards, who seemed quite happy to just stand there, staying still on the bridge in their formation, polearms held ready. Never before had Kordak felt such disgust. Such a craven method of fighting, to stand there in a position of power and just wait.
    But as much as Kordak wanted to prove that he and his fellow warriors were the superior fighting force, he was not stupid enough to charge headfirst into such a position. Not when they had such an advantage. Couldn't even take proper advantage of the fact that the lizards weren't carrying any shields; the warriors of Malice weren't exactly carrying a surplus of javelins or spare axes to throw.
    'Somebody run back and find either Lord Fatesaw or Lord Skaros,' Kordak snarled eventually, after swallowing his pride. 'We need a sorcerer.'
    He hated the idea. Hated the very thought that he was in a position where being a mighty warrior of Malice was not enough, that he had to rely on the arcane prowess of a sorcerer to tip the balance of a battle in their favour. It felt like admitting weakness.
    Somebody broke away and retreated the way the warriors had come, to do as Kordak had demanded be done. Even though it was what he had ordered, it still left a taste of bile lingering in the back of Kordak's throat. That none of the other warriors had argued and suggested other ideas meant that they had come to similar conclusions. There was no way that they would be forcing their way across this bridge without some aid.
    Well, unless Lord Soulshriver makes an appearance.
    Fortune smiled in one regard, the smaller lizards with their handguns weren't just raining gunfire on the warriors, even those who foolishly moved to a more exposed position. Maybe they were concerned about their ammo reserves? Kordak didn't know, didn't care.
    Regretfully, even if a warrior stood at the very edge of the water, few would be able to throw any javelins or axes far enough to actually hit any of those smaller lizards. And those who managed would no doubt be shot quickly to remove that particular threat to their safety. A pity, as maybe killing the smaller ones could have angered the larger ones into reacting and coming off that bridge.
    Kordak moved to the shoreline of the pond, staring at the smaller lizards disdainfully. They aimed their weapons at him, but the lack of any threatening motions on his part meant that as he reasoned out, they weren't shooting.
    'Cowards and fools. Stand and watch all you want.'
    They couldn't hear him, he wasn't shouting, more talking to himself than anything else. Like a silent vow, though voiced aloud as if it was more impactful that he actually heard his voice making the declaration.
    Nearby, the water shifted. Kordak's attention briefly turned to the murky water. Again he wondered how deep it was. Could he have everybody wade across? Was the bridge just so that the weaklings of the Empire didn't have to get their frilly little socks wet if they decided to pass through this grove?
    A ripple danced across the surface. Then another. Kordak's eyes narrowed.
    The water erupted.
    The beast's jaws were impossibly wide, clamping down with ferocious strength on his shoulder and chest. Armour buckled like tin, and Kordak roared as pain shot through his body. His axe slipped from his hand, the strength draining from his arm. He slammed his fist into the creature's snout, but it didn't flinch.
    The lizard twisted sharply, rolling in place, its iron jaws locked onto Kordak. His armour buckled under the pressure, and the sickening sound of cracking bones filled the air. It was not to his benefit that he managed to retain his consciousness the whole time. If he'd allowed himself to blackout, or to simply die from the number of hits his head took during the lizard's furious rolling, he wouldn't have had to suffer the moment that the lizard—jaw still clamped with an ungodly strength—dragged his body into the water. If he'd been unconscious, he would have been blissfully unaware of his death by drowning.
    Instead, his last moments were pain as he struggled to draw breath beneath the murky waters which swiftly turned crimson over the space where he vanished.
    That first kroxigor's appearance was like a signal, all across the edge of the pond, kroxigors lunged from the water, either clamping powerful jaws on warriors who were standing apart from their comrades, or swinging their weapons, if near a group of the warriors clustered together.
    The warriors of Chaos were taken by surprise, their focus fixed on either the saurus phalanx or the skink musketeers on the opposite side of the pond. They had clearly not anticipated any threats within the waters. That was their folly.
    Mex kept his satisfaction hidden—not that the Chaos warriors would recognise it in his reptilian features. The trap had worked perfectly, but there was no time to dwell on victory. Distraction meant death. If anything aggravated the warriors into a suicide charge against the phalanx, their angered reaction to seeing comrades mutilated by kroxigor death-roll would certainly be it.
    Especially when the Chaos thralls learnt that killing the kroxigors wouldn't be a simple task. After the initial strike at the armoured warriors, the kroxigors then pulled back into the water. It left the warriors unable to retaliate, unable to take out their frustrations on the crocodilians. That frustration would inevitably lead to anger—anger that clouded judgment. A suicide charge against the phalanx was the only outcome of such anger.
    If that was what the Chaos thralls chose, then Mex would be only too happy to assist them in their desire for death.
    True to his prediction, after a few moments where the thralls of Chaos shook their fists in impotent rage, or throwing javelins and axes at the water as if they could hope to actually harm the kroxigors hidden in the murky depths, they then fixed their sights on the saurus. Common sense dictated that charging a phalanx in a chokepoint was suicide, but rage had stripped the Chaos warriors of reason. They charged anyway.
    Mex braced himself, felt more than saw the way those at his sides did the same, and they received the initial rush of armoured warriors. Spears punctured through plate armour, a combination of the natural strength of the saurus paired with the momentum of the warriors' charge. The charge was thusly halted as the thralls met an unmovable wall of scale and spear.
    Crowded as the warriors of Malice were, they left themselves open to the skinks on the opposite bank. Gunfire cracked in volleys, and armoured warriors were felled as bullets punched through their exposed sides. And that was saying nothing of the kroxigors still lurking beneath the water, perfectly capable and willing to lunge out and pull their prey deep into the murky depths. The kroxigors swung their heavy weapons at nearby foes, casting them into the water alongside their captured prey. The murky depths quickly claimed them.
    Despite the position of strength upon the bridge, it wasn't going to last forever. It couldn't. Numbers were against them, and any more Chaos thralls that came wouldn't be provoked into throwing their weapons at shadows in the water. That left the phalanx as the only target of opportunity.
    It wasn't often that Mex bemoaned the way that shields had stopped becoming a mainstay of saurus arms. The Legion's saurus rarely fought like this anymore, standing firm in a defensive formation, pretending to be an unbreakable wall. It wasn't their way. Not like Mort's saurus. His warriors, his guardians, they would have turned this bridge into a fortress and held it until the last star burned from the heavens. Even Zak's regiment would have held longer.
    The problem had always been the shift in tactics. The original plan was to use the woodland terrain to their advantage: strike and fade, hit and run. Tactics where Mex's saurus and skinks excelled far beyond Mort's or Zak's commands. The bridge was never meant to be anything more than a fallback point. If not for the sheer scale of this battle, Zak would have been stationed here, his troops ready to hold the line when the time came.
    No use dwelling on would could have been. Focus on the now.
    The reminder to focus came in time for Mex to register the latest Chaos warrior charging toward him. A thrust of the spear punctured the neck, caused a spray of blood to stain Mex's scaled hands. Without a moment of hesitation, he wrenched the weapon free, then twisted it so that the hook caught another warrior's armour. With a hard yank, the armoured thrall stumbled forward, weapon lowered as he fought to regain his balance.
    He was never given the chance.
    The saurus to Mex's left lunged, driving his spear through the warrior's breastplate. Hellforged metal buckled under the force, and the blade punched through to the flesh beneath. The Chaos thrall crumpled, his body toppling onto the growing mound of carcasses that already littered the bridge. The pile rose higher with each kill, the slick, blood-soaked remains turning steady footing into a challenge for their enemies.
    No time to savour the kill. No time to bask in satisfaction at how well the line was being held.
    An axe hurtled through the air, spinning end over end, hurled by a warrior at the back of the mob. Mex hissed softly at the sight. He swung his spear up in a sharp arc, the blade striking the weapon mid-flight. The axe veered off course and fell into the water with a soft splash.
    Ducking might have been safer for him, but it could have meant the axe buried itself in the saurus behind him. Unacceptable. Mex refused to let his line falter because of one stray weapon.
    'How long are we to hold?' A saurus behind Mex asked with a low hiss.
    'As long as we can,' Mex answered, thrusting his spear forward, the blade finding flesh with a sickening crunch.
    Again he was reminded of the weight of the pistol tucked in his coat. The absolute last defiance that they would enact were they to be pushed away from the bridge. There was no more falling back and still being able to defend the grove. Fall back from this position, the Chaos thralls could exit the other side of the grove, close enough to the hill that Ingwel was commanding from that there would be no artillery support to soften their charge.
    But while the colonel was still somewhere in the grove, Mex wasn't eager to enact that final middle finger to the worshippers of Malice. He would do it. He was still a saurus. As much as the Legion played up their emotions for the benefit of the warmbloods, the cold reptilian logic still reigned in their minds—even for those who had embraced the display of emotion.
    War was calculation, a ruthless and unflinching arithmetic that left no room for sentiment. Even the life of the colonel could be weighed and measured, his death evaluated as a net positive if it tipped the scales against Malice's thralls.
    Logic offered no comfort. But it was irrefutable. Objective. It made the impossible choices bearable. Mex might not like it, but if it needed to be done, he would do it.
    That didn't mean he wouldn't delay as long as he could, buying the colonel every precious moment. Whether to win his duel against the champion or to break away and retreat, time was all Mex could give. And time, for now, was enough.
    It wasn't sentiment. It wasn't an emotional choice. Solin's life might be weighed as an acceptable casualty, but that didn't make it an ideal outcome. If Mex could delay long enough to ensure the colonel's survival, there was no logical reason not to. It could flavoured it as an emotional choice, and might even be done so if he had to recount the moment to a warmblood.
    But it was still cold, reptilian logic at the core of it.
    Shoulder burned with a fiery pain. Beneath the sode he could feel blood pooling out and staining, causing fabric to stick to flesh and chafe. Ignored it. The bruise on his forehead throbbed—a lingering gift from that brutish blow. He gritted his teeth, forcing down the surge of anger that threatened to override his focus.
    Had to maintain his discipline and focus. Could not let mindless rage take over, much as he wanted to embrace that feeling.
    The lizard parried another blow, then moved back, used the slick mud to its advantage.
    Soulshriver growled lowly, planted his feet and felt his grip on his naginata tighten. Any satisfaction he was getting from fighting an apparent equal in martial prowess had long since faded. Now he wanted nothing more than to skin this reptile alive, to flay the flesh from it while it could still feel every agonising moment.
    Control. Focus.
    Breathed in. Exhaled. Adjusted his stance. Didn't wait for the lizard to adjust in answer, leapt forward, naginata swinging. It was blocked. And again. And then a third time.
    Didn't let up though. Refused to give the lizard a moment to counter-attack. The naginata lashed out—again. And again. And again.
    Aimed a strike for the hand. Didn't hit, the lizard angled the oversized sword so that the naginata's blade hit the crossguard. Kicked at the lizard's knee—maybe not the most elegant move, but if the foul reptile wanted to fight like a dishonourable cur, then that was just invitation for others to do the same in turn.
    His foot met the lizard's knee with some force, but there was no satisfying crack of bone. The lizard's leg seemed to slide out from under it, but it wasn't an uncontrolled stumble.
    Soulshriver would give the lizard that much credit—it had mastered the terrain. The slick mud became an extension of its movements, allowing it to twist, shift, and flow around attacks. That strange, dancer's grace had nearly won the fight more than once. Even the headbutt that had given it the opening it needed to cut his shoulder had been born of its mastery of movement.
    Soulshriver would admit to underestimating the creature. Had seen that sword, and even with the initial show of speed and grace, had still mentally catalogued it as a fighter dependent on brute force and reach. It was a mistake he wasn't about to make again.
    Blocked the lizard's upward strike, felt his shoulder ache, the deep gouge carved into it protesting the strain, the fiery heat reminding him constantly that he has been injured.
    That burning sensation was concerning though. He had been injured in the past, he knew what pain felt like, even before his time at the Serpent's tender mercies. But something about this wound was different. Whatever it was, it was making it harder than it should be to ignore the pain, something he usually had no difficulty doing.
    Every blocked strike—his and the reptile's both—sent vibrations to his shoulder, and that fire in the open injury seemed to flare up and any progress he had made on shunting the pain to the back of his mind was undone by that renewed sensation that was just as vivid as the moment he had first been given the injury.
    It made him eye the lizard's blade with a new sense of wary caution. It had to be the blade. The faint azure glow it carried marked it as something significant. The dark metal was clearly Gromril; had it been forged by a dwarven runesmith? Was it marked with runes? And if so, what power had they bestowed upon the blade? Unnatural sharpness?
    The longer he examined the blade, the more Soulshriver felt a sense of unease. He shook his head and dismissed all thoughts of the blade from his mind, refocused on the muddied and bloodied lizard.
    Couldn't ignore the state of his shoulder though. As the fight carried on, it was getting worse.
    Pained as he was to admit it, even in his own mind, that one strike had lost him this duel. Unless he found some way to turn the tide in the next clash, he was going to have to withdraw. His dominant arm was weakening. Each block or parry he made was becoming less structured for it.
    He swung high, felt his arm vibrate as the strike was blocked. Backstepped, then swung low. It too was blocked. Made to swing again, but the lizard was faster, that greatsword came up and was thrust at Soulshriver. Parried, but the lizard turned the redirection of its blade into a circular swing.
    Planted the haft of his naginata upon the ground and pulled himself toward it, used it to vault over the swing of the lizard, and slammed his heels into the lizard's chest. Remembered that moment months ago he had used the same trick and how the lizard had used its tail to keep itself upright. Planned around that.
    As expected, the lizard slammed its tail to the ground, absorbing the impact of the flying kick with barely a step backward, its claws sliding slightly in the mud. But this time, Soulshriver was prepared and swung one foot upward while he still had momentum. His foot caught the lizard on the underside of its jaw, then continued upward, gave enough movement to allow Soulshriver to somersault back, landed on hit feet with the slightest of wobbles, not used to that particular level of acrobatics. The kick caused the lizard's head to snap upward and its balance was upended, eyes crossed, tail suddenly slack, whether from startlement or pain, Soulshriver didn't know, didn't care.
    Soulshriver twisted the naginata, reversing his grip as the lizard fell, its guard momentarily open. He lunged. But the creature recovered fast—faster than he expected. Its massive sword swept around, deflecting the naginata's strike and sending the blade plunging harmlessly into the mud. The lizard snapped its knees to its chest, muscles coiling like a wound spring. Soulshriver cursed—he saw it coming, knew exactly what was about to happen. But knowing wasn't the same as stopping it. He was too slow. The lizard kicked out, legs firing skyward with explosive force. It launched from the ground and landed upright in a single, fluid motion—greatsword already in motion.
    The greatsword crashed down. The haft of the naginata shrieked in protest—then splintered. Steel cracked, wood shattered. The weapon snapped in twain.
    Soulshriver swore softly in his native tongue, backstepped and dropped the lower half of his naginata's haft from his hand, moved his right to his hip and grabbed at one of the two blades, didn't take the time to check which. Grabbed the hilt and hurriedly pulled the weapon free.
    Thankfully, instinct guided his hand—he drew the right blade. His katana flashed from its sheath, the edge biting through the air in a lethal arc. The lizard recoiled, forced to backstep or feel steel carve through its belly. As soon as he bought himself space, Soulshriver reset his stance—both hands on the hilt, blade angled defensively.
    The lizard's gaze widened—briefly—at the shift in stance. But then its crimson eyes flicked to his wounded shoulder, and a knowing glint sparked within them. In an instant, it pressed the attack, its blade a relentless blur.
    Soulshriver was a talented fighter. But the katana was not his weapon—it was his fallback, his last resort. He had mastered the naginata, wielded it like an extension of his own will. This blade? It was a badge of status, not a weapon of war. If he was using it, it meant he had already lost.
    It did not help that against that oversized sword, the katana was at a disadvantage. Even his katana, master-crafted and enchanted as it was. Couldn't rely on parries, even if his shoulder wasn't injured. And avoidance was getting tiring.
    He knew it now—he had lost this duel. His wounded arm slowed him, his favoured weapon lay in ruins. But if he was to fall, he'd make damn sure the lizard paid the price.
    The greatsword came for his neck—a killing stroke. But it met only smoke and buzzing shadows.
    Soulshriver dissolved, his form unravelling into a swarm of hornets that scattered, hanging in the air before surging together again a few paces away. He reformed, breath steadying, eyes fixed on the reptilian kensai once more. The lizard stared back, knees bent, clearly ready to pursue, to try and finish the fight with Soulshriver's death.
    Let him try.
    He stared back at the lizard in silent challenge, then deliberately looked in the direction from which the background chorus of gunfire could be heard. There was a low hiss from the lizard, and then it stalked toward Soulshriver with a very clear intent to stop him from moving that way. Soulshriver hummed, tightened his grip on his weapons, but took a step backwards, further from the fight.
    Come then, beast. How badly do you want me dead?
    The lizard paused a moment, eyes narrowed, searching, considering.
    No, no you don't.
    It was difficult to smirk without lips, trapped in a perpetual rictus grin. But there were other ways of taunting, other ways to convey mockery without words. A slow twirl of the katana, the lazy and contemptuous flourish of one who saw no threats.
    The lizard didn't appear to take the bait. Tilted its head, ever so slightly, but continued to stay back, staring.
    Maybe that was too obvious, or else it doesn't understand the mockery.
    He flicked a glance toward where the other lizards had gone. A calculated move—just to see. And that, at least, got a reaction. The kensai tensed, muscles coiling, weight shifting forward as if preparing to intercept him the moment he tried to follow.
    Soulshriver exhaled, steady and measured, then took another step back. Not turning, not running—just moving. Just watching.
    The lizard mirrored him, shifting its weight, tracking his every movement with those unblinking crimson eyes. It was wary now, more cautious than before, yet not so hesitant as to let him simply leave.
    Good.
    He didn't need to go far. Didn't need to force the fight now. But he needed to keep this one isolated. Away from the lesser lizards. He had lost the duel, but he would be damned if he let the lizard win.
    Another step back. The lizard tensed, ever so slightly.
    He let the barest flicker of amusement glint in his eyes. Let it follow. Let it chase. Let it think it was in control.
    Then, with a final glance, he turned—just enough to invite pursuit—and disappeared into the overgrowth.
    thedarkfourth likes this.
  2. J.Logan
    Battle on the Mud - Flight
    Northern Middenland
    Battle Duration: 4.5 hours
    It was a low rumbling sound. Like thunder in the distant skies. But close, intimate. And far more dangerous. Dangerous, but not indiscriminately. This sound wasn't in the distant skies, wasn't a far-away rumble of thunder. It wasn't in the skies. It was on the ground, closing fast—a cavalry charge. But no horses galloped this way. No banners fluttered above lances. This was the charge of aggradons.
    Preda leaned into the motion, the rhythm so familiar it was almost a comfort—even in danger. If he closed his eyes, he could almost believe he was riding for the joy of it.
    But he was a saurus. His lot in life was to fight and kill for the Great Plan. To defend it. With his life, if that was what it took. And Preda had no problem with that. That was the true comfort for Preda, that knowledge of his purpose. He knew his place in the world. He knew why he existed.
    For a moment, brief as it was, the sound seemed to fade away. Like existence itself held its breath in the eager anticipation of the next few seconds.
    Preda tightened his grip upon his sabre and braced himself.
    His aggradon mount leapt—launched himself the last few metres, flying through the air, all snarling teeth and razor-sharp claws. Landed amidst the Chaos warriors, crescent talons eviscerating one warrior, while another warrior found his head within the raptor's maw, jaw clamping down with force enough to buckle the helmet. A third warrior was felled by a thrust of Preda's sabre to the neck, the height advantage of sitting upon a large aggradon more than enough to allow him to aim that stab without any hindrance from the Chaos warrior's gorget.
    Around Preda, his fellow cavalry-saurus landed from their own charged leaps. The violence was brutal, primal—but tempered by training and experience. Even in the heat of slaughter, the aggradons heeded their riders—trained not to lose themselves to bloodlust, but to kill with purpose. A nudge of a knee here and the aggradon would turn away from whatever had its attention, a click of the tongue there and the aggradon would direct its aggression to a different target, trust forged through long bonding having the raptors believe that their riders knew best.
    An ironclad gauntlet rose in a vain attempt at defence. That hand was swiftly removed as fangs tore into it—ripped it free of the arm it had been attached to. Another warrior tried to angle his halberd to fend off the large raptor charging him. It was a futile effort—its rider struck first, a swift kick disrupting the warrior's stance before he could even raise his weapon properly. The warrior had no time to recover before the aggradon's claws finished what its rider had started.
    The Chaos warriors had been focused on butchering the retreating infantry when the aggradon cavalry struck. Unwittingly, they had trapped themselves against the rock—leaving the saurus riders to play the hammer. Empire halberdiers made for a very dangerous rock for the Chaos forces to be slammed against.
    Chaos reigned among the warriors of Malice. Some turned, raising shields against the charging cavalry. Others braced for the wall of steel ahead. None could do both.
    Do they stand against the disciplined wall of halberds and bayonets, steel tips aimed at their throats? Or do they turn to the snarling raptors, with riders ready to cut them down?
    Despite the moment going in their favour, Preda was keenly aware that it was a temporary state. This was but a single band of the ruinous warriors, more would come—soon. And the Malice warriors had cavalry of their own.
    They needed to finish this skirmish quickly. The infantry had to reach the hill. And Preda had to ensure they made it—by leading the aggradon cavalry against the Chaos riders who would try to cut them down.
    Fortunately, Preda's cohort wasn't the only one working to protect the retreat. Overhead, a terradon swooped past. Seconds later, an explosion thundered through the Chaos ranks—the rider had dropped another grenade into the gathering of ruinous warriors. That wouldn't last long. Terradon riders rarely carried many grenades—they weren't meant for frontline battle. But Preda was thankful for what they did carry. Explosions deep within one's ranks always had the same effect—turning cohesion into chaos.
    But not the kind of chaos that the Ruinous thrived on—despite the name.
    Preda's sabre felled another warrior, its keen edge finding flesh, cutting him down in a single stroke as his mount tore into another foe. This clash of warriors was coming to its end, The infantry were already turning away, resuming their withdrawal, leaving Preda and his saurus to cut down the remaining stragglers.
    He took a moment to survey the battleground, took note of where the hordes of Chaos warriors were, and more importantly, where their cavalry was. His eyes locked onto a band of Chaos knights, riding a small distance away. Knights with actual horses, unlike the apparently far more common daemonic pillbugs that this warhost favoured.
    That was fine. Horses made for good meat for the aggradons.
    Captain Yen'ayes scowled down the hill, assessing the fighting retreat below. He gave a silent thanks to Yackl for having alerted him that going to the farmhouse would have been pointless. He preferred the hill anyway.
    Though unlike the suggestion passed on from Preda, Yen hadn't moved to the peak of the hill, but formed up the regiment under his command upon the sloped inclines. Saurus armed with spears formed a perimeter around the rest of the regiment, while the skink musketeers stood in staggered lines at different elevations, all lined in such positions that they could see over the heads of those in front of them. Even if the thralls of Chaos reached the saurus walls, it wouldn't be shield enough to spare them the gunfire.
    Behind the musketeers, Yen repositioned the small number of bastiladons and infantry from the hilltop, integrating them into his regiment to bolster both numbers and firepower.
    Between the bastiladons, a crate of musket ammo sachets. The skinks from the farmhouse would no doubt need more ammunition. Yen would provide it, allowing them to hold the newly drawn line—like a scaly St Nicholas, delivering gifts to the noble and righteous while striking down the wicked.
    Allowed himself a small chuckle at that mental image. The Empire would probably have something to say if he actually voiced such thoughts. Likely nothing good, what with defensive warmbloods got regarding what they considered "theirs".
    Yen huffed, fingers tapping an irregular beat on the hilt of his sabre. Though a captain, Yen never relished command. His true passion lay in teaching—drilling skinks and saurus in the art of swordsmanship, the skill that had become a mainstay in the Legion. But like most saurus who reached a certain age, leadership found itself thrust upon him. Fortunately, he was rarely needed to act as such. As a captain, he was usually serving under somebody else—typically Colonel Solin—so he rarely needed to command more than a cohort or two. But then, battles like today's happened, and Yen was forced to step into the role of leader for a force, of which he had likely tutored at least half in swordsmanship and fencing.
    As a saurus, his ultimate duty was clear. As an individual, he wished he could just be the teacher, to live through the successes of his students.
    But the Old Ones had their plan, and as much as he might wish that he never had to set foot upon a battlefield, this was where he was needed.
    He closed his eyes for five slow seconds. Inhaled. Held it. Then exhaled, expelling hesitation, doubt—anything unnecessary for the fight ahead.
    End of the day, he was a saurus Scar-Veteran. He knew his duty. He would fight. Win. Prevail.
    Mind clear of distraction, he refocused on the retreat below. Preda's cavalry was doing a good job of disrupting the efforts of the thralls of Chaos to run down the retreating infantry. It also helped to tell Yen that the retreat wasn't from a broken force, morale shattered. The infantry fell back in as good an order as the circumstances allowed, their focus sharp on approaching threats. Halberds turned into a bristling wall, warding off the warriors of Malice.
    It improved their odds of surviving long enough to reach Yen, their ability to turn themselves into a rock upon which Preda could be a hammer.
    Yen's gaze shifted from the retreating force to the seething mass of Chaos warriors. His regiment had been noticed. Unlike the retreating infantry, the enemy surged forward, unburdened by repeated attacks. The Chaos warriors split themselves, forming multiple war-bands.
    Must be a handful of leaders within that mass, to break apart so cleanly. Not perfectly—some warriors hesitated, uncertain which mass to join—but by Chaos standards, it was almost disciplined. Especially since there did not appear to be any arguments or confusion about which way each would start to move. They divided, and they all moved in different directions, but with the same destination.
    They were coming. From different angles, with different leaders, but one goal—him.
    Well, aside from the ones still chasing the retreat, Yen conceded.
    Four war-bands. Four angles of attack—if he counted the one still pursuing the retreat. He never assumed the war-band veering away was retreating. They were trying to circle around, crest the hill, and strike from behind. But Yen had chosen his ground well. Even if they reached the peak, the slope was too sheer for a direct descent. They'd have to move at an angle until level with his position—turning their attack from a rear strike into a flank assault instead.
    No downhill charge for Chaos. Not today.
    His fingers drummed a steady beat against the hilt of his sabre. Even with his mind clear, a measure of something remained—not quite impatience, not quite tension, but the weight of waiting for battle to begin.
    That moment when all anyone could do was wait. Wait for the charge. Wait for the enemy to come into range. Wait for them to break.
    Yen never believed for a second that Chaos warriors would be wise enough to break at the sight of a prepared foe. Their sheer numbers had already proven enough to overrun opponents—hence the infantry's retreat from the farmhouse.
    No, Chaos needed more persuasion than a disciplined battle line in their path. Chaos needed blood. Violence. Something to rattle them.
    Not that Yen would ever complain about killing Chaos warriors. Their lives were forfeit the moment they gave themselves to the Ruinous Powers. The Legion's duty was to put such wretches down.
    A blink. Or it felt like one. But when he looked again, everything was closer. Nearly time. Another blink. Closer still.
    Close enough. Yen drew his sabre, the blade sliding free. He was ready.
    The fight was here.
    Inhale. Exhale. Open mouth. 'Fire!'
    At his hissed command, the musketeers fired.
    Yeucan cursed softly, slipping on the slick mud, the frantic footsteps of everybody in front of him having churned the ground. Was spared a faceplant when the human behind him grabbed his shoulder and steadied him before the sliding of his feet could tilt him to the point of no return. Mumbled his appreciation, quickly adjusted the musket in his grasp and continued to move.
    Some distance away, thunder cracked, but not with the fury of the sky, but with the regular rhythm of volleyed gunfire. Yeucan couldn't see past the crowd of his fellow soldiers before him, but if he was to make a guess, the reinforcements at the hill had begun to secure their position. He hadn't been able to see who the commanding element of the reinforcements was, but with any luck, they were smart enough to use their position to good effect.
    Hills were the unsung heroes of many a battle. A good solid place to plant oneself down and refuse to budge. Good for gunfire as well.
    'Right!'
    At the shout, everybody halted, turned in the direction called out and braced, halberds and bayonets aimed for the coming charge. It would never be as solid a spear wall as if they hadn't been moving, but it would do. It had to do. There wasn't much else that they could do in this situation. Brace against attacks, become a wall upon which Preda and his cavalry would hammer the enemy against.
    One would have thought that the warriors of Chaos would have learnt after a few repetitions of this exact sequence of events. But then, Yeucan recalled that there was a saying about insanity that described this same pattern. And nobody ever accused the thralls of Chaos of being sane.
    Yeucan felt it the moment the Chaos warriors slammed into their wall of blades. The entire formation shuddered, like a fortress struck by a battering ram. Yeucan pushed his shoulder against the human that would have backstepped into him, lending him some extra strength to remain unwavering against the pressure applied to the bladed bastion.
    Screams of anger and fury, not all of which was from the warriors of Malice, but replies from those being struck at. War was bitterness and hatred, and Chaos was always an acceptable target of such rage, a victimless recipient of the worst emotions that could be levied at anybody.
    Step. Step.
    Slowly, the block of men and skinks pushed back against the Chaos warriors—refused to be static and idle. Even if their best defence was to hold until the hammer could come down, pride decreed that they still fight with everything they had, to not rely on the incoming charge.
    Step. Step.
    A squelch of mud. Yeucan twisted his head, looked over his shoulder. Cursed softly, then louder.
    'Behind!'
    At his shout, the back half of the block turned fully around, bracing weapons.
    Maybe Chaos wasn't quite so insane then, to have decided to mix up their play somewhat this time. To try and hammer and anvil the retreating force instead of constantly being the ones to suffer it.
    Yeucan felt his arms shake, vibrating from the force of which the Chaos horseman ran into the bayonet at the end of his musket. He would have been bowled over if not for the same human he'd braced moments earlier. Still felt an agonising ache in his limbs from the force, fingers rapidly numbing.
    The warhorse screamed—a horrible, snarling sound—its eyes burning with fury, as if it blamed Yeucan for its rider's mistake. Yeucan hissed back, twisted his musket—twisting the blade still buried in flesh—before ripping it free and driving it straight through the beast's eye. The horse convulsed, then toppled, taking its rider with it. The rider was cut down by a halberd before he could recover.
    Yeucan acknowledged that he had gotten lucky, could have easily been crushed beneath that horse. Probably should have been. The horse must have slowed before it had reached him, but not enough to avoid impaling itself. Had still had enough force in its momentum that Yeucan could now barely lift his weapon, the strange mixture of ache and numbness engulfing his limbs, but it hadn't been able to slow itself enough to avoid running into the bristling line of pointed steel.
    But Yeucan was not representative of everybody who had been at the front of that flank. Humans and skinks alike were crushed beneath the charge of the large warhorses, slammed to the ground and trampled, or cut down by the over-sized axes of the riders before those behind the front line were able to retaliate.
    Heaved out a breath, fought against the leaden weights now pulling at his arms, and lifted his musket back into position and lunged forward, stabbing the bayonet into another Chaos warrior.
    An explosion erupted somewhere behind the Chaos cavalry. Overhead, the terradon flew past, the skink riding the majestic creature having his finger in an obscene gesture at the now panicked Chaos horsemen.
    And following the explosion, a rush of aggradons charged, leaping with tooth and claw at the ready. The Chaos cavalry charge had been halted by steel and grit, now it was ripped asunder by talons and fangs.
    Ingwel growled lowly. The problem with command? He had to be the voice of order, reading the battle and shifting the tides through others, not his own blade.
    Watching those who entrusted their lives to him fight and bleed while he stood at a distance, forced to send others in his stead? Infuriating. Even when he locked away emotion—suppressed every instinct—it burned to not be there, fighting beside his saurus and skinks with blade and claw.
    Breathed in, calmed the fire within that demanded he forgo common sense and charge. Charge in which direction? He couldn't even say. To the east: troops retreated from the farmhouse, its walls collapsed, any strategic value lost. To the west: Mort fought against a Chaos champion who was managing to fight on near equal footing.
    Probably a good thing that Ingwel wasn't able to see through the canopy of trees to the grove that lay at the foot of the hills, who knew how that front was faring? But at the same time, not knowing was almost as bad, let his imagination dredge up worst-case scenarios.
    Moved his spyglass back to the eastern front. Hummed in unheard approval as the latest charge against the retreat was driven back. Captain Preda, as ever, struck like a viper—always at the rear, always where the enemy least expected. An anvil of flesh and steel. Cold? Some might think so. Necessary? Absolutely. The cavalry was too few, the Chaos warriors too many. Preda couldn't stop them all, but he could make sure they broke against the infantry instead of overrunning them. Outside of those decisive hammer-and-anvil strikes, he still cut down Chaos troops wherever he could—though some managed to slip past, only to face the hunting aggradons.
    It wasn't as if Preda wasn't striking at any Chaos troops outside of those moments. The hammer and anvil moments were those that slipped past the hunting aggradons.
    Shifted his attention slightly, took in Yen's position on the hilltop and rumbled in approval. A good solid position with good firing angles. A small bastion where the retreating troops could recover from their flight and regroup. Assuming that the retreat reached Yen's position.
    Ingwel had faith that they would.
    Looked back toward the bulk of the Chaos warhost, aligned the spyglass with the warlord in charge. He studied this pristine white form that was borderline regal and not at all like one would expect a Chaos champion to look. With colour and heraldry, he could have passed for a Bretonnian paladin—proud, regal, heroic. Where a noble house's sigil should have been, the dreaded star of Chaos leered back. His sword did not shimmer with the Lady's grace but pulsed with something far fouler—black, jagged, and needle-sharp, it looked like the stinger of some monstrous hornet.
    For a moment, the Chaos warlord paused, his head tilting ever so slightly—almost as if he sensed he was being watched. Then, just as quickly, he turned away, gesturing to a lesser warrior. His head moved subtly, the way one does when speaking, though from this distance, no words could be heard.
    There was a sound of surprise from behind him. Ingwel lowered the spyglass, was about to turn to address whoever had made the sound, but the moment his vision was no longer locked to the view gifted by the brass tube, he could see what had caused that surprise. From that wooded grove, a sudden burst of red light shot through the canopy, a lance of fire streaking into the sky. Against the pale afternoon sun, it burned like a bloodstain in the heavens, vivid and impossible to ignore. For a moment, it lingered—then it dimmed, leaving only a faint trail of smoke curling in the breeze.
    'Damn,' Ingwel cursed in saurian.
    There was no need for him to make any commands, for the presence of that flare had been planned for in advance. The knight of the White Wolf had commented on that plan, given it a fitting term.
    Scorched earth.
    Fitting. Because that was exactly what was about to happen.
    Yen listened to the choir of gunfire, twisting his head around to stare impassively at the Chaos warriors who had clambered awkwardly down the hill. As he had predicted, they'd been forced to angle their descent in such a way that they hadn't been able to strike at the rear but instead side-on.
    Admittedly, he hadn't predicted their attack angle perfectly. His skink musketeers had adjusted their lines hurriedly—not ideal, but not disastrous. Even without repositioning, they still fired from a position of strength. But with the numbers against them like this? Every little detail that could tip the balance of power in Yen's favour was going to be taken into account and used to best effect.
    The real problem? The Chaos warriors were nearly level with Yen as they charged. No way to stack musket lines from elevation—not really. Had to treat those Chaos warriors and cavalry as if they were fighting on open ground.
    Ah well. At least it's only the one band and not all four of them, Yen hummed, seeking that silver lining and finding it. Better to have only a portion of the Chaos force fighting on as close to equal footing as they could get, rather than all the Chaos force.
    Another volley of gunfire cut a bloody path through the Chaos warriors. Further down the hill, a second line of skink muskets fired, this time aiming down the slopes at the first warband to reach them—the ones who had abandoned clever manoeuvres in favour of a direct charge at Yen's position. That warband had quickly learnt the folly of trying to charge uphill against a wall of spears and muskets.
    So far, none of the warriors of Chaos had managed to break through that wall. The saurus warriors were quite adept at stabbing at anything that came within reach, and had strength enough to puncture armour. Meanwhile, muskets were the great equaliser in warfare, didn't need strength to puncture armour, just point and shoot. And that was exactly what the skinks carrying those lethal weapons did, firing down the hill into the mass of armoured warriors, bullets punching through hellforged armour.
    'Where's the retreating battalion?' Yen asked aloud, craning his neck to find the topic of his question. He'd lost track of them after the initial clash with Chaos warriors, had to focus on the immediate threat rather than the trials of his allies.
    A nearby skink pointed. 'Over there. Looks like they've circled some to get around the warriors who reached us before they did.'
    Yen stared in the motioned direction, easily spotting the block of retreating infantry. At the skink had said, they were slightly off-position than if they'd made a direct line for Yen, which would have had them fighting through a mass of Chaos warriors blocking their path.
    Though how much of their detour was intentional, and how much of it was because they'd been attacked and it had thrown their path off-kilter? Yen couldn't say. Wasn't important anyway—they were still making their way toward him, still being helped by Preda's cavalry.
    A nearby bastiladon rumbled, the cannon mounted atop its shell firing. The shot blasted through Chaos warriors, but they weren't the target. The real mark—a hulking, mutated troll—let out a guttural roar as the cannonball detonated in its face. It clawed at the bloody ruin where half its skull had been. It might not have been a salamander shot, but the explosion should have had enough heat to it that the regeneration should be slowed for a moment.
    And even if it wasn't enough, the troll was more occupied with being in pain than it was with charging the saurus lines.
    Another volley from behind. Yen ignored it, instead turned his attention to the Chaos warband that had yet to reach him, the one that seemed to have taken its time, wasn't even nipping at the retreating infantry's heels.
    In Yen's opinion, if any of the four warbands were to break Yen's position, it would be them. They were smart enough to not exhaust themselves before reaching the fight. Would be fresh and ready while everybody else exhausted themselves.
    For a moment, he wished he had a spyglass at hand. But then another chorus of gunfire pulled him from those thoughts. He refocused his attention, took in the flanking force trying to push forward despite the gunfire and the spear blocking their path.
    'Captain!'
    At the call, Yen turned to the skink, who was pointing to the west. Yen followed the skink's finger and cursed softly at the sight of the red flare over the grove.
    'That's a bad sign,' he mumbled to himself.
    'Do we answer or does Major Boney?'
    'Both.' Yen answered sourly. Then, louder: 'Bastiladon crews! Load salamander shots—fire on the grove! Burn it to the ground! And pray to whatever Old One listens that our spawn-kin make it out in time.'
    He turned his attention back to the Chaos warriors. No time to think about the fact that the defence in the grove had failed. Failed to the point that the only answer was to turn that grove into an inferno to temporarily stay any Chaos advance from that direction, and even after, there would be no cover for an advancing force.
    But the grove being gone would also remove any camouflage regarding the Legion's numbers. Once the flames died, there'd be no more shadows to hide behind. No more illusions of strength. Anyone with eyes would see the truth—just how badly outnumbered the Legion really was.
  3. J.Logan
    J.Logan Well-Known Member
    Battle on the Mud - Where the Mud Held
    Northern Middenland
    Battle Duration: 5 hours
    'Flare!'
    Boney's attention was captured by the call. His eyes automatically turned eastward, in time to catch the burst of light. His mind recalled the briefing before the battle's start, the plans and the contingencies.
    The grove between the two farms. Ground where any advancing forces would be given cover from the Legion's gunlines. Technically, ideal hunting grounds for the Children of the Gods. But it had been realised quickly that the grove wasn't big enough for that advantage to negate the issue of the numbers they'd be facing. A full-sized forest, hunters could move hidden, unseen and strike at any stragglers, to slowly whittle down the threat. In that grove, there was only so much that could be done, no room to truly move around and hunt prey.
    And so the plan had been that the saurus and skinks in the grove would do what they could to delay any advance, but with the knowledge that unless the warlord in charge of the warhost was an idiot, it was always going to be a delaying action not a sustainable front. The moment it was decided that the delaying action was no longer viable, they would fire up a flare, some rocket of coloured powder that would light the air in a signal.
    And Boney's part was preordained. He was to scorch the earth.
    'Salamander shots!' he called out to the gunner crews atop the bastiladons. 'Fire at the grove. Burn it to the ground.'
    There was a moment of hesitation from the gunners, no doubt some nagging concern regarding the fact that there was no way to be certain whether they were about to burn their kin along with the trees. But they were Children of the Gods, and sacrifice was something they were long aware of the importance of.
    But even with an instinctual and cultural reinforcement of sacrifice and its often-times necessity, Boney… wasn't able to watch. He could have just condemned kin to burn, and the idea that it was because he gave the order was too much for him. He turned away, focused instead upon the Chaos warriors threatening his position.
    He didn't flinch when the cannons fired. Swallowed, reigned in any discomfort, and stared at the lines of Chaos warriors. Let out a huff of amusement at the slowly increasing span between them and the saurus wall. As the battle had dragged on, the musketeers had slowed their rate of fire, until it had reached a point where they would only fire once the Chaos warriors pushed and reached a certain distance between them. The warriors of Chaos weren't stupid, they had worked out that there was a range within which the skinks would fire.
    Without the champion or some other leader rallying them, they were reluctant to push forward now. Every time a group mustered the courage to charge, they were shot down before they reached half the distance. They weren't broken, but they were certainly rattled.
    The only exceptions were those who neared the clash between Mort and the skull-wearing champion.
    Speaking of which…
    Boney watched the latest clash between the two, eyes narrowed. Couldn't help, not with magic. The champion had shown himself to be immune. How one could be immune to a bolt of lightning striking them simply because magic was the reason the lightning struck was a little beyond Boney's understanding.
    Interesting to note that as time had passed, less and less warriors had tried to involve themselves in that duel, until only the foolish bold and the stupidly overconfident felt the need to try and aid the Chaos Champion. If they weren't run through by Mort's spear, they were knocked down by his shield, and left to the mercies of the nearby saurus.
    Though that wasn't to suggest that the saurus weren't also looking for an opportunity to get involved to help their major. But unlike the Chaos warriors, they were far more careful about involving themselves in a clash of such champions, and were balancing the notion with their duty to hold back the tide of warriors.
    Boney turned his attention to toward the central hill, where Ingwel was no doubt watching events unfold. The nature of battle across such a vast space, couldn't hear what the higher authority wanted done. Not without sending a runner to pass on messages. Maybe if the terradons weren't so preoccupied with the furies. Based on what Boney could see, Ingwel's attention was fixed in the opposite direction, toward the eastern front.
    Wonder how they're faring compared to us, he mused privately, before his eyes lowered to the farmhouse at the base of the hill. It appeared a fresh wave preparing to make a push at the walled off structure. Looked to be a wave of mostly daemons and foul mutants.
    'Prepare to fire at the ground around the farmhouse,' he called out. 'Let's soften that wave before they reach the walls.'
    Didn't hear the affirmatives of the artillery crews, had focused his attention outward, scanning for any more Chaos forces that might be trying to be clever and circle around the hill entirely in favour of going straight for the central hill. So far it seemed that none had gotten that idea. Probably a case of target fixation. Now that the warriors had a target so near, they weren't content to let go of that, to redirect their attention.
    Boney turned again to the farmhouse, feeling a stutter in the Winds. Without consciously considering what he was doing, his mental awareness grabbed at the foreign fingers weaving at the Winds and slapped it aside. Felt the personality of the other mage, the spike of ire that was levelled at him for the insolence of daring to dispel their shaping of the Winds. And then he felt nothing, that fleeting connection already faded.
    'Keep your eyes open, they have a sorcerer near!'
    Near enough that he was able to feel their efforts at shaping the Winds. Near enough to be able to dispel those efforts. But that also meant that they were close enough for it to go the other way. Casting magic was now going to be a gamble, would he be able to cast, or would the sorcerer counter his efforts? It was difficult to determine the strength of a magic caster by a single dispel, not when common practice to avoid potential miscasts was to not needlessly put more than was needed into a spell.
    Scanned the sea of daemons and mutants moving toward the farmhouse. He had a feeling the sorcerer was down there, the one directing the abominations. Call it a hunch.
    Clicked his teeth together in consideration, then exhaled roughly through his nostrils. With a Chaos sorcerer near, and possibly more than just the one, he decided to avoid casting magic himself. Best to focus his effort on disrupting their efforts.
    Mort hissed softly, aware on the edge of his peripheral that something had just changed. Subtle, but wrong. He didn't have time to decipher it now. Not when his attention was required on the immediate issue in front of him.
    This Chaos champion had lasted a long time. Had seemingly boundless stamina, such that even after all this time, he still was not waning, still fighting with as much vigour as he had begun. The only waning that came about was from any injuries he took, so there was proof, however slight, that this was not an unstoppable juggernaut of violence.
    This skull-clad champion took any moment of weakness and used it as fuel for his rage.
    And in theory, that was fine. Mort could do this all day if the need arose. Millennium of a duty that required patience and a surprising amount of endurance for all that it wasn't apparently physically taxing—what would one day be compared to months of constant vigil?
    But it wasn't an ideal outcome. To simply outlast meant that he wasn't actively beating this enemy in combat. And it was time that he wasn't contributing to the battle elsewhere.
    Not to suggest that a duel with an exalted champion of Chaos wasn't a notable contribution, but it was still one aspect of the greater whole. And the longer this duel took—assuming it could even be truly referred to as a duel—the less time he was able to assist elsewhere.
    The less time he could spend protecting those that needed such.
    He heard the growl of a Chaos-mutated hound. Exhaled sharply. Threw his shield at the champion. Knew that it wasn't going to be some felling blow. Hadn't been the last time. Wouldn't now. But it was still a moment of fleeting distraction for the champion, a moment where he had to focus on the aspis slicing through the air toward him.
    As the skull-clad champion focused on the incoming shield, Mort twisted and thrust his spear. The spear punched into the warhound mid-leap, sinking deep into its gut. It didn't halt its charge—but Mort twisted, redirecting its weight. He flung the dying beast into a nearby Chaos warrior—one of the lesser-armoured ones.
    Narrowed his eyes as that last detail registered. Took a moment to scan his surroundings while he summoned his shield back to his arm. Took note of the positions of the myriad of warriors, armoured and unarmoured. The battlefield had shifted. Earlier, the plated warriors led the charge—now they lingered behind, sending the lightly armoured marauders to the front instead.
    Clearly, they'd grown wary of the mounting casualties. The armoured elites now threw the marauders forward like fodder, realising brute skill alone wouldn't break the line.
    But even the marauders were reluctant to push forward now. Chaos hadn't yet fully stripped these people of their survival sense. Though no doubt their confidence would return when the next wave arrived. If another wave was coming.
    In the meantime, it looked like it was mutants and lesser daemons that were continuing to try and push forward despite everything. Creatures—and that was a word that only barely counted daemons in—that held no survival instincts.
    He wondered idly if the eastern and central fronts were going even half so well. If they were, this was almost a victory guaranteed.
    The skull-clad champion chose that moment to charge, roaring a rage-filled scream. Mort snapped back to the fight, barely registering the artillery barrage—aimed not at the Chaos lines, but at the grove marking the central front.
    He met the axe with his shield, deflecting the blow with a sharp twist of his arm before thrusting his own weapon in retaliation. Wasn't surprised when the champion dodged aside the sharp head of the polearm, was already whipping his tail around in an effort to trip him up.
    The thick appendage slammed into the champion's leg, but Mort was left disappointed when the large human barely stumbled back a single step at the strike—though later on, the memory of the red welt that formed on the champion's leg would be a source of satisfaction.
    Stepped forward, pressed his offence. This champion, with his seemingly endless stamina, was not a foe that could be beaten through attrition. Not in any reasonable timeframe. Pressed the attack, but not recklessly so. No need for him to endanger himself in doing so.
    Swing. Parry. Stab. Twist. Duck and retaliate.
    The champion had an uncanny sense for which blows he could absorb, and which were truly dangerous. And it was infuriating. More than once, the champion let the shaft of Mort's spear slam into him with little more than a grunt—trading pain for an opening to strike back.
    Not that those efforts worked. Mort was still alive, mostly unharmed. A few new nicks across his scales—nothing deep, nothing fatal. Maybe a few fresh scars. Nothing to worry about.
    Parry. Retaliate. Backstep. Block. Stab. Pivot and swing.
    He slammed the shaft of his spear into the champion's shoulder. The scream came, as expected—fury, yes, but laced now with pain the champion had previously hidden.
    Mort's gaze snapped to the wounded shoulder. The broken spearhead was still lodged deep, the hooked barb sunk into muscle like a hornet's stinger. The champion's arm dragged, sluggish and unresponsive.
    Backstep. Block. Parry. Kick. Swing. Swing. Swing.
    He allowed himself a flicker of satisfaction. The flurry had served its purpose. The champion powered through the pain—but the steel was still there, barbed and buried deep in muscle. And with each passing moment, the injury became harder to ignore. The champion couldn't lift that arm above shoulder height. Defence on that side now came from awkward body turns and off-balance swings.
    Mort bared his teeth in a grin. Victory might come sooner than expected—now that he had a weakness to exploit.
    The champion stepped back and hurled his axe—forcing Mort to backpedal, raise his shield. A brief reprieve, stolen through aggression. The axe bounced harmlessly against the aspis and vanished, summoned back to the champion's hand.
    The champion heaved deep breaths, unseen eyes drilling holes into Mort. A silent challenge to be the first to resume combat. Mort would have indulged, but the squelch of mud snapped his focus to an insectoid daemon charging him.
    Ducked. Raised his shield and slammed it into the underside of the pouncing daemon. Pushed and shoved, threw the abomination aside.
    Snarled. Swung his arm—let the aspis spin free, whirling through the air. He turned back just in time to catch the axe strike with his spear. The second came fast, but he grabbed the champion's wrist, halting it before it could gain momentum. Had no problem keeping that second hand in place, the strength sapped by the impaled spearhead.
    He twisted, using his weight to drag the champion around—angling his body so that the Chaos warrior now faced the saurus lines. He lifted a knee and smashed it into the champion's hip, then pushed with all his strength. Whether it was fading strength or just slick mud, the same warrior who had once lifted Mort with one hand now slid backward, boots skidding in the muck.
    Mort raised his arm—called back the aspis, its edge freshly painted with daemon ichor. A quick shake cleared the worst of the blood. Then he swung. Parried. Swung again. Drove the shield's edge into the wounded shoulder. He didn't relish the champion's roar of pain. Such things were beneath him.
    Blocked a wild swing of the axe, then cursed softly, more mud squelching from rapid footfalls. Angled his head, just enough to check what was charging him from behind, while still keeping his eye on the threat in front.
    Four Chaos warriors. Three lightly armoured marauders. One fully armoured. Either they thought they had the element of surprise—or they'd started to doubt their champion.
    Looked again at the champion. Noted that a pair of saurus were moving to attack the champion while his back was to them. They would afford Mort time to remove the Chaos interlopers.
    He hissed, threw his shield—caught the armoured warrior's leg and dropped him instantly. Didn't pay him any mind, dismissed him as a threat for the handful of seconds it would take for the warrior to pick himself back up.
    Met the nearest of the marauder types with his shoulder in a move that wouldn't have looked out of place upon a blood bowl pitch. His spear arced around, smashed into the cheek of another marauder.
    The shoulder-checked marauder gagged, blood dribbling from chapped lips. The impact had driven cracked ribs into his lungs, leaving him gasping and broken.
    No sympathy spared. Mort grabbed the man by the neck, lifted, turned, and hurled him into the armoured warrior—knocking the brute down again just as he reached one knee.
    The marauder struck by Mort's spear reeled, jaw shattered. It might've been luck—if Mort hadn't been busy shoulder-barging the other, that blow would've crushed his skull. But luck only delayed the death still coming. Mort dismissed him. The pain would buy a few seconds—just long enough to deal with the last marauder still on his feet.
    Must have had some flicker of intelligence—the marauder stopped short, watching all three of his comrades dropped in seconds. His face twisted, fear creeping in as it dawned what he had just put himself in the sights of.
    Too late for that marauder to take back his choices though.
    Mort raised his arm in a familiar gesture, felt the gemstone on his bracer react, calling to his aspis, which answered to the call and spun through the air back to its owner. The marauder in its path was irrelevant.
    The round shield clipped the marauder as it passed him, struck him in the ribs with force enough to stagger. Mort surged forward, arm raised to meet the aspis mid-flight. It snapped into place on his bracer with practiced ease. The spear punched through the marauder's chest—clean, efficient, final.
    He turned back to the champion just in time to swat another axe from the air with his shield. Then his gaze cut to the armoured warrior, who was once more rising from the muck—white armour now streaked and sodden with mud. Ripped the spear free of the marauder's chest, swung it around, levelled it at the warrior. Cast a quick glance at the champion, took note of where he was and how much of a threat he would be in the coming seconds. One of the saurus who had tried to attack from behind was dead, head laid some distance from the rest of his body. The other was injured, blood dribbling down his leg, but still fighting.
    Time enough for Mort to quickly kill the interlopers.
    Bent his knees, tensed, then lunged forward, charged the armoured warrior. Lifted his shield, slammed it forward. The warrior panicked, swung his axe wildly, but the strike was cast aside. Mort didn't stop though, continued his charge, slammed himself against the warrior and sent him sprawling yet again.
    Kicked the hand holding the axe, disarmed the warrior. Pressed a foot against the armoured figure's chest, pressed him into the mud. Hissed irritably and adjusted the grip on his spear, angled it for the neck and stabbed. Ignored the sound of the warrior choking to death on his own blood, cast his eye to the last of the four interlopers.
    The marauder stumbled back, eyes wide with a mix of pain and panic, but seemed to pull at some pool of courage—or just feckless fancy to go down fighting. Charged at Mort with chipped and jagged axes swinging wildly.
    Mort blocked the first axe with his shield and shoved forward, swinging his spear around to hook it beneath the crescent blade of the second. He twisted at the elbow, wrenching the spear around and dragging the marauder's hand with it as the man stubbornly held on. Left the marauder open, exposed.
    Mort lunged, his jaw clamped down on the warrior's throat, teeth puncturing soft flesh and weak muscle. He jerked his head—once, then again—ripping flesh loose with each savage shake. Flesh was torn free, blood spraying from the mutilated neck. The marauder fell, if not dead then damned to soon be.
    Swallowed the lump of flesh, then cast his attention back to the champion—just in time to see the second saurus split in two by a brutal blow. Another saurus approached, clad in the familiar breastplate of Mort's regiment—but a single look from Mort made him hesitate, slowing his advance.
    The champion heaved a breath, shoulders briefly lifting with the inhale, before lowering, the good shoulder rolling in the socket while the injured one simply sagged low. Axes were lifted into the readied stance, legs tensed. Mort reacted to the charge before the champion had even taken the first step.
    Block. Parry. Backstep. Block. Block.
    Perhaps the champion was simply tired of the fight. Or maybe Mort's survival had driven him into a deeper frenzy. Either way he attacked with renewed fervour, axes swinging rapidly, arcing through the air in blurred motion that any lesser fighter would have been incapable of fending off.
    Block. Parry. Parry. Backstep.
    Mort wasn't a lesser fighter. What wasn't blocked with his shield, his spear batted aside.
    Duck. Thrust. Swing. Backstep.
    The berserker fury left little room to counter. Every strike had to be weighed, each risk judged. Lunge now? With an axe screaming for his head?
    Duck. Parry. Riposte.
    But the longer this champion worked himself up and tried so hard to strike at Mort, the quicker he should be tiring himself out. If it was possible for him to be tired out.
    Backstep. Parry. Riposte.
    But there was another weakness to exploit from this berserker assault. His attention was hyper-focused. To this champion, Mort was all that seemed to exist.
    Duck. Swing. Pivot and tail whip.
    The champion stumbled, a red welt rising on his stomach. It wasn't enough—Mort's follow-up spear-thrust was batted aside with a growl more bestial than anything his kin had ever made. The champion shifted his stance, then proved Mort's earlier observation false. He spun on one heel—axes whipping outward in a brutal arc. One slammed into the saurus's chest, shrieking against the breastplate. The second carved deep into his arm.
    The saurus hissed, dropped his halberd, and staggered back—clutching at his limp arm as crimson streaked across his cobalt scales.
    The champion wasn't given time to finish the injured saurus. Mort lunged forward with a snarl, drawing the warrior's attention back toward him.
    Swing. Stab. Block. Block. Block.
    Kick.
    Again the champion stumbled, and as before, it wasn't enough of an opening to run him through. But this time, the saurus behind him, despite being injured, lunged at him, taking advantage of the stumble and how it put the champion just that little bit closer. The champion sensed the strike and began to turn—but Mort's spear forced him to stay put.
    A blood-stained hand gripped at the broken spearhead in the champion's shoulder and pulled. Not to remove the sharp object in the champion's flesh. But upward, and from behind, so that the hooked barb pulled and tore and dug itself deeper into the champion's muscle.
    The champion roared in a guttural mix of pain and fury, lost his footing as the hooked spearhead was yanked and tugged at. Fell to the mud-sodden ground with nothing that could be mistaken for grace. Yet even now, with the saurus dragging him like a hooked fish, the champion fought. He swung the axe in his good hand, lashing out blindly to keep Mort at bay.
    'Bastards,' the champion spat at them, the first word Mort had heard him utter.
    Around them, saurus and skinks approached, halberds and spears, sabres and bayonets levelled at the struggling champion. No fear from the champion despite the obvious conclusion he must surely have reached. Despite the pull against his injured arm, he still managed to throw the axe—maybe acknowledged that it wasn't going to get any use in his current position and gave a single spiteful hurl. One of the nearing saurus fell, head split from the axe's passage.
    A skink lunged while the champion's arm was still outstretched, sabre slashing down. The blade struck just past the elbow—messy, angled—splintering bone beneath muscle with a jarring crack. He howled again—rage and pain blending—as he swung with his remaining arm, crushing the skink who'd crippled him. The sabre still jutted from his ruined limb. He flinched as a musket cracked. A fist-sized chunk of his breast tore away in a spray of blood and meat.
    Still screaming, mangled and soaked in blood, the champion planted his feet. He rose—despite the barbed spear still tugging at his flesh. He took a step. Dragged himself forward. A grotesque tug-of-war, won by sheer hate.
    'I'll… rip… and crush… you… filthy lizards!' he continued to snarl. Mort wondered if, beneath the skull, foam was frothing from his mouth with how much hatred he poured into every word.
    'How is he still standing?' Mort heard one of the saurus ask.
    Clearly, this was not going to end. Not until the champion stopped breathing. Mort lunged, thrust his spear, aimed for a felling blow.
    Then the buzzing came—first a whisper, then a tide. Flies. Locusts. Crawling filth. The swarm surged up, thick as a wall. Mort's spear struck nothing but air.
    A voice followed, dry and mocking: 'You put up quite the fight. But I cannot allow you this kill.'
    Mort raised his shield, instinctively bracing at the sound of the voice. The saurus who had been pulling at the champion hissed in startled shock, frantically brushing at his body, swatting at the insects crawling over his scales. The swarm parted, revealing an older man. Stringy hair, skin pocked with boils—yet clad in silk robes, absurdly pristine amid the filth. Mort recognised him, vaguely, as one of the other champions who had been present at the Feyerabend Keep.
    The old man didn't look concerned at the weapons levelled his way. His lips stretched into a mocking sneer. He placed a hand on the champion's shoulder. The buzzing swelled again—louder, denser—as the swarm surged up once more. When it cleared, they were gone.
    Mort bared his teeth, fury rising—then crushed it down, shoving the emotion into that familiar mental lockbox. It would wait. Instead, he needed to focus on what was important. There was still a battle ongoing.
    He turned, looked to the Chaos warriors who had been pushing against the defensive lines. And blinked as it became clear that their morale had shattered with the defeat and disappearance of the champion. It wasn't an ordered retreat. They broke and ran, leaving only daemons and beasts too stupid to flee.
    Inhaled. Exhaled. Looked to the saurus and skinks around him.
    'Keep an eye open for that sorcerer,' he said, voice low.
    With no threats nearby, he allowed himself a brief breath—and looked beyond the broken Chaos ranks. His eyes narrowed. The grove nearby burned—flames climbing skyward, painting the sky in shades of orange.
    Didn't ask himself what he had missed. He could already guess.
    Let out another deep breath. Then his gaze shifted—searching for the youngest of the Legion's majors. Spotted young Boney—the skink was gesturing down the hill toward the farmhouse.
    Curious, Mort stalked toward Boney. Mort could have taken command of the entire front. He had seniority over Boney—by age, and by status.
    But he wasn't interested in usurping command. No, he wanted to see the younger major able to stand tall on his own merit. So, Mort would hear what Boney was considering as their next move now that the enemy's push against their front had been broken.
    The moment Boney spotted Mort, it showed. A momentary hesitation; his eye widened a fraction, breath caught in his throat—then gone. Back to normal.
    'What's the plan, major?' Mort asked, tone blank, hiding away the flash of concern at his continued reaction toward saurus.
    Boney raised one bare arm—bloodied enough that the priestly tattoos inked into his scales were all but hidden—and gestured toward the farmhouse down the hill.
    'Artillery has run out of ammunition. With the push on this hill broken, I think we ought to relieve the pressure on the farm.'
    'And what if another wave decides to circle and take advantage of our absence?'
    Boney gestured toward another skink, standing at a respectful distance, hands clasped behind his back, awaiting orders. 'If they're trying to flank the Marshal they'll be disappointed; he's relocated. I was just told that Ingwel's reinforcing the eastern hill.'
    Mort blinked, then gazed toward that central hill. True to Boney's words, the Legion forces on that hill were no longer there.
    'Why…?' he trailed off, didn't fully word the question in his mind.
    Boney let out a breath, then handed Mort a spyglass. 'If I had to guess, it's because the bulk of the warhost have decided to make a push.'
    Mort raised the spyglass and scanned the battlefield. The Warhost was on the move—most of them heading for the eastern hill.
    Boney continued, tone contemplative. 'They have no way of knowing our artillery has run out of shot, and we have been holding off an attack led by that champion—is he dead by the way?—whereas our eastern line was pushed back. And with the grove burning? East or west, they picked east.'
    'He got away,' Mort answered the question blandly, simplifying the event rather than go into detail. 'So, you want us to relieve the farm and push back the last of the attackers on this side?'
    'After that, we reassess. Flank the Warhost… or hold position.' Boney shrugged.
    Mort turned to the other skink. Likely a runner. 'Any other news?'
    'Our fliers have noticed banners to the east, coming this way,' the skink answered.
    'Banners? Whose? The White Wolves?'
    'None we recognise.' The skink shook his head. 'Ingwel has no way of knowing if they are friend or foe.'
    'Which I would imagine is another reason Ingwel moved east.' Boney mused softly.
    Mort huffed out a breath in silent agreement. 'Very well. What formation would you have us march on the farmhouse?'
    Boney paused, a flicker of surprise crossing his eyes, and then he steadied his posture.
    'While we still have the hill to our advantage, your saurus lead with muskets behind. Once on level ground, staggered formations so that the guns have lines of fire.'
    Mort rumbled in acknowledgement. 'Very well. You have command.'
    Boney turned, already shouting orders, posture tighter now, voice steadier.
    Mort watched him go. Didn't speak. Didn't need to.
    He adjusted the grip on his spear and followed.
  4. J.Logan
    Battle on the Mud - Marched Resolve
    Northern Middenland
    Skaros watched, mind racing. Thick black smoke billowed from the grove, the sweet scent of perfume curdling into bitterness. Cannon barrages had ignited foul-smelling pitch, and the flames now roamed unchecked, veiling the central hill.
    Patience would have him sit by. Wait for the flames to die down. Wait for an unobstructed view of the threat held in reserve. And then choose: to charge the centre line, through charcoal, soot, and burnt carcasses. Or charge for the flanks, to reinforce and take the fight's climax to the place of his choosing. Patience would have him wait for the right moment in which he could apply pressure at the right spot, that surgical slip the knife into the chink in the foe's defence.
    But five hours of watching as his forces were held at bay. Five hours of feeling a sting of second-hand humiliation, while waves of his troops clashed and clashed and clashed. Yet, after five hours, all he had to show for it was a slight advance on the eastern front. An advance which then was quickly curbed once reserves had bolstered the fleeing lizards and Empiremen, and they planted themselves on that hill and once more, held their ground. Made a mockery of Skaros's warhost.
    Even the western hill, the angle that Skaros had predicted would fall first, they held. The Everwrath clashed with a warrior, and where normal expectation was that the Everwrath would carve through them as he had so many heroes and champions in the past, this one lizard held and held and held. Fatesaw had been sent to twist the fight around the Everwrath in the Warhost's favour. For a while, Skaros saw the flicker of her blue flames in the distance—faint, like sparks glimpsed through smoke. Then, they vanished. Ceased to appear.
    Patience would have him sit, wait for that moment where the gap would be revealed, the weakness that could be exposed.
    Five hours. That's how long he'd sat. Watching. Tolerating the mockery of resistance. That was patience.
    This was its death.
    He did not wait for the flames to die. He turned, called for those in earshot. He barked the order, voice hoarse with fury. His bellow scattered the nearest, who sprinted to relay the command. In short order, the reserve of the Warhost of Malice turned and marched for the chosen front. A hammer to knock down the resistance at Skaros's chosen point.
    Overrun the point he had chosen, and then he could refocus his attention.
    Collapse the flank, then roll along the line before the reptiles can reorganise, he mused privately.
    Ingwel scowled, buried his worry beneath the cold reptilian logic that came so easily for his race. The same ease that gave rise to the image that the Children of the Gods held no emotion beneath their scales and their less expressive features.
    But that was a lie. They felt emotion, they had feelings. Those emotions might be tempered by the cold, hard logic and the awareness of the Great Plan. Emotions that ran cold in comparison to the warmbloods who felt so keenly as to be a blazing inferno in comparison.
    But Ingwel would never claim to be emotionless. He worried. He worried about those who lived and died by his word. He worried whether he was doing right by them. He worried for his brother.
    It was that last one that flared up in his mind at that moment. It was irrational, and he knew it.
    But five centuries among the warmbloods had taught him to mimic their fire. Exaggerated tones, deliberate gestures—an almost pantomime of emotion. All so they might catch a glimpse of what lay beneath his rigid features.
    Sometimes, he wondered if he'd faked it so well that it had become real.
    Worry for his brother? That was nothing new. Ever since they had spawned, despite being the younger, Ingwel had worried for him, worried for his misfit brother who had a naturally keen grasp of emotion and felt every rejection from the conservative elements of Madrigal.
    But where once he could bury that worry with ease, he now stared at the growing inferno, and it took effort to shove that worry down, to remember that letting his worry take centre stage would not serve anybody any benefit.
    The mental argument he had with his own feelings was brief. A handful of seconds. A human might feel aghast at how quickly he had managed that fight. But Ingwel was still, and always would be, a saurus. The more orthodox of his kin might frown in disapproval, but Ingwel was not about to let them dictate how he should feel, not so long as he never let it dictate his actions.
    So, while the grove turned to an inferno, Ingwel swallowed once, mentally asked Quetzl and Xa'litza both to look over his spawn-brother, and then turned away and returned to the matter at hand. It wasn't unreasonable to assume that the Old Ones were watching, enough of the troops who had been stationed in the grove had withdrawn within moments of sending up the flare that was signal to the need to burn away the haven of trees and deny it the enemy.
    With the smoke rising, his view of the Chaos warriors was dulled. But fortune smiled upon him, for he wasn't completely blind. The Warhost's line stretched far enough that Ingwel could still see the flanks, even through the smoke. He doubted the warlord had the same luxury—his view of Ingwel's position would be choked.
    And Ingwel had another tool to his advantage when it came to observing the movements of the enemy. It was this fortune that allowed Ingwel to see their reaction to the inferno between them.
    As if summoned by his thought about the tools Ingwel had to his advantage, a terrodon swooped down from the sky. The avian creature landed, blunting the momentum of its abrupt landing with a slight waddle, while the rider patted its neck, hissing out praise for a good job.
    'What news?' Ingwel asked after a moment.
    The rider looked at Ingwel, amber eyes wide. 'There is a force approaching from the east.'
    'A force? Who? The White Wolves?'
    But the skink was already shaking his head. 'Not the Wolves, unless they've changed their standards and colours. I don't think the standards were Empire.'
    'Describe them,' Ingwel ordered, eyes narrowing.
    The skink hurriedly described the standards that he had been able to spy from the distance between them. Ingwel's brow-ridges rose slightly, and he let out a bemused breath.
    'I see…' He paused for a moment, considering. His mind raced in consideration for how events may play out based on what was described. 'The east, you said?'
    The skink rider nodded. 'Given time, it looks like they'll be arriving at Captain Yen's flank.'
    Ingwel let out a thoughtful hum, then glanced down at the Chaos warhost, took note of the sides of the columns and direction they were starting to turn.
    'Well, that settles it. Back to the air—watch them. Report any change.'
    The skink nodded once, and clicked his tongue, which had the terrodon waddle a short distance before then taking flight once again. Ingwel watched the majestic creature fly for a heartbeat, then turned to a nearby skink.
    'I need you to ride to Major Boney's position, pass on a message to him. Tell him that I'm taking the central reserves in their entirety and reinforcing the eastern hill.'
    The skink messenger trilled out an acknowledgement and mounted an aggradon, a younger one not yet trained for combat, so instead used for message running. Ingwel could have tasked the terradon rider with the message, but the approach of an unknown force warranted having an eye on the situation.
    Once the skink had ridden away, Ingwel let out a long breath, which escaped with a low hissing sound and an unconscious flick of his tongue. Inhaled, then turned to the regiments nearby and started barking orders, readying them for the relocation.
    They were going to be going all in.
    Mud splattered 'neath armoured footfalls.
    The chaff had charged. Numbers of warriors in armour had struck. But what still remained, what now marched forth with Skaros, they were the true might of the Warhost of Malice. Not mere warriors, but those who had truly earned their place.
    Skaros picked up his pace, moved to the head of the formation, took his place at the front, to lead the warriors. Leader first, warrior second—but today, the order didn't matter. It was a requirement; Chaos, no matter which god one served under, no matter how unified a warhost might be in theory, demanded that the champions constantly prove their position. Lead from the rear, lose the host.
    When multiple fronts required oversight, distance was forgiven. There, it was understood that leading required he be in a position to actually make the right judgements. But once a battle reached a certain crescendo, it was expected that the leading warlord or champion would oversee the battle personally. Get their hands dirty and prove that they belong.
    After five long gruelling hours and the humiliation of what had initially seemed an almost amusing distraction had reached that point where if Skaros was not at the front, leading by example, he forfeited respect. This wasn't a nuisance that was beneath him.
    His hand briefly brushed against the stone he carried, felt the faint warmth it projected.
    Let it feast. Let the day be bitter and bloody. At least the stone will remember.
    At least, if naught else, it would be feasting on the blood spilt, the lives cut down. That alone reassured Skaros that the humiliation of this battle would be worth it.
    Mind briefly flickered to the first time he had led an attack from the front. The exhilaration of the moment. The rush that hit him. The high unlike any other.
    With crimson cloak billowing behind him, he advanced. Led his host of blades and killers, those who Malice had smiled on in the past, had already started the journey toward becoming chosen.
    No mere hopefuls, no acolytes hoping to have Malice gaze upon them.
    Not Chosen, not yet, but on that path. Maybe this was the battle that would elevate some to that venerated position.
    His hand drifted to the pommel of Nexsting, but he did not draw it. Not yet. The barbed weapon, shaped in the manner of a hornet's stinger, was not to be unsheathed until its power was needed. Not a moment sooner.
    The daemon bound within was fickle—hateful, ravenous. It hungered for death the way the damned crave absolution: endlessly, blindly, without pause.
    Skaros may not be burdened with sentimentality for those who served 'neath him, but he would not see them die to a daemon's spiteful impatience.
    The pommel vibrated, as though the bound daemon sensed what was to come, and was eager. Ready. But still the blade was not pulled free, for Skaros knew all too well that the impatience would show itself.
    The formation shifted behind him, a purposeful reordering. Armoured warriors moved to the rear, making way for those deemed worthy to march at the fore. These ones were clad in hellforged armour. Real hellforged armour.
    Many mistook the distinctive plate worn by Chaos warriors for hellforged armour. In truth, most bore only crude imitations—twisted steel shaped in Chaos fashion, but lacking the infernal essence. True hellforged armour was rare—most bore only crude mimicry. Only the Chosen wore the real thing.
    Even the learned often mistook it—assuming that any grotesque suit of plate was hellforged. They were wrong.
    Skaros wore hellforged armour, stark white as a sign of his devotion to Malice. But there were few within the warhost who wore actual hellforged armour.
    Those who positioned themselves to his flank? His dedicated retinue. They were also clad in hellforged armour, white as bleached bone. Their loyalty had been long standing, their devotion to Malice long since rewarded. Not champions, but still chosen of Malice.
    Ahead lay the foe—reptilian things that had dared to strike at the warhost. They clung to the hill's incline, huddled into a defensive bastion. Saurian warriors formed a cruel perimeter while their gunners crouched behind, weapons primed, awaiting the order to fire.
    Admirable, in its way. But irrelevant.
    The moment they loosed their first cannon shot at the Sons of Malice, they sealed their fate. That they still lived was an embarrassment. That it required Skaros himself to end them—a personal insult.
    Five more strides forward.
    A ripple passed through the enemy ranks, tension quickening like blood in the veins. Skaros raised a hand.
    Thunder cracked. Smoke fouled the air. Gunfire roared from the hilltop—but Skaros did not slow. A hemisphere of crackling blue energy bloomed around him, each bullet slamming into its surface and flattening before dropping, inert, into the mud.
    Another three strides, another volley of gunfire blocked by the the arcane barrier.
    Didn't protect those behind him. Such was the nature of Chaos, no coddling, no protecting others beyond the minimum requirement. And Skaros could shield himself, but his barrier was not wide enough to shield any other.
    He didn't look back. The dead were unworthy. Besides, he knew even without looking that the Chosen of Malice were fine. The casualties were all lesser warriors.
    Step. Step. Step.
    Another volley of gunfire. Maybe this volley was tinged with some measure of desperation. Maybe. Slightly more concerning than the volley of handguns though, were the creatures with carronades on their backs. Carronades which fired moments after that last volley.
    The guns fired not iron balls but clouds of shot—dozens, perhaps hundreds of pellets.
    Skaros felt his barrier shudder. Not falter, but strain.
    Interesting.
    He filed the knowledge away. The artillery of the southern lands had evolved. Fire and iron were no longer the only threats they presented. He would remember that.
    If it mattered.
    One last step and he was close enough. Nexsting was finally torn free from its sheath. The daemon pulsed with anticipation, the blade trembling. Skaros raised it high and forced his will into the writhing spirit bound within.
    The sky darkened. His blade came down in a chopping motion, and as if pulled down by the blade, the sky opened to allow a vivid bolt of energy, black yet with a blinding white core, to crash down among the reptile soldiers forming a defensive barrier.
    A crater formed. Blood steamed on shattered rock, and what little remained of the fallen was flung skyward—charred bone, flensed meat, and smoking scales, torn free and cast to the wind like refuse. All two-score of them.
    Beneath his helmet, his lip twitched. Once, the man he had been might have offered some dry, sardonic remark; dark humour bordering on the gallows. That man was long gone. But the memory lingered, a flicker of amusement sparking in the hollow where humanity had once lived. It was out of place now, alien against the monstrous shape he had become.
    He stepped forward. Raised his blade.
    Again, he imposed his will.
    Again, the heavens obeyed. An eldritch lance of Malice's fury tore down from the sky. The air screamed as it split, and all caught beneath it were unmade.
    Another three dozen, ripped from life in a heartbeat. All that remained were scorched flesh and bones charred black.
    The gunlines opened fire again, but their barrage was as pitiful as before. His barrier flared, unbroken; his armour remained untested.
    And with that, he charged.
    Sprinted forward, feet landing with surety, never once in question despite the slick sodden earth. A lizard swung at him—a billhook arcing for his side. Skaros batted it away and drove Nexsting into the creature's gut. The daemon within supped deeply, and before his eyes, the lizard withered, flesh collapsing inward as its life was consumed.
    Pulled his weapon free, turned and cleaved another's head from its shoulders. A third struck at him. Skaros slapped aside the stab of a billhook, his gauntlet clanking against the metal of the weapon. He didn't hesitate. He lunged forward and seized the creature's throat. He dragged it close, relishing the flash of fear in its scarlet eyes.
    Slowly, deliberately, he drove Nexsting through its breast. The daemon purred. Skaros watched the life fade from the creature's gaze, the crimson dulling as its soul was devoured.
    He dropped the withered carcass. Swung his hand around and backhanded another lizardman. While his forces clashed with the lizards' faltering lines, he scanned around, seeking one who was worth his time.
    Eyes locked onto a startled looking lizard. A larger lizard—Saurus, he reminded himself—clad in a uniform that, at a glance, matched the others. But there were subtle differences: a waistcoat made of cotton, not wool. A southern fabric. Costlier. Valued.
    Not a general, perhaps. But not a grunt either. Someone with weight. Someone worth the blade.
    Important enough.
    With a low grunt—almost a chuckle—Skaros took a step forward. His blade was raised, part challenge, part readiness. An unspoken invitation. The daemon within the blade purred in eager anticipation.
    The saurus tensed. Its eyes locked with his. Weighing its chances, perhaps.
    Skaros didn't give the saurus time to think about its options. He charged forward, Nexsting raised high in a brutal cleaving arc. The saurus reacted fast, backstepping just enough to avoid the blow. Steel rang as its sabre met Nexsting in a parry.
    Another step back. The sabre came up again, this time held firm. A proper stance. Ready now
    Both blades briefly tapped against each other, not a salute or a gesture of respect, but more a confirmation that they were both ready.
    A nearby explosion had Skaros rock back, eyes briefly leaving the saurus to determine the source of the disruption. Spotted one of the lizardmen fliers, watched as the smaller reptile riding it dropped a bomb which detonated moments later.
    The saurus tried to use his momentary distraction to its advantage, lunged forward with sabre aimed in a thrust that could be lethal if it met its mark. But Skaros's distraction wasn't all encompassing. Batted aside the sabre and kicked the saurus back, then returned his attention to the flying creature. Nexsting was swung in a downward chop.
    The creature didn't have a chance to give a death-cry as the bolt of energy struck it from the sky. All that remained of it and its rider was the blood that rained down on those below.
    Skaros continued to ignore the saurus he was supposed to be duelling, his eyes scanned the skies, took note that there were more of the flying creatures. Scowled in irritation.
    It appeared that he had no more furies in the air. Useless pests. Can't even do the one task I gave them…
    Absently parried another strike from the saurus, and finally turned his attention back to the large reptile. Felt a swell of disgust in his breast, re-catalogued this creature. Barely worth his time.
    Lunged, felt his blade be parried. Didn't stop his body from moving though. Slammed his helmet down on the saurus's face, then slammed his fist into its gut. The saurus staggered back, doubled over.
    It still had enough presence of mind, despite several heaving, gagging breaths, to dodge aside when Skaros lazily swung Nexsting in a move that would have decapitated the saurian.
    It still just reinforced that this was simply was not worth his attention. Pity. Where are the ones that have some skill to their names?
    He briefly considered toying with the saurus. Dismissed the thought almost as quickly.
    No. He was here to overwhelm this flank—not to play games. No wasted movements. No indulgence. This would end quickly.
    He raised his blade, adjusted his stance—
    —and cursed as a new sound tore through the air.
    It was high-pitched, keening, and didn't sound natural to Skaros. It built with terrible pressure, like the air itself was being drawn away from the hill upon which they fought.
    Skaros turned, tried to identify the source of the wailing sound. But on turning, he was met with a bright searing beam of light that speared through the air and into Skaros's warriors while they fought. Where it hit, armour evaporated. Flesh boiled and burst like overripe fruit.
    A dozen warriors were unmade in an instant, reduced to ash and shattered bone. The light wasn't just heat—it was purity, raw and unrelenting, scouring flesh and soul alike. It ripped away flesh with such violence it left nothing behind.
    Those nearby staggered, blinded and choking, skin blistering even at the fringes of the blast. Some fell to their knees, shrieking, gripping their heads as the light reached into their minds—alien and wrong.
    Skaros blinked furiously, mind racing. The light was like staring directly into the sun—but focused, sharpened, made cruel. He followed its path. Tracked the beam to its source.
    It was a black and yellow creature, large and clearly a predator. Skaros recalled what he knew of Lustria and the lizardmen of that distant shore—he was looking upon a carnosaur. And on its back was a small cannon. But this cannon's muzzle was not an opening through which shots would come, but instead seemed to end with a glowing quartz crystal, radiant and golden, blazing with power.
    The carnosaur reared back and it bellowed a roar that vibrated the air with primal fury. And that was when Skaros took note that mounted atop the carnosaur was another lizardman—another saurus. This one though was garbed in a rich blue greatcoat and white breeches, and carried a sabre, the blade tinted with a faint azure hue. And even from the distance between them, Skaros could feel the aura of command and steely resolve.
    So, we finally meet…
    The saurus dismounted with slow, deliberate grace, patting the carnosaur's ankle—casual, confident. Then he stepped forward, gaze locked on the line where Chaos clashed with cold-blooded discipline.
    And behind the saurus and the carnosaur, more. Another pair of carnosaurs, unburdened by weaponry. Then a line of horned, lumbering behemoths of scaled muscle and primal fury, wooden platforms in their backs, carrying a handful of the smaller lizardmen armed with handguns. And behind those thundering creatures, scores of lizardmen, advancing in tight formations, fanning out as though with intent to encircle and keep the Sons of Malice locked in place.
    Skaros narrowed his eyes, staring at the approaching force. They moved quicker than anticipated…
    He looked past them, seeking signs of more—reinforcements, a second wave. There was nothing. This was no vanguard, no tip of a spear. This was the spear.
    Still, it was no meagre force. But…
    I had them outnumbered from the start, Skaros realised with mounting fury. They were staying back and playing defensive because they would never have won if they had engaged in a direct confrontation. And I let them.
    I let them dictate the pace. I split my strength when I should've crushed them outright.
    The fury of the realisation swelled up, like a pressure pressing against his lungs. Then he exhaled and felt a measure of calmness return.
    Well played, my saurian foe. I had the cards, while you played an empty hand.
    A dry laugh escaped him. Not amused. Just… impressed, reluctantly.
    Even now, with the numbers against them, they struck with precision. From the rear. Forcing his warriors to fight on two fronts. Chaos warriors caught between their own momentum and a blade in their back.
    A desperate move, yes. But not without merit.
    A last stand. A final strike. Better, Skaros thought, than dying like cattle.
    Another guffaw left his lips unbidden. He turned fully, ignored the one he had previously intended to fight and kill in the name of Malice. He had a more worthy foe to take on.
    Besides, it appeared that in his distraction the lesser saurus had retreated somewhat. Recognised that he was outclassed, no doubt.
    The black and yellow carnosaur lowered its body again. The crystal on its back shrieked its unholy note, and the golden quartz flared with impossible brightness. Skaros averted his gaze just in time, shielding his eyes from the second blast of solar fury.
    Another beam lanced across the field. Another line of warriors reduced to smoke and cinders.
    The carnosaur roared again, then charged—earth-shaking to the thunder of its stride. It leapt, impossibly agile, and landed in the thick of the Sons of Malice, tearing into the Chaos ranks with primal rage.
    And behind it, the others followed.
    The other two carnosaurs surged into the fray like the tip of a blade puncturing armour—leading the path for the lower creatures, heads bowed to angle horns to lethal effect as they surged forward, bowling aside any unfortunate enough to be in their path, while the gunners fired away without a care.
    And then the infantry reached the line.
    Ingwel moved forwards, pace deliberate. He paused as a Chaos warrior—unlucky enough to be caught in Gila's jaws—was hurled aside. Bone cracked, armour buckled, and the body crumpled from the savage shake of her head.
    Gila was a good girl. Gila knew Chaos wasn't food. Chaos was filth. Chaos was threat. Not prey to be devoured—but predators to be killed, then discarded.
    Once certain he wasn't about to be bowled over by the flung corpse, Ingwel continued to advance. His sabre danced in his grip; a flick of the wrist sent it slicing cleanly through the air. Cleaved through any warrior that neared him, blade slicing through armour with unnatural ease.
    An axe came for him—he riposted, the motion fluid. Countered with a thrust through the gap in the warrior's visor. Paused. Assessed. Moved.
    Another threat, white armour that radiated unholy energy. A Chosen. But more concerning than the standard warrior of Chaos. But nothing Ingwel had never fought before.
    The Chosen twirled a blade shaped like an insect's stinger in a flourish, adjusting his stance—
    —only to change his mind as a green-and-brown carnosaur lunged past, snarling and full of teeth. Even a favoured of Malice had better things to do than challenge an angry thundersaur with a short temper.
    Ingwel considered pursuing him. But then, a flutter of crimson caught his eye.
    He paused.
    The armour was similar—bone white with dark edges—but it bore no iconography. No screaming skulls, no profane glyphs. No mark of the bisected skull that denoted Malice. And yet, that blankness made it all the more imposing. All the more deliberate.
    Even if Ingwel had not been observing from his spyglass throughout the battle, he had a feeling he would have recognised this warrior by the aura alone.
    'Warlord Skaros, I believe,' he spoke aloud.
    The warlord tilted his head. The visor left the face beneath shrouded in an impenetrable shadow, but Ingwel had the distinct feeling he was being scrutinised.
    'I do not know your name, warrior.' His voice was harsh, cracked stone over steel. 'Tell me, so I can remember the one who did so much… with so little.'
    Ingwel didn't answer immediately, tilted his head in a mirror of Skaros's own gesture.
    'Marshal Ingwel'tonl of the Outland Legion.'
    A long moment passed. Then Skaros gave a single nod. 'I hope you fight as well as you lead, marshal.'
    He shifted his stance. Blade raised. Balanced. Ready.
    Ingwel gave him two heartbeats. Then followed suit—lifting his sabre into a guarded stance, angling his body sideways, right arm forward, left tucked behind his back, held clear of any errant strike.
    The air between them thrummed with unspoken challenge.
    But when the two leaders adopted their stances, an invisible line seemed to be drawn. The battle didn't stop, but the chaos bent around them, unconsciously acknowledging what was about to happen. No one stepped too close.
    Ingwel breathed in deeply—and with that breath, set aside the habits and concerns of a marshal. He locked them away. All that remained once he finished his inhale, was the warrior spawned under the blessing of Xa'litza. The weapon of choice might have been a traditional pick for a Child of the Gods, but he was a saurus first and foremost, and a saurus with a weapon, was a weapon.
    Skaros must have recognised that something had shifted within Ingwel. He lunged forward, blade cleaving from left to right. Ingwel's sabre snapped up—wrist flicking, blade angling beneath the strike—and redirected the barbed edge skyward. He surged forward, wrist turning again in a blur of motion.
    Skaros blocked it, bringing up his off-hand. The back of his gauntlet caught the blow, steel ringing as it forced the sabre away. He backpedalled, helmet tilting as his gaze flicked to the gauntlet.
    There, etched across the metal, was a shallow but clean scar. It hadn't been there moments before.
    A grunt escaped him—acknowledgement, not pain. He lowered the hand and reset his stance, refocusing.
    Ingwel hissed low, tongue flicking the air.
    Skaros lunged, impatience betrayed by the tension in his shoulders, the heavy stamp of his foot. Ingwel stepped back, parried, noting how Skaros adjusted mid-stride to recover his footing and pressed forward again. Ingwel stepped back and parried. The warlord adjusted, striking again, which Ingwel sidestepped rather than block.
    He countered, striking at the opening Skaros had overcommitted to. But the Chaos warlord was faster than he looked—he twisted, bringing his blade around. The barbs of the blade caught Ingwel's sabre and locked it fast.
    Skaros hadn't accounted for the saurus's foot crashing into his knee. He staggered at the blow. Didn't fall though.
    Ingwel used the moment to shift his stance, twisted free of the blade trap, and lashed out. Another strike.
    Blocked again when Skaros raised his off-hand, letting the sabre glance off his gauntlet with unshaken confidence. Not instinctive. Not reflex. Calculated.
    Later, Ingwel would muse about how rare it was for humans to have such comfort. Even in full plate, they usually flinched—even the lifelong warriors. Blocking with a gauntlet wasn't unheard of, but it was desperation—last resort, not considered defence.
    But not Skaros. This one had clearly learned long ago that armour wasn't just protection. It was a weapon, too.
    And, inconveniently, the armour was good enough that it was blocking Ingwel's sabre. Had it been one of his kin's blades, that detail might have been expected. But his sabre? That was different.
    The blade was a gift—from a Dawi runesmith. A mark of gratitude, offered in return for a great favour performed by the Legion. That runesmith had only ever gifted two blades to the Outland Legion. This was one of them.
    True, it wasn't the other blade. Ingwel's sabre was a leader's weapon, not a frontline's. But still: gromril-forged. Rune-carved. Dawi-crafted.
    And Skaros's armour was withstanding it.
    Ingwel flicked his tongue, tasting the air. Blood. Mud. Death.
    He adjusted his footing, lowering the sabre into a different guard. It had been some time since he'd faced an opponent who forced him to work around limitations.
    In his mind's eye, he mapped the weaknesses in the warlord's armour. Gorget gap. Shoulder overhang. Wrist seam. He also noted the counters. Flared winged plates at the knees, designed to shield against side-swings. The slight overhang at the shoulder, meant to catch angled strikes before they could slip beneath.
    Skaros's armour was a fortress. But not without cracks.
    Well, how convenient for me that my weapon is one of precision!
    Leaned back, avoided a downward chop. Flick of the wrist and the sabre snapped forward, aimed straight for the seam at Skaros's wrist.
    The Chaos warlord reacted fast, pulling his hand back sharply and dropping into a guarded stance once more.
    And that more than anything else is why you are dangerous.
    You know and acknowledge your own weak points.
    You don't pretend they don't exist.
    "Skaros straightened, blade raised, pausing as he seemingly assessed Ingwel's stance. Then he lunged, swiped his blade left-to-right. Ingwel retreated from the next swing, then caught another with a sharp deflection. Ingwel's eyes narrowed. He felt the ground vibrating. His tail coiled, his grip on his sabre tightened, then relaxed again as his mind raced.
    A heartbeat later, he blocked another strike, then stepped forward and twisted, keeping their blades in the bind and held away from him. He swung his tail around, releasing the tension built up from its coil. The thick appendage met Skaros's hip, with enough force that anybody else would have been knocked prone. Skaros's only reaction was a slight stumble, then an attempted retaliatory slash.
    Unfortunately—for Skaros—Ingwel was first and foremost a saurus of Madrigal. And saurus, no matter their personal strength, did not fight alone.
    Skaros's retaliation was cut short—he realised too late he'd been manoeuvred. Ingwel backpedalled, and watched as the stegadon he had noticed charging their way bowled over Skaros.
    Skaros vanished beneath the stegadon's bulk. But Ingwel knew, instinctively perhaps, that it wouldn't be the death blow. He was proven right in short order, when the stegadon slowed, its flesh shrivelling and seemingly aging rapidly, before eventually withering away, bones turned to dust.
    Ingwel watched, momentarily frozen, as the flesh withered from the stegadon's bones in an instant. That dread weapon was more than just steel.
    The five skinks who had been riding in the howdah fell to the ground as their mount decomposed beneath them. They hurriedly tried to pick themselves up, but Skaros erupted from the brittle mummified remains of the stegadon, and cleaved his blade through the air, tearing the nearest skink in two. The second skink unfortunate enough to be closest to the Chaos warlord pivoted around, hissing in startled shock, but before the musket could be raised, Skaros's blade punched through his skull—then tore back out, barbs dragging chunks of bone and brain alike.
    Ingwel surged forward. Too late to save the third skink, who was booted back with such force that his chest was clearly caved in. He did manage to save skinks four and five however. Or so he thought. Blocked the chop that would have killed the fourth skink, directed the foul blade aside. Skaros blocked Ingwel's sabre with his off-hand, then turned his blade on the furthest of the two skinks.
    A dark bolt of energy flew from the blade, striking the musketeer with a loud crack. In the blink of an eye, all that remained was gore, painting the spot where he had stood.
    It wasn't quite the same level of devastation that the bolts raining from the heavens had given, smaller and more directed as it had been. But there was no arguing effect on the one touched by it.
    Ingwel exhaled, fought down the snarl of fury that wanted to rise up. Tensed as the warlord, clearly so very done with the fight, turned back toward Ingwel, and the skink behind him, and held the blade in the same position as he had before the swing which had fired off that eldritch blast. Ingwel's eyes drifted to his sabre, to the Dawi runes artfully crafted into the blade. Considered his options. The first that came to mind, he dismissed it as anything other than a desperation move, rather than the basis of a plan.
    Instead, Ingwel lunged forward. Hoped that the slicing motion was a required component to flinging those bolts. Skaros started to move the blade, the same motion as before. But Ingwel was faster than his size would have many believe. His sabre intercepted the foul blade, pushed against its movement, even while Ingwel continued his body's momentum, slammed shoulder first into the warlord, sent both falling into the muddy ground.
    He twisted, snarling. His sabre hacked—not to kill, but to break focus. Distraction was survival. Nothing like having a blade slamming against you to distract you to pull your attention away.
    Ingwel planted one hand in the mud, rolled smoothly upright. The filth clung to him, but his gaze was fixed—Skaros was rising. But for a handful of seconds, still vulnerable.
    Wasn't given the opportunity to take that opening. Another Chaos warrior appeared, clad in the white plate that marked him as a Chosen. The newcomer charged at Ingwel with a twisted and foul glaive that seemed to drain the colour of the world about it. Ingwel twisted, pirouetting past the sweeping polearm, and slashed at the warrior as he passed.
    Fought down the irritated snarl when the blade left a scratch on the armour, but failed to penetrate. While it did better than it had against Skaros's armour, it was still a mark of just how potent a defence the elevated patrons of Chaos were gifted.
    Precious seconds lost—time that could have been spent finishing Skaros, stolen by this intruder.
    The warrior twirled the glaive and lunged at Ingwel again. Side-stepped. Blinked in a small moment of startlement as a gunshot echoed, that last skink musketeer from the now dead stegadon making his continued survival felt with a gunshot that made the Chaos warrior stumble. It didn't fell him, but it was distraction enough.
    Ingwel darted forward, batted aside the glaive, and seized the warrior with his free hand. He yanked him off-balance and vulnerable to the thrust of the sabre. The blade punched through chainmail, deep into the lung. The warrior gagged, blood frothing in his throat..
    But it cost time, time that Skaros used. He was on his feet, blade already swinging. Ingwel did not think, he simply reacted, twisting his body while still gripping the choking Chaos warrior. Hurled the dying warrior toward Skaros at the same instant that the bolt shot forth from the blade.
    Ingwel flinched as the sudden wave of blood splashed across him, thick and hot. He didn't dwell on it. He lunged.
    Skaros cursed aloud. Blocked the strike. Staggered. Regained his footing—
    —and came for Ingwel like death reborn.
    thedarkfourth likes this.
  5. J.Logan
    J.Logan Well-Known Member
    Battle on the Mud - Combat's Conclusion
    Northern Middenland
    Battle Duration: 6 hours
    Preda panted hard, lungs burning as he eased his aggradon clear of the melee. He signalled his formation to pull back too, for a needed lull to draw breath before the next charge. Beneath him, the aggradon's snarl rasped into a laboured hiss, its stride faltering from its usual snappy tempo. Even a beast bred for war could only run so long before its muscles gave out.
    He absently patted his mount's neck and hissed out a few words of encouragement. The raptor tossed its head back, a golden eye meeting his own for a moment. His muscles ached, hours of fighting, riding astride a raptor, sabre swinging.
    Unbidden, his mind recalled how there had once been talk of arming aggradon cavalry with lances. With all the shifts and adaptations the Legion had made, the adoptions of warmblood weapons and tactics, why wouldn't the humble lance be considered. Considered and then dismissed.
    Lances would not work with aggradons as the mount of choice. The movement of the raptors was not prone to smoothness, couching a lance would not work with the constant bobbing, while the rider would also be forced to angle lance so low as to be uncomfortable.
    No, the sabre was the weapon of choice for those who rode aggradons. These cavalry were less about the shock of an initial charge, more about the grind of close-quarters slaughter that followed. Unlike a horse, an aggradon fought with teeth and claws, rending a bloody path through enemy ranks. Put a blade in its rider's hand, and the raptor became even deadlier.
    Spears also had their uses; for reach, for punching through armour, and still let a rider add to the frenzy of snapping jaws and tearing claws.
    But for all the differences, even aggradon cavalry needed to pull back, draw breath, circle wide and strike again. They might not couch lances like the horse based cavalry of the humans, but they were a lance all the same. They were a living blade driven deep into the enemy's flank, tearing them open from within.
    From his position outside of the melee, catching his breath, Preda could judge where next to direct the fury of the aggradons. But more than that, he was able to survey and gauge the battle.
    It was… not looking good.
    The Legion was fighting tooth and claw. This was their purpose, the enemy here was the enemy, the Ruinous Powers. The Warhost of Malice: countless thralls driven by the will of a lesser god of Chaos, perhaps, but Chaos all the same.
    Righteous fury and divine purpose could only carry them so far. For every saurus, skink, or kroxigor who tore down a dozen thralls, a dozen more pressed in with blades and shrieks of blasphemy. Numbers would tell in the end, if nothing changed.
    Marshal Ingwel had driven the Legion straight into the heart of the warhost. Preda could see that despite the Legion fanning out to draw as many Chaos warriors into the fight as possible, there was no encirclement. It simply could not be done.
    Victory, should it come, would not be the erasure of the warhost. The warriors of Malice could rout, and there was nothing that could be done to prevent them from fleeing into the hills. Neither Preda, nor any other cavalry, had the energy to run them all down.
    But that was getting ahead of himself. Victory still wasn't certain. Quite the opposite. Still, this was a battle worth fighting. To cut down as many Chaos worshippers and thrall warriors as was possible.
    Inhaled, drew in what energy he could from the air. Exhaled, removed any notion of entertaining his exhaustion. He then scanned for the next fracture point, that spot where a charge of aggradons could best shatter morale.
    A piercing squawk cut through the clamour, dragging Preda's gaze skyward. Overhead, a terradon wheeled low, its leathery wings thrashing the air. The skink perched on its back leaned dangerously far, shouting down to be heard.
    'Captain,' the skink called down. 'We have reinforcements coming!'
    Preda paused, mind racing. 'I thought the Middenland army was not coming!' he yelled back.
    For a moment, he recalled the Knights of the White Wolf, supposedly delayed from their arrival due to linking up with another force. He wondered for a moment if this was their arrival.
    The skink shook his head, the feathers lining his head swaying at the movement. 'They aren't Middenlanders!'
    The need for knowledge briefly rose up, questions that were begging to be voiced. He already had the truth that mattered: maybe this battle would not be their grave. Only one thing left to ask.
    'How soon until they get here?'
    The skink cocked his head, eyes turned to look to the distance over the hill, a view Preda envied bitterly, stuck on the ground while the scout rode the wind.
    'Before the hour is up, at the latest.'
    Preda released another breath. He turned that knowledge in his head, weighed it, and locked it down. One hour. They could hold for an hour.
    They were Children of the Gods. They would fight until the last scale fell. And it would take more than an hour to butcher them all.
    'But…' the skink hissed.
    Preda quickly swallowed down a sense of concern that came about from that one word. "But", the word that was often a prelude to news most ill.
    'But what?' he asked the skink, feeling the eyes of his cavalry on him.
    The skink didn't answer. Not with words. He lifted a clawed finger towards the hilltop. Preda turned, tracing the line of that gesture. At first, there was nothing, no sight worth pointing to. Then, moments later, a lone human astride a great horse, cresting the ridge. More riders fanned out behind him, armour bright in the shifting light. A low horn bellowed, a rallying call that rolled over the battlefield like thunder.
    Finally, the skink rider spoke up. 'They sent a vanguard.'
    At the crest, the Knights of the White Wolf assembled around their leader, a giant of a knight draped in the pelt of a white wolf. A horn rang out, echoing across the bloody ground below.
    Preda watched as the knights lowered their hammers and thundered down the hill, howling their battle cry to Ulric and to the slaughter waiting at the base.
    Preda's eyes narrowed into a sharp and hungry grin. He turned in the saddle, voice cracking like a whip. 'Cohort, with me! We will not let these warmbloods do all the work!'
    He tapped his heels to his aggradon's flanks, feeling muscle coil beneath scale. Then they surged forward—claws tearing mud, snarls splitting the din—joining the avalanche of hammer and steel.
    The clang of steel on steel vibrated the air. Though neither weapon was steel in actuality, the sound was the same regardless.
    Ingwel stepped back, left the reach of the swing of the warlord's blade. Once the barbed blade passed him by, he lunged. His foot stomped into the mud, and he thrust his sabre. The strike was batted aside, a low growl emanating from beneath the warlord's helmet. Didn't wait, didn't let the Chaos champion regain the initiative. Twirled the blade, used the redirection to twist the weapon around and under, then flicked his wrist.
    Skaros grunted in startlement as the tip of the sabre managed to slip through the gap between vambrace and gauntlet, and nicked the flesh beneath. It wasn't a debilitating injury, a slight cut, enough to draw blood, not enough to do much more than sting otherwise.
    But it was a reminder, one that the warlord now carried. A reminder that he was mortal. He could bleed. Was bleeding. He could die.
    The Chaos champion roared, a mix of fury and hate. But still he fought with control, didn't lose composure in his fighting, didn't lose himself to bloodlust and rage. If his strikes were a little harder, a little more force behind them, then that was the extent that he was allowing his rage to dictate his actions.
    Ingwel took a step back, his sabre met the side of the foul blade of the Chaos champion, redirected the blow. Swivelled his wrist, preempted the next swing, forced it aside before it could even begin, closed the gap and drove his elbow into the chest. Skaros stumbled at the force, recovered quickly though.
    Breathed out a breath. Side-stepped.
    Felt his blood rushing, the thrill of combat. Didn't get to fight as often as he would like. As marshal, Ingwel's mind was more important than his ability to fence. But he was still a saurus, and combat was in the blood, was his ultimate purpose in the world.
    Block. Parry. Riposte.
    The sabre in his hand danced. He was reminded as he always was about how the sabre had spoken to him as a design. A weapon not borne of brute strength, but of poise, of grace. Wielding the design that first time had felt like he was finding himself.
    A weapon where he needed more than to swing a blunt instrument, one that allowed him to show that he was capable of more than brute force in a fight.
    Back-step. Parry.
    Angled his body, allowing a thrust to miss him, stabbing through the space previously taken up by his ribs. Ingwel's Gromril blade was positioned to block those same ribs were the warlord to try and capitalise on the positioning. As he predicted, when Skaros pulled back his foul blade, he also pushed it toward Ingwel. Barbs caught on the sabre—almost seemed to try and pull the curved blade from Ingwel's grip
    Twist of the wrist, redirect the stinger-blade so that its pull wouldn't strongarm the sabre from his grip. Step closer, bring his offhand from behind his back and latch fingers around the warlord's elbow.
    Couldn't strike him, not with bare fist. If the armour was able to endure a Gromril edge, all that a closed fist, even one from a saurus, would accomplish would be broken fingers and cracked knuckles. But striking wasn't all that an empty hand was good for.
    Pivot on the ball of his foot, tightened his grip on the elbow. The warlord was heavy. That was to the warlord's disadvantage. Up and over and down again.
    The warlord landed back first into the mud with a harsh crash, already soiled armour now further muddied and sodden, no trace of white remained.
    He stabbed his sabre down at the floored warlord, angled to slip into a vulnerable joint. Had to abort the motion when the warlord kicked out, nearly took Ingwel's foot out from beneath him. Staggered back, regained balance and…
    Mud struck his eyes. A splatter flung from the warlord's gauntlet.
    He hissed a curse, vision blacked out by grit and filth. Blind, he wiped at his face with a sleeve, clearing just enough to blink through the smear. Eyes free, made to look toward the warlord, but was jolted when a body slammed into him. Turned, registered the foul armour before anything else and swung his tail, forced the warriors legs out from beneath him. The warrior was then run through by another saurus, stabbing down with a spear, puncturing the armour.
    Ingwel looked again to his foe, but the space between them had dissolved into chaos. Legionaries and Chaos warriors clashed where moments before there had been only mud and silence. Steel slammed against steel, screams rang out, and the white-armoured brute was nowhere to be seen.
    Ingwel flicked his tongue, tasting blood and dirt. He swiped away the last of the grime from his eyes, scowling as he scanned the melee.
    The warlord had vanished in the fighting. Swallowed in the press of bodies. Ingwel fancied he heard an infuriated scream, rage manifested. But there was little to say that it was the warlord, too many Chaos thralls surrounding him.
    It wasn't just a clash of warriors. The melee had blurred, less regimented lines and more a free-for-all. Admittedly, he would acknowledge that thinking of it in those terms made it sound worse than it actually was, there was still a clear sense of one force on one side, the other on the opposite.
    A horn blew. A giant stallion thundered past, a human rider astride it, hammer raised high. Supernaturally potent armour or not, a hammer blow at speed would fell any who still had traces of their humanity to them.
    Had to pause a moment, tried to work out just where a human cavalryman with a warhammer had come from. Tried to track the horseman, but the brawl quickly hid him from sight.
    He took a step. Eyes never stopped moving back and forth, trying to find the warlord again. Movement at the edge of his awareness, sharp and deliberate, had Ingwel lean back and to the side, avoiding the axe-blow that had been aimed for him. A hurried step back allowed the following strike to also miss.
    He took the moment to lunge forward, caught the wrist holding the axe, wrenched toward him and adjusted his hold, held the armoured warrior in place, allowed him to raise his sabre into the armpit, the tip puncturing through the mail and leathers.
    Dropped the body, twisted his head. Hissed softly when he felt a body connect with him with force enough to make him take a step lest he lose his balance. Turned to identify who had barged into him. Took note of the red coat, relaxed a fraction. The saurus who had bumped into Ingwel hissed something, then jerked back. Ingwel copied the action, trusted in his subordinate.
    A heavy axe came cleaving down, slammed into the ground instead of flesh. The saurus lunged, thrust his blade at the Chaos warrior responsible. The sword was blocked by a heavy steel shield. Ingwel stepped closer, cut at the warrior with his sabre, but was himself blocked when the warrior swung his axe back up.
    The saurus warrior snarled lowly, blocked a second time by the large shield. Ingwel hissed out a quick instruction, and then swung again. Saw the block coming, but while the Chaos warrior was distracted, the saurus moved close and physically grabbed the shield, and the arm holding that shield, and wrenched it aside.
    The Chaos warrior made to swing his axe at the saurus, but Ingwel locked his blade against the axe, keeping it from moving. The Chaos thrall looked between the two saurus on either side of him, each keeping one of his arms locked in place. He struggled against the two, but Ingwel grabbed the axe while it was immobile, yanked it free of the warrior's grip, and hurled it aside. Almost took a fist to the jaw for his trouble.
    Hurriedly grabbed the offending fist and held it in place. Cast a significant look at the saurus. Wasn't needed though. Before the saurus could do anything, a gunshot echoed out. Whether it was the intention or not, the warrior jolted, blood pouring from a hole in his helmet which hadn't been there prior, his body slacking as all strength left it.
    Ingwel dropped the carcass, head jerking back in startlement. He scanned about him, but couldn't see where the shot had come from. Dismissed it—wasn't important. He stepped over the body, already looking for the next inevitable threat to charge at him. The saurus had disappeared, the chaos of the melee a shroud that kept all from sight, even as they were in sight.
    Another horseman galloped past, heavy hammer swinging low to buckle armour and shatter bone. An aggrodon leapt upon a Chaos warrior, sharp teeth bared and closing about the warrior's throat, while the rider swung a sabre at another nearby warrior.
    Colour shifted in the air, became more vivid, more vibrant. Moments later, a beam of weaponised sunlight scorched and immolated a score of Chaos thralls. The source of the beam, Gila, roared triumphantly after the cannon on her back depleted its charge. Then the orange and black carnosaur hunched forward and lunged, caught a warrior between her jaws, and shook her head with force enough to crack and shatter the bones of the flailing warrior.
    Ingwel looked away, continued to keep a cautious eye about him.
    Didn't take much to realise that if nothing changed then soon he would be forced to sound the retreat. Numbers were slowly being chipped away. Attrition was the slow killer, but it was a killer all the same. He saw more Chaos corpses than he did his own troops, but there were more Chaos warriors available to be killed. Every lost saurus, or skink, or kroxigor was felt more keenly than the warhost felt theirs.
    Another Chaos warrior was brought down by Ingwel's blade. The armoured body fell to the ground upon the eviscerated husk of a saurus.
    Looked left. Looked right. Still no sign of the warlord, though his work was visible.
    How long had he been fighting? Time was a blur, a constant stream of matching one warrior then another.
    A loud crack of air being torn asunder 'neath the eldritch power of the warlord. Ingwel pivoted to face the direction the sound had come from, but wherever the warlord was, he was still buried beneath the bodies of the melee, invisible to Ingwel. No hint of even the bodies that resulted from the unnatural energy blast.
    Stumbled when yet another body collided with him. Felt the steel of the armour, recognised it as the enemy even without looking. Twisted himself around, blade first. The warrior hadn't finished their own turn, had been distracted by a skink with a spear. They only became aware of who they had backed into when Ingwel's sabre pierced the ribs and the heart beneath.
    The warrior stilled, and if the sabre hadn't killed him, the spear rammed into his neck finished the job. Blood cascaded down in volumes enough to please Khorne, though no one here spilled it in his name.
    Ingwel nodded at the skink, who pulled the spear free of the warrior's neck with a returning nod. The smaller reptile adjusted his grip on the weapon and disappeared into the brawl.
    Ingwel's tongue flicked out, tasting the air. Still mud, blood, and fouler scents best left unnamed. Exhaled softly.
    A new sound filled the air. A horn, but not one of the Legion's. It didn't sound like any Empire horn either. It was a long, low bellow.
    For a moment, the fighting paused as everybody, Legion, Chaos and the few Empire humans, all looked to the crest of the hill. The horn continued to linger, before it gradually trailed off.
    For a moment, there was nothing. Then Ingwel felt it more than he heard it. A low, rhythmic beat.
    Thump. Thump. Thump.
    He narrowed his eyes, tensed. What next? He felt a momentary spark of hope, but he was quick to contain it, lest he open himself to disappointment.
    Thump. Thump. Thump. 'Ha!'
    Ingwel's back straightened as he caught the new sound. Words?
    Thump. 'Khazukan.' Thump. 'Kazakit.' Thump. 'Ha!' Thump. 'Khazukan Kazakit-ha!'
    Louder and clearer the words became, words that Ingwel knew. He didn't think anybody couldn't possibly know not just the words themselves, but the meaning behind those words.
    That hope previously contained was freed. Ingwel released his breath, which came out with a "hah".
    And at the crest of the hill, the first battle standard appeared, angular design on the banner recognisable for who carried it. Then the carriers, and the first ranks of the newcomers appeared. And still they chanted in time to each step.
    More emerged, resting the hill and forming up long lines, long ranks of warriors. Ingwel felt a chill run down his spine at the sight, at the air's vibrations to the marching footsteps and chanted battlecry.
    The formation halted like a wall built from flesh and iron, but still the chant thundered, louder than before.
    'Khazukan Kazakit-ha!' Look out, the dwarfs are on the warpath.
    Ingwel could make out a single figure moving along the front of the ranks of Dawi, a hammer raised high, though bobbing as the dwarf gestured harshly, clearly—even at this distance—getting worked up by his own pre-combat speech to his throng. And then, the hammer was lowered, gestured toward the melee.
    And the Dawi roared, their march transforming into a charge like the breaking of the earth itself. It wasn't a chaotic rush, the Dawi kept themselves in their tight formations, shields facing forward and close together, forming a wall. A wall that was charging forward, and was not about to stop for anything that wasn't the Dawi's own choosing.
    Inhaled, felt a chuckle, nay, a laugh building in his chest. He remembered, back before the battle had started, Ser Wolfram had spoken of the reason for the Knights of the White Wolf's delay being a reinforcing force worth slowing down for.
    A Dawi throng? Ser Wolfram had been right, that was indeed the kind of force worth slowing down for.
    Victory had previously been a distant and just out of reach abstract. Now with the Dawi, the balance of power had shifted.
    The Chaos warriors could clearly tell that their victory had just been snatched out from under them. They might still kill Ingwel, kill every member of the Legion, but it would now come at the cost of their own warhost.
    Even Chaos suffered from morale loss. Here came the dwarfs, fresh and in numbers. Meanwhile the warhost was tired, had suffered losses. Had the Dawi been involved from the start, maybe the warriors of Malice wouldn't feel the blow to their morale so keenly, no doubt the way the battle had been fought would have been different.
    But the arrival of the Dawi after six long hours of fighting?
    The warhost just needed that final push, and Ingwel had no doubt that their morale would be shattered.
    And for that push?
    Ingwel's eyes finally found the warlord again. Almost missed him, his previously gleaming white armour coated in so much sodden earth that were it not for that blade of his, he would look indistinguishable from his lesser warriors.
    Ingwel tensed, hunched forward and then launched himself forward. The warlord turned, must have sensed the hostile intent focused on him specifically. That, or he managed to catch Ingwel from the edge of his periphery.
    Luckily, Ingwel wasn't fool enough to put everything he had into a proverbial haymaker. Not fool enough to leave himself open to a counter attack, success or failure to fell his opponent.
    The warlord managed to bat aside the sabre, but couldn't counter. A human appeared, heavy warhammer already swinging, his form partially obscured by the giant white wolf pelt he wore as a cloak.
    The warlord weaved aside the hammer blow, adjusted his grip on the barbed sword and made his move to retaliate against the Empire knight. That motion was halted when Ingwel lunged, and the warlord had to turn his blade instead to parry the thrust.
    Again, he started to make his counter-attack, only to physically hurl himself to one side when the White Wolf's hammer came swinging around.
    The knight was clearly skilled, flesh showed his age. An age that one did not reach in this lifestyle without picking up the skill to survive.
    There was a snarl from beneath Skaros's helmet, a dark glower directed at them. Then, after swinging an arm around to bat aside Ingwel's latest strike, he went on the offence, his foul barbed blade swinging in a rapid flurry of blows which had both Ingwel and the White Wolf backpedalling, forced on the defensive.
    Ingwel was vaguely aware of that moment, the instant when the Dawi clashed with the Chaos warriors. The air hummed with the violence.
    Ingwel brought his sabre up, angled downward. It met the warlord's blade, pushed it aside. Would have been able to slide the sabre down the length of the other weapon had it not been for those barbs, instead, for a moment it was as if they were going to be forced to remain in the bind, but the knight chose that moment to charge forward, hammer swinging low. Would have taken out the warlord's leg, but again the warlord weaved back.
    Skaros slid slightly in the blood-stained mud from his abrupt dodge of the hammer strike. He raised his blade in a manner that Ingwel had quickly become familiar with, his attention clearly focused on the knight.
    With a hissed curse, Ingwel moved. Slammed his shoulder into the knight and sent both to the ground the knight uttering startled oaths to Ulric. The eldritch blast missed them, though Ingwel was infuriated to note that one of his saurus had taken the blast. Of everybody surrounding them, of the tangled mass of bodies fighting, and of course it turns out that one of his takes the stray blast.
    The warlord flinched, at the same instant that a gunshot echoed through the air. Whether it was a Dawi thunderer or a skink musketeer, Ingwel didn't know, didn't particularly care either. The warlord didn't look like he'd been injured, assuming that he had actually been the one to take the gunshot. Probably had—the flinch was likely startlement more than anything else, hadn't expected to be shot at that moment.
    For all that he was unflinching and had no hesitation about using his armour to block sword strikes, that didn't render him immune to shock and surprise. It probably shouldn't have satisfied Ingwel as much as it did to realise that fact.
    But he felt a cold glee that Skaros was not so above it all that a random gunshot was capable of making him flinch from startlement.
    Both Ingwel and the knight returned to their feet, used the time gifted to them by Skaros's shock to their advantage. It wasn't enough time to get a killing blow in—Ingwel doubted that the warlord's shock was quite that strong even if they had been—but it was time enough to get themselves upright and ready.
    A blue flame appeared, bursting from the ground. It died down to reveal the form of a human woman, dressed in fine silks styled as those from Ind. Ingwel vaguely recognised her from the descriptions, and had briefly spotted her when looking over the battle through his spyglass.
    The champion's fire-scarred face scowled at Ingwel, one hand raised, palm pointed toward him, while her other hand latched onto Skaros's shoulder.
    'What do you think you are doing?' Skaros demanded.
    'We've lost this one, my lord,' the champion said, her voice layered with bitterness and disgust.
    And then blue flames shot from her open palm, gushing toward Ingwel and the Knight of the White Wolf. At the same time, a cocoon of those same blue flames surrounded Skaros and the champion, seemingly devouring them.
    With a curse, Ingwel swung his sabre at the blue fire streaming towards him. Trusted the dawi-runes on his blade. The weapon sliced through the flame, and parted it, then seemingly drank it in.
    He exhaled softly, twisted the weapon in his hand to look upon the trio of runes. One of them was faintly glowing, though that glow quickly dimmed as the purpose behind it was no longer needed.
    Where the warlord and his champion had been, there was no sign other than the mud being dried and burnt where they had stood. They were gone.
    'Shit,' he hissed softly, allowing himself the rare indulgence of actual vulgarity.
    Failure to kill the warlord or not, his disappearance quickly had the same effect regardless. He could feel it in the air. That moment Skaros vanished, the oppressive weight that had held everybody down lifted and with it the Chaos warriors faltered, where before they had seemed to carry an iron will, now they struggled.
    A hand clasped Ingwel's shoulder. He turned, and met the eyes of the knight.
    'You held admirably,' the human spoke with a tone that carried age and experience.
    'Not finished yet,' Ingwel said. He took a step forward, and lifted his sabre as though it were a banner to rally around. 'Legion! Reform!'
    Around him, every member of the Legion nearby who was not actively fighting at that moment moved, called by Ingwel's voice, projected at volume to be heard across the battlefield.
    A formation was formed around him. Battered, with missing members, but still formed with what they had.
    'What are we?'
    'We are Children of the Gods!'
    'Who are we?'
    'The Outland Legion!
    Ingwel let out a chuckle. 'Now's our time. Let's see the Chaos from this land!'
    Those within the formation roared in answer. Even those who hadn't been able to remove themselves from their prior engagements roared, and fought with renewed vigour.
    And with that rallying cry, Ingwel led the charge at the faltering Chaos warriors.
  6. J.Logan
    Sodden After-action
    Northern Middenland
    Thane Thundi Flintisson of Karak Varnazund scowled. Some said it was the only expression he owned, and in lighter moments he might even agree with them. It was simply the way his lips were naturally pressed together, brow perpetually furrowed as if chiselled that way by centuries of stubbornness. Even when he was in a good mood.
    He was not in a good mood.
    So he scowled with deliberate intent.
    Really, it was a culmination of several months. His mood had been grim from the moment that he had learnt of umgi-ruaki on the move. Not just any umgi-ruaki, but those that were Malice-tainted.
    Dawi had long memories. They remembered every grudge, every wrong, every blood-debt carved in stone. And the umgi-ruaki of Malice? Their ledger with Karak Varnazund was thick with sin.
    With such grudges to be settled, Thundi had gathered a throng and set out with the purpose of striking some grudges from the ledger. Ill fortune that the Malice-umgi were a distant march away, causing problems for the Empire. There was some concern that the Empire’s umgi would manage to wipe out the Malice warhost without the involvement of the throng—a grudge could be settled through another’s hand, but only if the Dawi had a part in it. Even if it was just ordering the blow.
    Not that most Dawi would ever stoop to that. Pride was a force greater than any god. And that pride dictated that Dawi settle their own grudges with axe in hand, unless all other options had failed.
    Good fortune had determined that the Warhost of Malice were going to be in a large battle that would hold them in place, which would allow the throng to reach them at last. Assuming the ones fighting the warhost survived long enough.
    The Knights of the White Wolf had been rather quiet on the ones who would be battling the Chaos-blighted warhost. Their Hochmeister, Wulfhart Grimmson, had said that mercenaries were leading the fight, but little else.
    Arriving at the battlefield, Thundi had seen why there was little said of the mercenaries. He had never seen repki before, though he knew of the lizardmen of Lustria and the Southlands. What he knew of both did not suggest any fondness for gunpowder. Or for clothing.
    Yet there they were. Fighting on mud-slick hills, lizardmen clad in uniforms, firing muskets with discipline and grim precision. No doubt Grand Master Grimmson had kept quiet because seeing was believing. And Thundi? He would not have believed it unless he’d seen it himself.
    Surprise died quickly beneath duty. There were Chaos-spawn to crush. He had personally led the charge, twin axes held aloft.
    The Dawi didn’t arrive like a wave. They struck like a mountain falling, relentless and unyielding. That was their way.
    But the satisfaction had been ripped away. The cowards had lasted barely a handful of minutes before the first of them broke. With the first, the others started to follow suit, until the warhost collapsed into a mass rout. Satisfaction fled like a craven faced with a fair fight.
    If Thundi was feeling generous, he would acknowledge that it was both inevitable and understandable. By all accounts, the battle had raged for well over five hours, both sides were exhausted and bloodied. The appearance of a Dawi throng? Only fools would have felt that staying and facing the new threat was a good idea.
    Thundi was not feeling generous.
    What Thundi felt was fury, a righteous Grimnir-given rage as they fled, denying him the clean deaths needed to strike their names from the Book.
    Not that he suffered them to flee unmolested. The repki might have been too spent to try to run them down, but the Dawi were still fresh, still eager. They harried the retreating cowards, hammer and axe bringing low any too slow to escape, while the thunderers unleashed volleys at those further off.
    There was no way to run them all down. Dawi pace was deliberate, not swift. But every Chaos-warped corpse left in their wake was one less problem waiting to return. And now that the throng had caught the warhost once, it was inevitable they'd catch them again. And again. As many times as needed.
    Let the umgi-ruaki outrun them in a sprint. Dawi were the destined winners of the marathon.
    It was with that in mind that once the last of the warhost’s warriors had finally got enough distance to be deemed as “escaped”, Thundi turned his attention to the repki mercenaries, and the Empire umgi who had been fighting alongside them. At first, he didn’t do anything more than watch with a mixture of curiosity and suspicion. Everything he knew of the repki of Lustria and the Southlands marked them as fanatics of some “Greater Good”—or whatever the repki called it—following it with the same zeal that any self-respecting Dawi gave the Book of Grudges.
    It sounded fine enough, this Greater Good, except: a greater good in whose eyes?
    Even among the Dawi’s allies in the Empire, many balked at the Book of Grudges, calling its traditions petty and its methods for cleansing wrongs excessive. Let them say what they would. The stain of a grudge was a weight on the soul, and Dawi knew better than to let such things fester.
    But how did being mercenaries factor into this “Greater Good” of theirs? Or were these repki something else entirely?
    Questions. Questions and no good time to ask them.
    Thundi was a Dawi. Even as the thane of a Karak, he was considered brash by the standards of other races, all too prone to bulldozing through their so-called "diplomacy." He would argue, of course, that if others wanted to pussyfoot around instead of getting to the point, that was their failing, not his.
    But even Thundi knew there were times and places for questions.
    And while the dead were being gathered; this was not one of them.
    So for the time being, he watched. A Dawi could learn much through observation.
    He learnt that the leader of the repki was not above hard work. No pomp, no orders barked from a distance. He was there, among the ranks, shirt sleeves rolled up, helping carry bodies into orderly rows while others stacked wood for the pyres.
    He learnt that the repki were not emotionless flesh golems. The signs of emotion were muted—barely visible, even to him—but they were there. Small tells, subtle details that had nothing to do with their faces.
    If one tried to work out their emotion using only facial expressions, they would be left without any result. There were no expressions, at least not in any way that made sense to a Dawi. But their eyes betrayed tension. Their postures had stiffened. Their tails slapped the mud. Fists clenched, then slowly unclenched.
    No, they felt. And what they felt now was mourning, tempered by fury.
    If the repki had their own version of the Book of Grudges, the Warhost of Malice surely had a new entry. Or perhaps that wasn’t their way. Perhaps their so-called Greater Good demanded restraint; that vengeance only be taken when it served some higher goal.
    Thundi snorted at the thought. He’d take a clean, honest oath of vengeance over that sort of pious waiting any day. Still, to each their own. Couldn’t expect everybody to be as sensible as the Dawi.
    He wondered for a moment if there was a cultural significance behind their intent to cremate the bodies, or if it was simply a reaction to the whispers of undead. Shook his head before he could dwell on it. Wasn’t important, just a question of the moment.
    He turned away from the scene, best to not get in the way of funerary rites. Start to stare too long, it would start to become rude, even by his standards.
    He glanced around, searching for something to focus on that wouldn’t come across as awkward staring.
    The Grandmaster of the Knights of the White Wolf stood nearby, speaking with another knight. No, not about to interrupt a conversation.
    A line of injured repki, being tended to by their kin. No again, interrupting a healer at work was a surefire way to earn a deserved tongue-lashing. No matter the race, healers were an authority above all else, and sharp of tongue besides.
    Instead, his eye was drawn to the repki who stood at the outer edges of what had been the battlefield, standing vigil in case the umgi-ruaki might decide to turn around and resume the violence. Not that Thundi expected that to happen—much as he might wish it.
    Still, it presented a potential avenue for conversation. Thundi was curious, after all, about how a repki mercenary company came to be waging war on behalf of the Middenland umgi. And there were few things more effective at satisfying such curiosity than asking the source directly.
    The air was turbulent. A constant guttural screaming echoed loud and true. Soulshriver resisted the urge to cover the holes where his ears used to be—though for the first time since they’d been torn off, he regretted not losing his hearing along with them.
    It had taken time to track down where the warhost—what remained of it—had rallied. And it was annoyingly far. The appearance of that blasted midget-brigade, chasing down warriors while screaming aloud their obsession with “paying back wrongs” so ancient they’d surely fossilised, had scattered the warhost further afield than usual.
    Naturally, the warriors of Malice could outpace the vertically impoverished. Even exhausted, they had long legs. Truly, the Ancestor Gods had cursed the short-stacks, doomed to chase those who’d “wronged” them, only to be outpaced at a leisurely stroll.
    Any who still lived, had escaped, would start to find their way back. There was a presence about Skaros, one that pulled at those subordinate to him. The warriors and the marauders may not fully understand, but they would feel a pull that would always, inevitably lead them back to him.
    Soulshriver almost wished he hadn’t tracked down the warhost’s rallying point so soon. Not with a greeting like that: screaming fit to wake the dead. Considering Middenland was still suffering an ongoing undead problem the last he had heard, that wasn’t exactly something Soulshriver wanted to tempt fate with.
    The screaming increased in volume.
    It wasn’t even a high-pitched caterwaul. Just a low, raspy voice made thunderous by sheer volume.
    He had delayed approaching, unwilling to get closer to the source of the screaming. Hoping that the one screaming would exhaust themself—not likely, but hope was cheap—and if nothing else, to delay the chances of abuse sent his way. That could be verbal. It would probably be in the form of things thrown at him, however.
    So instead, he busied himself stripping off his cuirass and sode. His eyes went straight to his shoulder, to the weeping gash that had cut clean through his armour.
    The flesh around it was red and inflamed, sore to the touch. The wound itself hadn’t even begun to close. No scabbing, no stitchwork of the skin. Still parted. Still burning. And not with the normal heat of torn flesh. This was something else.
    He would know. It wasn’t the first time a blade had kissed him. Wasn’t even the first since his tenure as a guest of the Serpent had ended.
    At least it wasn’t weeping blood. Though pus wasn’t altogether better. But at least it was clear, it didn’t get in the way when Soulshriver stitched the cut closed, the first time in a very long time he’d had to do such.
    The screaming was loud and true. Even after the time spent delaying the approach. There was little else that Soulshriver could do to delay his approach which wasn’t simple cowardice. He didn’t want to approach.
    Still, needs must.
    It was a clearing in the middle of the makeshift camp. And when Soulshriver approached, he found himself wincing in sympathy, suddenly very thankful that the strange, unhealing cut that he had received was all that he had been dealt.
    The Everwrath continued to scream in a mixture of pain and fury. Where one of his arms should have been, there was naught. To Soulshriver’s expert eye, it was clear that it had not been a clean cut, the bone, visible where the appendage ended, was jagged and splintered.
    No wonder he’s been screaming. I don’t think I would have been much better.
    It was a rare flicker of sympathy for a fellow champion. He’d assumed the noise was just rage at the retreat. Hadn’t even considered that Valnar—Valnar, of all people—had been dealt a truly crippling blow.
    And crippling it was. For a man who thought with two axes, he was now half the warrior he’d been. Soulshriver had never cared for Valnar’s style—saw it as graceless, brutish, and far too loud—but it was the man’s identity. And now it was half-gone.
    Another approached at about that same moment. The Incubator, brow creased with frustration, stormed towards where the Everwrath was writhing on the ground. His lips were pressed into a thin line, and without a word he grabbed the Everwrath’s stump and pressed something against the bloody injury.
    ‘What are you doing!?’ the Everwrath roared, jerking back and lifting the stump to see what had been done.
    Soulshriver grimaced. He saw it the same moment Valnar did.
    Maggots.
    Dozens. Hundreds. A whole twitching swarm.
    ‘No! Get them off!’ the Everwrath bellowed, trying to swipe at the stump with his remaining hand. ‘I’ll not be gifted one of your poxes!’
    In a rare display of both physical strength and clear irritation, the Incubator grabbed Valnar’s arm and held it firm.
    ‘Do not be an idiot, Valnar. They’re cleaning the wound. They’re preventing infection, you imbecile.’
    It took a moment for Soulshriver to recall the truth of the Incubator’s words. Maggots did eat tainted flesh, cleaning away rot and reducing the risk of infection. It wasn’t a method used often, however, not with maggots being so closely associated with Nurgle. No doubt one of those ironies the less straightforward gods delighted in. Maggots, which devoured rot and corruption, had become symbols of rot and corruption.
    The Everwrath clearly didn’t appreciate the irony, nor care to acknowledge the truth in the Incubator’s words. He thrashed and bellowed, still trying to shake off the old man’s grip.
    Maybe if someone other than the former Nurglite had taken on the task, it would’ve gone over better. But even then, Soulshriver doubted it. The symbolism was too ingrained. Maggots were Nurgle’s creatures in Valnar’s mind, and that was that.
    Perhaps that was the point—one of Nurgle’s subtle victories. By being associated with what could prevent infection, people avoided them out of superstition… and thus invited more infection. Who said Grandfather Nurgle couldn’t plan ahead in his own way, same as Tzeentch?
    ‘Cease your noise, Valnar!’
    The command hit just as a wave of heavy pressure crashed down on Soulshriver’s mind. He grimaced. The Incubator winced too. And Valnar let out a startled sound somewhere between a cough and a hiccup.
    Skaros stormed into the clearing.
    His stride was the same calculated stalk as always, his posture the same upright, stately poise. But Soulshriver knew him too well. Knew what to look for. The way he wasn’t clenching his fists. The way he kept his voice perfectly level.
    Skaros was furious.
    Not merely angry. This was the cold, sharpened rage that stripped him down to the bone, that summoned the cruelty which made him the chosen of Malice. His tone was too blank, too polished. There was no edge of performance. No mask of cold confidence or condescension. Just... nothing.
    And nothing was terrifying.
    Nothing was the rage that preceded the genocide of entire shires.
    Trailing behind him came Fatesaw, her gait uneven, a limp disrupting her usual theatrical grace. Her garb concealed any wounds she might have suffered, but Soulshriver was almost certain they were there. The only question was who had inflicted them. The reptiles? Or Skaros?
    Not that Soulshriver had any sympathy for her, either way. She fancied herself cleverer than she truly was. A scarily competent sorceress with a flair for flame—despite the burn-scars that had kissed nearly every inch of her body—but not the master schemer she imagined herself to be.
    It was no secret that Skaros did not care for being taken from the battle. And while Soulshriver hadn’t witnessed it—too far and making his own retreat—he had heard whispers of how Fatesaw had made a choice and decided to take Skaros with her in retreat. She ought to be thankful that she still had her life, it wasn’t on her to decide when Skaros should retreat.
    Fatesaw’s eyes drifted to Soulshriver, and he knew the moment she had noticed his shoulder.
    ‘What happened to your shoulder?’
    The question drew the attention of Skaros and the Incubator. The Incubator, no longer forced to battle against Valnar’s flailing, had re-adopted his usual wide, bordering manic, grin. But even with that grin that stretched from cheek to cheek and made Soulshriver’s own rictus tame in comparison, he visibly frowned.
    ‘That should have healed by now…’ he mused, narrowing his eyes.
    Unconsciously, Soulshriver moved a hand over the stitched wound. ‘Well it hasn’t.’ He didn’t elaborate, uninterested in discussing his own failures.
    Couldn’t even be certain that the one who had dealt the blow was dead. The grove igniting and coming aflame had put an end to their fight, and as much as Soulshriver wanted to believe the reptile kensai had burnt with the grove, he also doubted it had happened like that. Soulshriver survived, so it stood to reason that the other had done so also.
    Skaros stared at him, his eyes unseen through the visor in his helm. Soulshriver felt a sliver of ice against his spine, fought against the shudder that wanted to result.
    Finally, after a long moment where nobody said anything, Skaros pulled out the stone that had been unearthed from the tomb beneath Feyerabend Keep. The glow it had projected before seemed stronger, and its red colouring a little less muted.
    ‘So many dead,’ Skaros said, more a self-musing than conversational, ‘and yet still not enough to empower this stone.’
    Fatesaw glanced at the stone in the warlord’s hand, eyes alight with greed, but at the same time a wariness. Soulshriver wished he knew whether that wariness was regarding Skaros—and the notion of betraying him—or the stone’s purported power.
    ‘If the stone has the power you believe it to,’ she said, slowly, thoughtfully, ‘maybe it needs more than just a sacrifice of lives.’
    Skaros slowly turned his head to face her. Other than a brief widening of her eyes, she managed to keep herself still.
    ‘Explain your thoughts,’ he commanded her after a drawn out pause.
    Fatesaw pursed her lips. ‘This stone is supposed to grant power akin to gods. Mortal lives sacrificed to empower it… works, clearly,’—she motioned at the stone,—‘but is a trickle, barely a step up from letting it drink in the Winds of Magic passively. We need something more… direct. More potent.’
    The Incubator hummed, crossing his arms. ‘She has a point. If we think of the power that stone grants in the same way as the power gifted when gods uplift mortals into Daemon Princes, the lives sacrificed aren’t the source of that power, they’re the catalyst used to get the attention of the god or gods in question, who then gifts a fragment of their own power to ascend the mortal.’
    That was interesting to Soulshriver, who had never considered the actual mechanics of one’s ascension into Daemon Princedom. It made sense, if the lives sacrificed was the only fuel needed, there would be far more Daemon Princes than there were.
    ‘And since the stone is a source of power separate from the gods of Chaos,’ Fatesaw continued, getting more animated as she furthered her thoughts, ‘then we can’t beseech Malice to empower the stone, because it would go against the whole point of our using it.’
    ‘And we can’t get another god to empower it, for obvious reasons,’ Soulshriver mused, following their line of logic.
    Skaros stared at Fatesaw, then briefly looked to the Incubator, and then Soulshriver. He ignored the Everwrath, who while quiet now, though still writhing in pain and glaring at the maggots on the stump where his arm ended.
    ‘Interesting thought.’ Skaros finally spoke, his tone less blank, his posture relaxing ever so slightly, and he stowed the object back to wherever it was that he kept it.
    Soulshriver could tell that he was still apocalyptic with rage, but that rage had been stowed away.
    ‘It’s too bad the old man that led us to the stone didn’t speak of any instructions on its use,’ the Incubator spoke, tone faux-jovial. ‘But I imagine that the hows and whys were lost to time.’
    Soulshriver let out a guffaw at the comment. When the others turned to look at him, he was secretly thankful at that moment that his lips and cheeks being torn away had left his expression a permanent rictus. Nobody could see his amusement at the image conjured by the Incubator’s comment, not when his grin was the same as it ever was.
    A moment later, Skaros looked again at the stone, then stowed it away once more. ‘I have a few thoughts in mind that might test that theory of yours, Fatesaw.’ His head angled, so that his visor was lifted to the skies.
    ‘So, what do we do now, Lord Skaros?’ Soulshriver asked.
    Skaros turned his head to the general direction of the battlefield they’d just left with tails between their legs.
    ‘We suffered more losses here than I cared for, especially with this reveal that lives sacrificed didn’t empower the stone nearly so much as desired. We need to recoup our losses, and get away from those dwarfs now that they have our scent.’
    Skaros crossed his arms.
    ‘We shall splinter the warhost into separate warbands. Each of you shall go, replenish our losses in different places. All of you have connections. Use them. And with Malice’s strength waning of late, make sure you don’t limit yourself to the cult of Malice. So long as it can be used, take what you can.’
    Soulshriver considered his options if he was to lead an independent warband. There was a flicker of doubt in his mind, that maybe Skaros would use the separation of the warhost to empower the stone without the others, to hoard the strength it would grant for himself. A short look at Malice’s Chosen later, he dismissed the notion. It was not that Skaros wasn’t capable. He almost certainly was.
    But even if Skaros did manage to empower himself with the stone, he was still one man, facing off against the four dominant Gods of Chaos. And if the current waning of Malice’s power was any clue, those four were already uniting under a joint purpose.
    Since Malice hadn’t yet fought them to the brink this cycle, that did not bode well. There were very few things that united Chaos’s most infamous four gods. Malice’s near victories were the common one, but as established, was not the possible cause in this case.
    The other cause that immediately came to mind had only happened twelve times in history. Soulshriver hoped that he was not about to witness a thirteenth.
    For all that the Warhost of Malice was hoping to use the stone to avoid losing strength alongside Malice’s waning power, it was still an unspoken question as to whether it would match Malice’s power at its peak, against the fury of four gods. And potentially, those four gods were about to have an avatar of their unity walk the lands.
    No, Skaros wouldn’t simply throw aside the four champions he had gone to great lengths to bring under his banner. Not with the threat of an Everchosen lingering in the not so distant future.
    Grand Master Wulfhart Grimmson, Hochmeister of the Middenland Chapter of the Knights of the White Wolf, observed. Observed as the strange reptiles sorted their dead with solemn silence. Observed as the sky darkened, the sun beginning to set, uncaring of the duty still unfinished after hours of work.
    The lizardmen weren’t the only ones finding their dead. But they’d contributed the most, and consequently lost the most to Morr’s embrace.
    There was a nearby Knight Panther. A part of Wulfhart wanted to go over to the rivalling knight, to engage in banter, teasing and mocking. It would be nice to indulge in the normal banter that marked the rivalry between their respective orders. But while there was a common opinion about the White Wolves that claimed them to be lacking in intelligence and overly brash, unable to think without resorting to their hammers, he was not an idiot.
    The normality of banter would be ill-served at that moment. Not just a failure to read the mood—it would be an insult to those who had fallen only hours before, their bodies still strewn across the field.
    He regretted that it had taken them so long to reach the battle. Had he learnt that the Graf of Middenheim had been waylaid, he would have strongly urged the Dawi throng to allow him to lead his knights ahead, rather than to travel at their pace. The Dawi were not wholly unreasonable, urgency would have been a valid reason to not travel at their pace.
    And what a contribution your late arrival made, he snorted in self-directed bitterness. A short span of combat as the vanguard to the Dawi, and then the Chaos warhost routed on the arrival of the dwarfs.
    That was simplifying. But that was also how it felt to him, and he would not fault any of the lizards, the Panthers or the two companies of Middenland state troops if that was how they felt.
    And when the warhost routed, the Dawi had taken pursuit and tried to run them down as best they could. It had to be the Dawi, and the White Wolves. The lizards were exhausted, and it hadn’t taken a genius to see that other than a few companies who had been on other fronts, they had been on their last stand.
    Wulfhart didn’t know much about the lizardmen. Even less about these ones, this Outland Legion. But he admired their dedication to stand and fight to the last. This wasn’t even their land, and yet they had probably just spilt more of their own blood for it than actual Middenlanders had.
    A sorry state, that. Wulfhart didn’t know what all had been happening whilst the White Wolves had been sweeping the province, but he could not see any reason for the lack of action by the Middenland military that wasn’t a cause for embarrassment.
    Wulfhart wasn’t even feeling the usual disdain regarding those who fought for coin rather than loyalty. How could he? When the mercenaries had actually shed blood for the Province rather than those who were supposed to be loyal enough to do so?
    He sighed irritably and pushed down the mixed feelings that warred to be felt.
    The leader of the lizardmen was nearby. He had shucked his blue coat, simply wearing the off-white shirt underneath. He retained a quiet dignity, even as he stopped regularly to help his subordinates carry a body toward the funeral pyres.
    Weapons were stripped from their fallen; blades, billhooks and muskets. All carefully sorted separate from their dead, who were in turn carefully laid in neat rows atop stacks of wooden kindling.
    Fortunate that the rain had finally stopped, with not even a drizzle remaining.
    Wulfhart tore his gaze from the proceedings, moved on rather than stare at the handling of the dead. Instead, his gaze moved to the large orange and black carnosaur. It was laid down nearby, blue eyes watching everybody around it with a predatory gaze. As if sensing his attention, the large apex predator turned its eyes to stare at him. It didn’t make any movements that could be seen as threatening, but he felt a rattling sensation, and could just barely hear a snarl from the beast.
    ‘You should not stare at her.’
    The grandmaster of the Knights of the White Wolf didn’t startle at the voice. The only hint that he was surprised was a brief tenseness to his shoulders, before forcibly relaxing.
    ‘Master saurus,’ he greeted, turning to face the large lizardman.
    The saurus in question was stripped to the waist, leaving him in simple breeches. Strips of linen bound tightly around one arm, and his left shoulder and left breast. Both were stained red. Wulfhart swallowed a dry throat as the unblinking eyes seemed to bore through him, before slowly moving away.
    ‘Preda,’ the saurus said.
    ‘Excuse me?’
    ‘My name: Preda.’
    ‘Oh.’ Wulfhart shook his head slightly, and cast another look at the carnosaur.
    ‘You should not stare at her,’ Preda repeated, even though he wasn’t looking at him. ‘You are telling her that you are challenging her.’
    Wulfhart quickly averted his eyes. He had no desire to get into a fight with a carnosaur. Not least the carnosaur of allies. Lacking anything else to focus on, he fell into step behind the saurus. Preda carried what Wulfhart convinced himself was a leg of deer: fresh, blood still streaking the bone.
    Preda approached a large raptor, which crooned softly on seeing him. Wulfhart recognised the beast—Cold Ones. I think the Dark Elves call them that at any rate.
    It bore a bloody gash across its flank, but the wound didn’t seem to hinder its movement. That became abundantly clear when Preda tossed the leg, and the raptor lunged forward with startling speed, snatching the pink fleshed meat from the air.
    Powerful jaws snapped shut; the crunch of bone was sharp and clean. A jerk of the head had what remained of the meat briefly airborne, and those jaws quickly snatched the limb again. More crunching and then five seconds later, the meat was gone. The Cold One stepped forward, pressing its head into Preda’s outstretched hand with a low trill.
    ‘Beautiful creature,’ Wulfhart said at last, watching as Preda gently scratched the raptor's head.
    ‘He has been my partner for many summers now,’ Preda replied, and though his tone barely changed, there was the faintest suggestion of a smile in his voice.
    ‘Are Cold Ones a common choice for cavalry for your kind?’
    Preda’s hand paused the scratching for a moment, then resumed when the raptor nudged the hand.
    ‘Aggradons. “Cold Ones” is the misnaming of the Druchii.’ The smile was gone from Preda’s voice, replaced by something colder—distaste, clear and sharp. ‘The dark elves have no business renaming them. Not with how they abuse them in the name of “taming”.’
    Wulfhart lifted his hands in a warding gesture. ‘My apologies, friend. Aggradons, then.’
    Which, thinking of it, actually sounded more like an actual name for the raptors, rather than a description.
    There was a moment of quiet, then Preda grunted softly. ‘The Children of the Gods have been forming partnerships with aggradons since long before your Empire was a dream. Would not have it any other way.’
    Wulfhart briefly wondered what the Empire might have looked like had aggradons been native to the Reik Basin. Would knightly orders have ridden them, as the lizardmen and dark elves did? And if so… how would they have tamed them?
    He chose to change the subject, after watching Preda care for the large raptor a while longer.
    ‘What happens next for you and yours?’
    Preda tilted his head, unblinking eyes turning toward him. ‘We finish the last rites for our fallen. Then we wait for word.’ His gaze drifted in the direction that the routed remnants of the Chaos warhost had fled. ‘Maybe we resume the hunt. Maybe return to hunting the undead. But we wait for news first. News from Middenheim, and the siege.’
    Wulfhart jerked back in shock. ‘What siege?’
    ‘The undead laid siege to Middenheim. That is why the Middenland army was not here. They were busy defending their home.’
    Wulfhart took a full step back, twisting to look southward, toward the great fortress-city. It was far enough away that he could see nothing—but he looked all the same.
    ‘Shit,’ he muttered. ‘I was wondering… but I never thought.’
    Preda hummed softly, then pulled away from his aggradon. ‘We wait for news,’ he repeated. ‘And if we hear nothing, Ingwel will have us march to Middenheim. The city is more important than chasing down the warhost.’
    That was a relief to hear. A relief that the lizardman mercenaries understood that the city, and the lives within were of a higher priority than the remainder of the warhost.
    Though he did wonder, in a dark corner of his mind, if they only thought that way because the Dawi were there to take up the pursuit of the warhost in their stead. Or whether it was a case of nerves, due to the number of dead from the last confrontation.
    He fought down those thoughts. No, the lizardmen legion had fought hard and true, it was an insult to think that now they were suddenly craven.
    He attributed those unbecoming thoughts to worry for his home.
    It was around that moment that squelching mud marked the approach of somebody new. One of the smaller lizardmen—a skink—was nearing them, eyes fixed on Preda.
    ‘Captain, we have finished gathering our dead. We give last rites in an hour.’
  7. J.Logan
    J.Logan Well-Known Member
    Ashed Rites
    Northern Middenland
    Bodies were lined up, laid as if at rest.
    Mayhaps they were, in a way. What was death but a final rest?
    Set upon plinths of carefully stacked wood. Peaceful, but for the obvious marks of how the lives had been ripped from them. Not all bore fatal marks that could easily be hidden away. It was difficult to pretend it was simply sleep when the head was no longer attached to the shoulders. Or when a body had been split in two.
    But at the end of the day, the last rites were not meant to conceal the brutality of death. It was about honouring their passing while also giving them their means of travelling home.
    Had they died in the jungles of Lustria, the Southlands, or Madrigal, these rites would not have been needed. Tradition was to allow nature to take the dead and feed itself. All perfectly natural, a part of life. But this was not the homeland of the Children of the Gods. These were foreign soils. And so, the rites were needed, to help the fallen journey home, rather than rot in earth far from their spawning.
    Ingwel walked along the rows of funerary pyres, took the time to look upon each of the fallen warriors, to commit them to memory. It wasn’t normal for their kin to care so much for the fallen. Death was cheap. Another spawning always waited, fresh warriors to take their place.
    But five centuries of roaming foreign lands, never to return to the temple-city of their origin, never to truly interact with others outside of their host. He didn’t feel the loss as a warmblood would, but he did care. Just being a member of the Legion, whether it was by choice or decree, was in itself a sacrifice, and Ingwel would do what he could to remember the fallen for that sacrifice.
    Ingwel knew not whether the Children of the Gods had souls in the same manner as the warmblooded races. He wasn’t a theologian. He didn’t dwell on spiritual matters. There was an argument to be made that their souls were different, more directly entwined with the Old Ones, for they were created to be the servators of the gods, stewards of divine purpose, guardians of celestial design.
    Whatever the truth of it, Ingwel would honour the fallen through memory. And his memory, like the old stone paths of the Temple-City Tiamoxec, remembered every step that had come before.
    He committed each face to memory. Only then did he step back and signal the skinks. Torches touched timber—fire raced from pyre to pyre in a swift, hungry line, needing no coaxing; only fuel and purpose.
    ‘Far from home, they stood. Far from home, they fell,’ Ingwel spoke, his voice clear over the crackling pyres. ‘But they will not be forgotten. Not while we remain.’
    ‘We are the outlanders,’ the Legion’s survivors chanted.
    ‘We fight.’
    ‘We fall.’
    ‘We remember.’
    ‘We shall carry our dead,’ Ingwel continued as the flames’ heat prickled the membranes beneath his eyes. ‘Until those who have fallen are home once again.’
    ‘In memory. In truth.’ The chant rolled on.
    Resin-sweet smoke drifted skyward; the pyres roared. The chant faded into silence, and the fire did the rest.
    Thundi tried to ignore the scent carried on the smoke. Cremation. He repressed a shudder at the thought. Cremation was a last resort, a hurried means of depriving access to the fallen Dawi, only to be performed if time was truly against them.
    Dawi dead belonged in the ancestral catacombs, deep beneath the Karaks. Barring that, at the very least they should be buried beneath stone. Burning them to ash was to deny the body their proper place among the stone.
    But he held his tongue, kept an awareness that Dawi ways were not the ways of the other races, wrong as the ways of the races might seem.
    But it was difficult, not least because the cloying scent of charred flesh clung to his beard. It clung to his beard; he suspected it would be weeks before he could breathe without the stench.
    Despite his misgivings, he attended the last rites of the repki. Showed his respect, refrained from any act that might be taken for disrespect. No hypocrisy from this Dawi.
    A corner of his mind lingered on the words of the repki leader. Carry their dead? How? Carry the ashes in urns? Or carry them in memory?
    Whatever the answer, it wasn’t really any of his business.
    Once the formations dispersed, the formal part of the rites clearly finished and naught else left but to let the dead burn, Thundi took that opportunity to put some distance between himself and the pyres. As he predicted, the scent lingered in his beard, every inhale brought with it a reminder of the smell of the burning dead.
    He grumbled wordlessly, fit for a greybeard, and scoured the repki for a distraction. Anything to take his mind off the stench of burned flesh. Hopefully somebody who was more receptive to his presence than the large repki with the circular shield and the skirt. That one hadn’t been dismissive, but so stoic and quiet that he could have almost been mistaken for a statue.
    Most of the smaller ones seemed a little skittish, so he would prefer to find one of the larger ones. The “saurus” as they called themselves.
    Thundi’s eyes tracked a saurus who had perched himself on the outskirts of the encampment, sitting upon a large rock which might have once been part of a stone wall. The repki was running a rag down the length of a large sword. The movement was slow and methodical, done by rote. He was clearly so practiced in the act that he could perform it without paying any attention.
    ‘Ey up,’ Thundi called as he approached.
    The saurus blinked, then twisted his head to look upon Thundi.
    ‘Master Dawi,’ the lizardman greeted.
    ‘Thane Thundi Flintisson,’ Thundi introduced himself, while he moved around so that he was actually in front of the warrior, rather than force the lizard to turn his head. His new position allowed him a better look at the blade that the reptilian was so diligently wiping down, the faint scent of oil managing to bypass the lingering burnt flesh.
    ‘Colonel Solin, Outland Legion,’ the repki introduced in turn.
    ‘Interesting sword,’ Thundi spoke, to break the silence that followed, and open an actual conversation.
    And it wasn’t a lie. It was certainly an interesting weapon, an Empire styled greatsword, but forged from Gromril. Which meant that a Dawi had been the one to forge that blade. And it had been forged with the intention of being gifted.
    Dawi did not care for weapons that were only weapons of war. Hammers and axes could be used as tools of crafting, but a sword, particularly a sword like that, was only good as a weapon of warfare and violence. But that didn’t preclude Dawi from forging swords if they were to be given to umgi, be it gift or commission. One only needed to remember the existence of the Runefangs to know that.
    The repki made one final pass with the rag, then adjusted his grip on the blade and held it so that Thundi could better look at it.
    ‘It was a gift from a runesmith,’ Solin explained.
    ‘Forged specifically for ye, I can see,’ Thundi said after a moment.
    ‘Oh? How can you tell?’ There might have been a smile in the green scaled warrior’s voice, but Thundi wasn’t quite certain of that.
    ‘The proportions of blade and hilt. It was made with your size in mind, not an umgi.’
    Thundi mentally pictured the lizard actually wielding the weapon, and then pictured a human doing the same. He had a feeling that while the blade was long even by greatsword standards, there were a few ungi that might actually be able to use it, but it would take masters of their craft and for little gain. But in this reptile’s hands, it was the ideal size.
    Though, he could be mistaken. He hadn’t much experience with Empire greatsword wielders.
    The lizardman hummed in acknowledgement. He adjusted the weapon, a silent invitation for Thundi to take, to better examine. It was an invitation that the Thane accepted, though he refrained from trying to hold it with both hands on the hilt, instead moving one hand to the ricasso.
    He couldn’t help the impressed whistle. He didn’t care for swords, but as a Dawi, he would always have a deep rooted appreciation for anything well crafted. The runesmith who had forged this blade had not disappointed: this was a work of art.
    He angled the blade to take in the keen edge, nodding in satisfaction at the absolute craft, not a single blemish deterring from that straight cutting edge.
    And there was magic to the blade. It could have been Dawi runes, or it could have been an enchantment added after the fact. But the smith’s mention and the resonance Thundi felt left no doubt: this was true rune-craft, not the unstable sorcery of the other races.
    Curious, he prodded at the magic within the blade, wondering at the runes that he wasn’t able to see—maybe hidden beneath the leather sleeve that covered the ricasso. The weapon grew warm in his hands, he got the sense of the power in the weapon’s enhancement, but he wasn’t given a proper answer as to what the runes were doing for the blade.
    He offered the weapon back to its owner.
    ‘Beautifully made,’ he said without hesitation. ‘Ye must have earned quite the favour if this was gifted to ye.’
    Solin took the blade back and rested it across his lap. ‘He owed his family’s lives to my intervention.’ There was no bragging in the tone, a little discomfort perhaps.
    Thundi ignored the immediate question that arose from that, instead asked ‘Did this runesmith name it? I can feel its strength, and a weapon like that deserves a proper name.’
    There was a moment of hesitation. ‘He called it Valdrakk.’
    Thundi’s eyebrows lifted. ‘That’s a powerful name.’ He cast the blade another look, remembering the feeling of the runes. ‘Ye know what it means?’
    ‘Literal? Might-Rend.’ The lizardman answered. ‘Contextually? God-Rend.’
    Thundi’s voice lowered. ‘Dawi are very literal, we don’t pussyfoot around and wax poetic. If he named that sword “God-Rend”, it is because he believed the blade capable of living up to such a name. What did he say to you?’
    ‘That the three runes he used, were runes that he told himself he would use on the last weapon he were to ever forge if he had to take the slayer oath. And with those runes, he would go into the Realms of Chaos itself, find a god, and he would either find the death he sought, or he would become known as “God-Slayer”.’
    ‘A Slayer’s final forgework…’ Thundi murmured, more to himself than the saurus. ‘No Dawi would speak such words lightly.’
    He thought about that for a moment. Whoever this runesmith was, he must have been in a very dark place at one time to even consider that there might be a time he would take the slayer oath; most Runesmiths clung to craft, even through grief. He then laughed, dismissed such thoughts instead with the stated ambition.
    ‘T’would certainly be a worthy death of any Slayer, to spit in the eyes of the foul gods themselves. And these runes that he created are what he gifted to ye? Ye must have truly done him a service.’
    Solin’s eyes narrowed in the faintest grin. ‘His exact words were “my family means more to me than you can fathom. As thank you for their lives, I shall give to you a blade worthy of a warrior such as yourself”.’ The saurus crossed his arms. ‘I was surprised he gave me a zweihänder. At the time, I carried the same sabre as everyone else in the Legion.’
    Thundi stepped back, trying to see what the runesmith had seen—why he chose to give this warrior a weapon so unlike what he’d carried before. Ten seconds of examining, he decided that he couldn’t see it—the saurus had a size and strength to him, certainly, but compared to most of the other saurus in this Legion, he was leaner, and didn’t carry the look that immediately made one think of a greatsword user.
    But looks could be deceiving, and the saurus had very clearly become versed in the use of the blade since being gifted it, however long ago that was. And, ignoring the immediate lean looks of this saurus, a greatsword was definitely a weapon for a warrior, so Thundi supposed that in that respect, he could see that the smith knew what he was doing.
    ‘What can ye say about the blade’s enhancement?’ Thundi asked, curious.
    ‘It glows when anything empowered by Chaos is nearby,’ the saurus said. ‘I think it hurts daemons more than a normal blade would, but I will admit that I haven’t exactly had the chance to experiment. Daemons don’t really care for letting me test such things.’
    Thundi guffawed. ‘Aye, I would imagine not.’
    The lizardman shrugged. ‘Other than that, anything the runes have given are subtle or haven’t had the right opportunity to be used. The blade has a keen edge; never had to sharpen it. Whether that’s just good Gromril forging or a rune’s effect, I couldn’t say.’
    ‘And the runesmith never told ye what all it could do?’
    ‘I don’t think he fully knew himself. He knew the combination of runes he had created would be powerful, but… well, I suppose I’m technically the test-case for these runes.’
    It rankled, the idea of such raw power sent into the world without even a century of trials. Testing and refinement ought to be a process of many centuries, entrusted only to a carefully chosen few who understood what they were doing.
    If these runes truly warranted the name “God-Rend”, then testing them beyond the Dawi’s holdfasts should never have happened.
    But Thundi wasn’t about to second-guess a runesmith who, by all signs, had meant the runes only for a Slayer’s oath and nothing more. And family…? Well, for any Dawi worthy of their beard, family came before all else. If anything could coax a lapse in good, solid sense, it would be gratitude for kin spared from death.
    There was precedent, after all. Alaric the Mad had forged the Runefangs. Nothing of their like had ever been made again. Perhaps, given time, this runesmith might become another Alaric the Mad. But would that be a thing to celebrate… or to fear?
    ‘So,’ Thundi began, shifting the focus while keeping within the same vein of thought, ‘does this runesmith have a name?’
    ‘Runesmith Dromli Barazgrimm, of Karak Zurnaz-Dum,’ Solin answered after a pause, eyes distant, seeing something not there.
    ‘Karak Zurnaz-Dum?’ Thundi repeated, slowly, as if testing the words. ‘Hold of the Echoing Deep… Can’t say I’m familiar.’
    Solin shrugged. ‘Even after all my travelling, I wouldn’t pretend to know every karak or holdfast. It was somewhere in the World’s Edge, but I couldn’t point it out on a map. I never saw more than the entrance.’
    ‘Aye. Not many karaks care to invite in outsiders.’ Thundi considered for a moment what he had just heard. If this karak was within the World’s Edge Mountains, that meant that the runesmith wasn’t from the Norse Dwarfs, which had been his initial assumption.
    ‘Mhm…’ Solin shrugged again. The oiled rag was returned to his hand, and was run down the length of the blade. Though his eyes remained on Thundi, a wordless message that he wasn’t being ignored or dismissed, but the repki hadn’t anything left to say.
    Thundi was sure if he continued to speak the saurian would continue to engage, but the repki had already returned to his own thoughts.
    Ingwel entered his tent, unconsciously unfastening his scabbard. He was just in the process of laying the blade atop his bunk when he registered that there was somebody else in the wagon. Scarlet eyes came to focus upon Iycan, who almost looked unrecognisable while he wasn’t wearing his coat and flatcap.
    Iycan lifted a hand in greeting. ‘Marshal.’
    ‘Colonel,’ Ingwel answered in kind.
    Iycan lowered his hand, then lifted the opposite, held out a steaming cup of brewed beverage in silent offer. Ingwel accepted the offering, took a sip of the tea and hummed in satisfaction.
    ‘What’s the bad news?’ he asked.
    Iycan pouted. ‘I don’t only come to you with bad news.’
    Ingwel cast a look at the skink over the tea cup, brow ridges raised as much as his features allowed. So you decided to bribe your way into my good graces first because you had good news?’
    Iycan held his pout for a few moments longer, then shrugged nonchalantly. ‘Actually, the drink was just to warm you after performing the last rites for so many.’
    Ingwel took another sip, enjoying the warmth that spread through his body.
    ‘But…?’
    Iycan rolled his eyes. ‘You simply can’t take a moment of peace without anticipating what comes next, can you?’ he asked, more rhetorically than genuinely. After another couple of seconds, his posture straightened. ‘Attendant Klixx’takka is summoning you.’
    Ingwel’s eyes narrowed briefly in consideration. ‘He just started summoning now?’ he wondered.
    Iycan made a sound of disagreement. ‘I think he summoned you a few hours ago, but since we were rather busy…’ he trailed off, motioning a hand into a vague gesture of “what could we have done?”. ‘I only noticed just before you went to give the last rites. Felt that he would understand being delayed an hour longer in light of that.’
    Ingwel gulped down the last of the tea, then flicked the cup outside of the tent to remove the dredges. ‘Well, let’s not keep him waiting any longer.’
    He allowed Iycan to lead him from the tent, towards a particular wagon stationed a small ways away. It was one of the larger wagons that the Legion had, large enough that it was typically hitched to a stegadon rather than to any of the juvenile or riderless aggradons. It was also noticeably armoured, being the only wagon that had steel plating covering the outside, rather than the simple wooden structure of all the others.
    Iycan pushed open the door into the wagon, held the door open for Ingwel, who breezed past him.
    The inside was almost underwhelming, for all that this particular wagon was armoured and clearly important. One side was lined with chests, neatly ordered. And at the back, there was a pedestal with a glass sphere. Normally, this sphere was clear, a simple ball made of glass with no apparent utility.
    At that moment, the glass swirled with blue mist, pulsing faintly, like a distant heartbeat.
    Iycan positioned himself next to the pedestal and rested his hand upon the glass sphere. A low hum followed. Then the mist seeped outward, filling the centre of the wagon. Slowly, it coalesced into the form of a skink.
    From what Ingwel understood, a twin sphere in a chamber back in Tiamoxec would now be doing the same—mist curling into the forms of Iycan and himself.
    As convenient as the artefact was for conversing across the span of continents, the spheres were not something which could be recreated, and they required the power of a slann to be used in such a manner, to empower one of the spheres for use. Without a wakeful slann to empower them, they were limited to delivering short messages rather than holding conversations. Which was still useful, as it allowed the Legion to know when a ship with new warriors to join their ranks was coming, and where they were planned to be offloaded.
    Ingwel examined the latest of Lord Annat’corri’s personal attendants, curious about this latest to take the position.
    Klixx’takka was a touch taller than was normal for a skink—if anything he looked more like a red-crested skink, judging by his size alone. His scales were a vibrant yellow, with a healthy sheen, and his arms were covered in the traditional tattooing of the priesthood. As was befitting his station as Annat’corri’s personal attendant, he wore a toga, rough-spun and dyed a rich blue.
    Though interestingly, his tail was stubbier than a skink’s tail should be. At some point he’d been injured and lost his tail, and as typical the regrown appendage wasn’t a perfect match for what had been lost. It was a minor detail, but it caught Ingwel’s eye nonetheless. It told him that this attendant was not the type to remain aloof and distant from physical work. Not if he had put himself in a position where losing his tail was something that could happen.
    Marshal Ingwel’tonl.’ Klixx’takka greeted, twice tapping his right fist against his left breast in a gesture of respect.
    Attendant Klixx’takka. Honoured to finally meet the latest to rise to Annat’corri’s attendance,’ Ingwel said in High Saurian, repeating the gesture.
    The projection of Klixx’takka grimaced. ‘No, no… feel free to speak in the warmblood tongue. And call me Klixx.
    Ingwel and Iycan shared a look of slight startlement. ‘As you wish.’
    Klixx’s eyes curved into a grin. ‘It is an honour to finally meet you, Ingwel’tonl. I have heard many stories about your successes.
    ‘Must not have been from your predecessor then,’ Iycan commented dryly.
    Ingwel refrained from rolling his eyes at the reminder of the sour skink who had previously held the position. While he’d never had the opportunity to speak in a real-time conversation with them, he had made it very clear through his messages that he was a particularly sour traditionalist who had never approved of the Legion’s purpose. A traditionalist whose entire career had been without Annat’corri’s guidance; the slann having been in mediation for the prior century.
    It had been something of a guilty relief when Attendant Haar’tas had died four summers back. Just two moons before Annat’corri’s latest awakening. Far be it for Ingwel to think ill of his kin who had shed their mortal coil… but a vindictive part of him was glad Haar’tas never got to meet the Slann Starlord.
    Klixx’s expression turned pinched. ‘Ah, no. Mostly from Captain Horeo and his crew. But I also read the reports you have sent over the centuries. Quite the library we have built up.
    Ingwel blinked in surprise, not having been aware that the scrolls he sent to Madrigal had been saved. In his mind, they were dispatches. Ephemeral, duty-bound reports. Not something worth preserving.
    At most, he would have figured certain details might have been rewritten and stowed away, information about the world beyond the isle of Madrigal. But not the whole reports.
    ‘Well,’ he said after the pause where he had absorbed that last detail. ‘That’s interesting. Glad you enjoyed the read.’
    Klixx chuckled a rasping, sibilant laugh. ‘I truly did.’ After a moment, he composed himself, absently tugging at his toga as though to flatten it of any creases, while his posture adjusted to one of composure. ‘As much as I would love nothing more than to talk history and praise your work, I am sure you can imagine that I summoned you to a converse for a reason.
    ‘It had occurred to me, yes,’ Ingwel said.
    Klixx’s eyes curled into an amused grin for a full two seconds before he again looked serious. ‘I do not know if you were able to see it where you are, but the Forked Tongue of Sotek was seen.
    ‘The Twin-Tailed Comet?’ Iycan’s voice sharpened, eyes wide.
    Klixx’s projection nodded. ‘It wasn’t visible from Madrigal either, but across the World Pond, it was seen clear as day.
    Iycan tilted his head in thought. ‘We heard that Mazadmundi was preparing for something, to the point that he had Kroq-Gar sent to the Kingdom of Beasts. Is this related?’
    Klixx hummed. ‘Possibly. But the appearance of the comet usually heralds times of great strife and change. The Lustrians have not asked for our assistance in whatever mission they are performing, and that is fine. Allows us to work on any other problems that might arise in the wake of the comet. You yourself are fighting a Chaos Warhost. How fares that?’
    ‘We just finished a battle with them,’ Ingwel reported. ‘And we have taken a lot of casualties.’
    Klixx winced in sympathy. ‘Which brings me to the part that concerns you directly. In the wake of your skirmishes with the Warhost of Malice, news of the God-Bear of Kislev being fatally wounded, the comet making an appearance… Annat’corri’s fellow slann on the Triumvirate have increased their support for your temple-host and the mission you are performing.’
    Ingwel narrowed his eyes in curiosity. ‘What does that mean for us?’
    For your standard day-to-day? Not much difference. You will still be doing as you have been, the mission of the Legion remains unchanged. But here in Madrigal, we are… adapting. You will, if all goes as planned, be getting your numbers replenished and bolstered more often than you were.’
    ‘No attempt to create a second host in a different region?’ Ingwel asked, remembering the failed attempt to create such a temple-host in the Far-East, in Ind.
    Klixx guffawed. ‘Better to let your Legion grow and if it reaches the point where you feel it capable of surviving, having a second host split off from you.
    ‘You say we’ll get replenished more often? When does that start?’
    Klixx’s projection looked at something that was unseen to Ingwel and Iycan, and then returned his attention to the two. ‘We are running short on time to talk. Horeo can explain the changes in better detail when he next delivers some numbers to bolster your Legion. You are still in the Empire?’
    Ingwel nodded. ‘We are.’
    He glanced off to the side again, checking something beyond their view. ‘Give the name of the next port or coast you will be visiting, and Horeo will meet you there. He needed to meet you sooner rather than later anyway, so that he can bring the gold plaque you found to us.
    ‘True,’ Ingwel acknowledged. ‘I’ll message with the most convenient place for Horeo to meet us once we have an idea of that ourselves.’
    Klixx nodded once, then tilted his head. ‘How is young Bonaeaix? ’ He asked, voice softening slightly.
    ‘Boney? He is doing well for himself. By all accounts he’s adapting quite well.’
    I am glad. I am aware that I did not give any warning that I was sending a priest over as a replacement for Yade-to, but it was a… spur of the moment decision. After what happened, I felt Bonaeaix—Boney, was it?—needed the change.
    ‘Well, as I said, he is adapting well to the more unorthodox nature of the Legion,’ Ingwel reported. ‘He is looking to become an artillery commander.’
    At the report, Klixx’s eyes narrowed into a happy smile. ‘That is good news indeed. He had such potential, it would have been a shame if he never lived up to it because of the arrogance of one fool.
    Ingwel hissed in agreement, having learnt of the damage done by the saurus who had earned Scar Veterancy at far too young an age, though this was the first that he’d learnt that Boney had been caught up in that, it unfortunately did not surprise him when he recalled the twitchy nervousness Boney had around saurus. He was getting better, by all accounts, but there was still an underlying tension that might never fully fade.
    Some hurts never healed.
    But so long as Boney continued to know how to bury that discomfort deep, he’d manage.
    Again, Klixx’s eyes focused on something that wasn’t projected along with him. ‘The charge is nearly gone. The moment you message me with the port or coast, I will have Horeo depart.
    Ingwel’s head bobbed. ‘I’ll give it once I have an idea on that myself.’
    Klixx grinned again. ‘I am looking forward to working with you, Marshal Ingwel’tonl.’
    Before Ingwel could answer, the mist which formed the projection dispersed, losing all colour and fading into the air as it spread.
    ‘Huh…’ Iycan grunted. ‘He’s enthusiastic.’
    Ingwel grinned wryly. ‘I like him. He isn’t treating us like exiles.’
    Iycan returned Ingwel’s grin. ‘Certainly a breath of fresh air.’
    Both exited the wagon. Ingwel’s eyes immediately moved to where the pyres had been burning. He took in the fact that the flames had died down and the skinks who had been tending to them were now collecting the ashes of the fallen. He breathed in, and then exhaled heavily at the reminder.
    ‘Spread the word: we remain here tonight, to give time for the ashes to be gathered and pressed. Tomorrow we are moving out.’
    ‘Where to?’ Iycan asked.
    ‘Back to Middenheim,’ Ingwel declared in surety in his tone. ‘The Dawi throng can continue to chase down the warhost in our stead, we need to find out what happened to divert Todbringer, and it’s about time we found Sharpe, if the undead have truly stopped prowling in the Drakwald.’
    ‘Got it,’ Iycan said with a nod.
    The skink turned on his heel and moved to pass on the order. Ingwel breathed in again, tongue flicking unconsciously. The scent of the departed dead still lingered in the air, in the smoke that still wafted in the breeze.
    So many dead. Arguably the most to a single engagement in the five centuries that the Legion had existed in any form. Was it truly a victory? The warlord leading the Chaos host had survived, yanked from the battlefield by that mage. And from the reports given by Solin, Boney and Mort, none of the other Exalted Champions had fallen either.
    So, the question was: how costly was the victory, and was the cost worth it?
    The question didn’t change anything. If he had to live the day again, he’d still fight. Worth or not never entered into it.
    thedarkfourth likes this.
  8. J.Logan
    State of the World – Silence in the Library
    Skavenblight
    Deep in Skavenblight, one skaven was deemed untouchable. No skaven, whether brave, ambitious, or just plain foolish, dared lay a claw on him. For even if they succeeded in harming him, the Council of Thirteen would, for once, agree. They would seize the offender. They would make an example of him. A slow, agonising example—one even the Prince of Excess might look away from.
    He wielded no great magic, commanded no armies—yet he was powerful in a way no skaven had ever been. So much so that the Council of Thirteen could not risk losing the resource he had become.
    He was something of an anomaly. A rare success story for a skaven. He did what had never been done before in all the skaven's history.
    He clawed his way up, teeth bared and tail curled, rising through the ranks like a plagued rat in a grain silo.
    He began as a clanrat—barely above a slave. But he accumulated power. He rose so high, his usefulness could no longer be ignored.
    Even without the protection of the Council of Thirteen, this skaven was noted. Every warlord, every Grey Seer, every ambitious skaven—all saw his value. And they knew it needed to be preserved.
    Thus he stood now as the single most protected person in all of Skavenblight.
    And at that moment, he was laughing maniacally.
    'Yes-yes! My collection is complete!' he squeaked most triumphantly, gnarled and aged hands gently brushing against his new prize, as though to confirm it was real.
    It was.
    This skaven—his name long lost even to his own aged mind—had lived well beyond his natural lifespan, extended by the rare privilege of imbibing the life-elixirs usually reserved for powerful Grey Seers.
    He had once heard a phrase. He had taken that phrase to heart. Dedicated himself to that phrase.
    Knowledge is power.
    And thus, he had set out to become the most knowledgeable of skaven. And in doing so, he had secured himself a niche that had never before been filled. A skaven with such knowledge, that every skaven with ambition turned to him for a sliver of that knowledge.
    He was The Librarian.
    And in his library, he was king above even the Council of Thirteen.
    Not that they particularly cared for when he reminded them of that, but he was old, he was aching, and all he really wanted was to sit back and enjoy a good read, but all these skaven kept coming to him, nagging him for details of this prophesy, or that ancient elf artefact.
    It didn't help that he honestly remembered every living skaven of significance when they were pups.
    Laughing some more, he opened his new tome with reverent care. Gold-embossed letters flickered briefly in the torchlight before vanishing beneath curling fingers. What foul words and secrets might be spilled from this tome that he expressed such glee to have in his ownership?
    He began to read the words aloud.
    'Medical Journal of the Tilean Universities, thirteenth edition.'
    A flick of a page.
    'Ooh, they got a new artist-sketchist this time. Good-good. Aaah… anatomy chart!'
    The Librarian leaned closer, eyes widening in a mixture of glee and curiosity at the detailed rendition of a human woman's anatomy.
    'Why man-things so obsessed with lump-things…?' he muttered.
    Had he been human, the scene might have sparked scandal or suspicion. But he was skaven, and his interest was only in the momentary flicker of curiosity at the strangeness of man-thing biology. Still… he didn't do himself any favours. If by some impossible fluke a human woman did wander in and he was caught like this, he'd likely be the first skaven cuffed across the muzzle for indecency.
    The door to his domain creaked open. The Librarian reluctantly pulled his gaze away from the fascinating tome, eyes already narrowing into an unimpressed glower. That glare only intensified at the skaven who sauntered in with a swagger that the Librarian did not believe this particular skaven deserved.
    'Behold, yes-yes! The Horned Rat's chosen has arrived!' Thanquol announced, arms spread as though expecting a choir of squeakers to sing his praises.
    The Librarian had once told Lord Gnawdwell, to his face, just how little he thought of Queek—Gnawdwell's favoured whelp in all but name. Without a moment of fear for upsetting the powerful lord of Mors.
    Then again, the Librarian remembered when Gnawdwell was a pup. A drooling brat who once chewed one of his rare tomes. The Librarian had never let him forget it. And if the Librarian was so bold to Lord Gnawdwell, what hope did the overly egocentric—even by skaven standards—Thanquol have?
    'Oh. You.' The Librarian's tone could have soured milk. He turned back to the sketch, gaze flicking to the more… protruding anatomical features, brow furrowed in thought, questions in his mind about their purpose. 'What do you want-want?'
    Thanquol's posture slumped—momentarily—before his towering self-importance swept in to patch the cracks. 'I need-need information. Have schemes!'
    The Librarian paused, eyes rising back to Thanquol's overly smug muzzle. 'No.'
    Thanquol blinked. For a moment, his brain experienced a lapse in function—though, given the organ's usual state of disuse, "lapse" implied a standard it had never quite reached.
    'What do you mean, no-no?!'
    The Librarian raised a claw. 'Last time, Thanquol asked about elf-thing Menhir. I told-taught. Thanquol failed—not even to dwarf-thing Thanquol whines-cries about, but to man-thing named Bernhardt.'
    Thanquol's fur puffed in indignation. He opened his mouth, but the Librarian raised a second claw.
    'And last time Thanquol entered my library, Thanquol sprayed musk all over rare-precious books. Pages curled. Stink-smell lingered for days. Thanquol is banned.'
    The Grey Seer cycled through an impressive array of facial expressions—confusion, outrage, wounded pride—before settling on a haughty sneer that barely concealed his irritation and desperation.
    'Grey Seers whisper-plot, yes-yes! Secrets in shadows—I must know!'
    The Librarian huffed in amusement and considered his words carefully. Then, with a look of absolute smugness, decided to give the most honest answer possible. Not because it would help Thanquol, but because it wouldn't.
    'I know nothing.'
    Thanquol sputtered impotently. 'What-what?'
    The Librarian gave Thanquol a look of pure contempt, hidden behind smug glee. 'Grey Seers have their own sources. Not always come to me-me. Only Grey Seer I've seen in months is you-you. So I know nothing. Nada. Not a thing. Very rare, I know-know. Cherish this moment, yes-yes.'
    The door behind Thanquol creaked open, hinges groaning like a reluctant mourner. Both Thanquol and the Librarian turned as another skaven slipped inside. Slight of frame, garbed in dark, tight leathers, a hood low over their head. Twin daggers—likely warpstone-forged—sat sheathed at easy reach, though anyone with sense knew those were just the visible ones.
    The Eschin assassin froze mid-step, pink eyes blinking with visible confusion at the sight of Thanquol.
    'What is useless-irritating Grey Seer doing here?'
    The Librarian let out a breath that almost sounded like a guffaw. Thanquol meanwhile choked on nothing, save perhaps his pride, trampled underpaw and roughly shoved down his throat.
    A beat of silence passed. The Eschin's eyes narrowed slightly.
    'Leaving,' the Librarian said at last, with the finality of a slammed book.
    Thanquol twisted around to glare at him, fur bristling. 'No-no. Still need knowledge!'
    'That I do not have,' the Librarian drawled. 'Go ask-request your fellow Grey Seers. Or the Council.'
    His tone suggested Thanquol would find more wisdom scraping the bottom of a latrine than by continuing to pester him.
    Thanquol continued his impotent sputtering, but did not raise a claw against the Librarian. He gave the assassin a withering glare, as if placing blame for his latest humiliation. The assassin didn't look like a single care was given. At the lack of respect, or even any fear regarding him, Thanquol stormed out of the library, cursing in Queekish, along with vague "promises" of what would happen to those who dared to embarrass him so.
    The Librarian ignored the white-furred rat. It was easy. Though he knew Thanquol would be back after he'd salved his bruised ego by venting on some poor clanrat. And by "venting", of course, he meant shoving said clanrat down the ducts of a warpstone refinery. But that was a problem for Future Librarian.
    He turned back to his book, only to sigh and slump as he noticed the assassin still loitering nearby, radiating something that almost resembled patience.
    'What-what?' he grumbled, adjusting his spectacles and casting a mournful glance at the still-unread medical journal. 'You come-seek knowledge, you pay-bribe first!'
    The assassin fished around in the bag worn at their hip, and pulled out a small book. The book was held out in silent offer.
    'Need knowledge. Trying to find-seek a name.'
    The Librarian stilled, managing to catch a glimpse of the title pressed into the cover. 'Is that the newest play by Guillaume Chavalspere?'
    The assassin hummed. 'Good pay, yes-yes? You help?'
    The Librarian snatched the book from the assassin's grasp and carefully opened the cover. Eyes immediately landed on the circular mark that Guillaume Chavalspere personally signed all the first print copies of his plays with. It wasn't just real, it was a first edition. A small squeak of joy escaped the Librarian's muzzle, and he forgot all about the medical journal.
    'How can Librarian help-assist assassin today?' he asked with a far more chipper attitude than he'd had previously.
    The assassin looked nonplussed at the joy that the Librarian displayed—but it was remarkable how few skaven understood the joy of a good book, so the indifference was long since numbed to—and instead crossed their arms.
    'Hired by man-thing. Looking for name.'
    The Librarian hummed, carefully resting the tome upon his desk, while also filing away the detail given away. Hired by a man-thing meant this Eschin rat was one of those who acted as free-agents, hiring themselves out to the man-things for odd jobs. Usually because it still benefited the Under-Empire in some way, even if that way was simply "helped man-things kill other man-things".
    'What name?' he asked.
    The assassin scowled. 'Strange name. Classical language. Pugna Textrix.'
    The Librarian tilted his head, then huffed. 'Not real-true name, then. No man-thing uses Classical for names.'
    'Maybe not,' the assassin admitted. 'But maybe a translation of real name?'
    The Librarian frowned, rifling through his mental archive of ancient tongues. 'Means "Battle Weaver". Or "Fight Weaver". No exact word, just the gist.'
    The assassin snorted. 'Still not real name. So… where you going?'
    The Librarian stalked deeper into his library, already heading toward a specific section. At the assassin's question he paused only to beckon irritably.
    'Heard that name before,' he muttered, tone turning thoughtful. 'But old. Older than most man-things. Should be dust-bones now, yes-yes.'
    He led the assassin to a corner where no shelves stood, only long drawers stacked floor to ceiling. Scrolls and loose parchment slept there, brittle and at risk to careless claws.
    After a pause, the Librarian tugged one open and deftly flicked through the crisp sheets within, claws gentle but sure. He selected one, laid it on a stone table, and weighted its curling edges with two heavy stones.
    The assassin peered over, whiskers twitching. 'Arabi?'
    The Librarian made a dismissive hum, eyes scanning fast. A claw traced the script as his lips formed silent shapes. Then he paused, eyes sharpening, and slid back to the start. The assassin leaned closer than courtesy allowed, ears angling forward as the first lines rolled from the Librarian's throat, voice absent any of the usual traces of Queekish accent or the verbal tics that usually came out when a skaven spoke in any other language. As he read, it was as though he were speaking in the voice of the one to write those words.
    'The sultan of the city of Qalat Ishra has been overthrown by his chief military advisor in a deadly coup. The advisor, Don Alarico de Zorilla, known largely by the title of "the Battle Weaver", is an Estalian man of unknown lineage. His mastery of both war and subtlety earned him the trust of the court until, by silken word and iron blade, he seized power outright.
    'Yet his reign was brief. Five summers passed, and now all that remains of Qalat Ishra are sand and ruins. It is our opinion that the gods punished the Battle Weaver by taking from him what he wrongfully stole.'
    The Librarian paused a moment, mouthing the name of the city to himself before scampering to a different drawer and pulling free yet another sheet of parchment which was placed overtop the first. The font was again Arabi, though a seal at the corner of the parchment marked it as being penned by a different author.
    'This is our report on the events that led to Qalat Ishra's ruination. We have interviewed countless survivors in our effort to understand the chain of events that began with the usurpation at the hands of the one called "the Battle Weaver". For five years, the city actually prospered under its new lordship, and most of the citizenry weren't even aware of a change in their ruler. Whether this is a mark against the previous sultan's presence in his own city, or a mark of the Battle Weaver's cunning, we cannot determine.
    'But on the fifth year of the Weaver's reign, something changed. Though most everybody interviewed couldn't say what it was that caused it, all described a feeling of dread, a sense of heaviness to the air. The more magically inclined were more informative: magic was being drawn in, and gathered at the sultan's palace.
    'Then came the catastrophe. Survivors describe explosions within the palace. A tower collapsed. Creatures appeared in the streets. At first thought, it was believed that these were Chaos daemons, except no description from any of the survivors matches any reported daemonic form, described instead as beings made wholly of sand.'
    The assassin made a scoffing sound. 'Sand? Sand not dangerous.'
    'Shh,' the Librarian sounded out, irritable at being interrupted. After a handful of seconds spent giving the assassin a baleful glare that had them squirming uncomfortably, he turned back to the parchment and resumed his reading.
    'Again, the magically learned offered more detail. One spoke of a Greater Daemon of Tzeentch, a "Lord of Change", fighting the Weaver's guard upon the palace rooftops. Yet this witness admits he could not see clearly, being engaged in the city's evacuation.
    'By the day's end, Qalat Ishra was saturated in energies that now repulse efforts to reclaim the city from the sands. Sandstorms that are surely not natural are now a constant sight, as if baring entry to all. The Weaver is presumed dead, and it is the official stance of the sultanate of Araby that this be deemed the will of the vengeful gods against the Battle Weaver.
    'Unofficially, it is known that Qalat Ishra guarded the Eternity Sands. It is believed the Weaver seized the city to reach them. Whether his ritual was flawed or corrupted by the Lord of Change, the result was the same. The veil tore, the daemon came through, and all within its reach were remade—mutants of sand and malice.
    'Survivors are held in quarantine. Should they prove free of corruption, they shall be resettled under watch. Should they show sand-blood or unholy signs, they will be silenced for the good of all Araby.
    'Thus: let the dunes of Qalat Ishra stand cursed and untouched. Let no pilgrim, scholar, or relic-hunter trespass there, lest their flesh, mind, and soul be forfeit. May the gods forgive us for witnessing such ruin.'
    The Librarian's voice fell silent. He lifted the parchment again, eyes narrowing in thought, then hummed under his breath and turned to the assassin.
    'Weaver-thing last seen in cursed sand city.' He shrugged.
    The assassin's pink eyes lingered on the parchment, though unable to read the scribed words. 'What exactly are these Eternity Sands?'
    'Araby-things legend. Sands that gods touched, now time not work on. But lost-gone now. In Qalat Ishra.' The Librarian paused a moment, then huffed out a laugh of dry humour. 'Think Mordheim, if half-buried in dunes-sands.'
    The assassin tilted their head back, eyes narrowed in consideration. 'Interesting-intriguing.'
    They reached for the parchment, whether to steal it away or simply squint at words they couldn't even read, the Librarian neither knew nor cared. The result was the same either way: a sharp slap to the paw creeping too close to ancient vellum.
    The assassin yelped, more startled than hurt, and snatched their paw back, shaking it vigorously as if to banish the sting.
    'Why Librarian keep old parchments?' they asked, voice edging towards a sulk.
    The Librarian sniffed, tail flicking with proprietary pride. 'Knowledge is power and power is mine-mine.' He carefully picked the parchment from the table and moved to return both sheets to their appropriate drawers. 'Hard work keeping knowledge-power. You want to hoard books and papers? Remember where they all are kept? Remember what you have?'
    The assassin grimaced. Understandable. The Librarian well knew that his kind found such work thankless, far too tedious for power that wasn't loud or immediately lethal.
    And that, truth be told, suited him perfectly. Fewer rivals sniffing at his shelves.
    With a final harrumph, he slid the drawers shut. 'You have what you asked-asked. What now?' Even as he spoke, he scuttled towards a cluttered desk littered with blank parchment and a battered inkwell.
    The assassin's eyes narrowed again. 'How do I find if Weaver-thing,'—they paused, searching the empty tabletop as though the parchment still lay there—'Don Alarico de Zorilla, littered before dying? Pups left behind?'
    The Librarian grunted wordlessly, snatched a ragged quill from the inkwell, and scratched out a few words with brisk strokes. Finished, he thrust the parchment at the assassin.
    'Go-seek the Cathedral Archives of Magritta, yes-yes! Estalia's so-called capital. Priests there hoard birth-writs, marriage-writs, noble scribbles, even scandal records. Oldest archive south of the Grey Mountains. Bribe a scribe, maybe break a priest's nose, then maybe they let you peek-peek at dusty family trees. And'—he bared yellowed teeth in a humourless grin—'bring me something shiny as payment when you crawl back.'
    The assassin took the parchment, absently reading the words inscribed upon it. If they were expecting anything other than a written reminder of what the Librarian had just said, they'd be disappointed. After a handful of seconds, the assassin looked back at the Librarian and opened their mouth, though to say what, the Librarian didn't know.
    Several seconds later, the assassin closed their mouth and stalked away with a mumble, the words of which were lost to the Librarian. The door to the library parted and then closed again with the passage of the assassin. The Librarian shrugged and returned to his desk.
    He missed the shadow that peeled itself away from the wall and slid beneath the library doors.
    All told, the entire ordeal had actually been quite a pleasant transaction, by skaven standards at any rate. Especially by skaven standards. There hadn't even been any weaponised harsh language!
    He cracked open his new prize. He had just managed to skim the first line, when he looked up, eyes narrowed in thought.
    'What are Grey Seers plotting-scheming?' he wondered aloud.
  9. J.Logan
    The Other Side - Duty's Pause
    Backertag, Erntezeit 27th, Outside Middenheim
    The battle for Middenheim lasted two days without pause. The defenders fought with the strength of heroes, but even they could not hold back such a tide forever. The inevitable result would have been the city's fall, drowned in bodies that felt no fear, no pain.
    The turning point came at the dawn of the second day. Graf Boris Todbringer returned. I wasn't there to witness it, but I am told that the Grand Duke personally led the charge into the flank of the undead, and cut down scores with each swing of Legbiter, the blade shrieking through steel and bone alike. There are whispers that for a brief moment, Todbringer had become a vessel for Ulric himself, channelling the strength of the White Wolf into each strike of his runefang.
    After the battle's end, his fury did not leave. He was heard demanding that all the fallen on the field be put to the flame without delay. According to Gerwin, there are rumours that this entire battle was just a diversion from the undead's true purpose. But what could that purpose have been?
    I would have dismissed it, but Captain Sigismund has been in a foul mood ever since he spoke to a member of Todbringer's court. The Efror Guard among us have picked up on his mood. I keep hearing the name "Fenchel" whispered among them.
    The necromancer does not seem to be among the dead, so our duty remains. But we are only human, so Captain von Eisling would have us rest up for a day before we move on. I would wager the real reason for the rest is that she and Sigismund need time to decide where we march next.
    Still, I shan't be complaining about the opportunity to put my feet up for a day or two. If I'm lucky, maybe I'll get a glimpse of the regiments of renown who had been fighting the Chaos warhost to the north.
    -Journal of an unknown soldier
    Gerwin felt his eyebrows rise to his hairline at the state of the room. For the most part, it looked neat, orderly. Everything where it should have been.
    He hadn't interacted much with Robert Fenchel, before everything had gone to hell. Cruniac had been the one to interact with the young ward the most, had taken on an almost fatherly role. More so than Count Feyerabend had ever done despite his intentions and being the one to take in the young man.
    Had to shake off the moment of ill feeling that rose up on thinking about Cruniac, still missing since that trip to the Feyerabend Keep.
    Yet Gerwin knew Fenchel well enough. The lad had always been meticulous, fastidious about keeping his space tidy. So the sterile neatness of the lodgings—that tracked.
    What didn't was the mess on the floor.
    It was vaguely human in outline, but the texture was wrong—crumbled flesh, slack and collapsing, like wet sand that had forgotten how to hold a shape. He had the sudden, sick thought that a breath might scatter it. Gerwin's stomach lurched.
    Sigismund swore under his breath, crouching next to the mess, though pointedly not touching it. 'You're certain that this is Fenchel?' he asked, though his tone suggested that he already believed the remains to be the young ward.
    Lord Rauscher—the man who had apparently been Fenchel's main contact with the Middenheim governance—shrugged. He hadn't moved from the doorway from the moment he had shown the two guardsmen in. Even now, he was simply standing there, back straight, eyes fixated on Sigismund with just the slightest hint of being narrowed.
    'About as certain as one can be, when there is no way to see the face.' He finally spoke up.
    Gerwin grunted agreement. The details were long gone. Unless someone else had broken into these rooms and died through some bizarre sorcery, there was little doubt. Though despite that, something still nagged at Gerwin, some subconscious feeling that he wasn't seeing something right in front of him.
    'How many people knew you'd stashed Fenchel here?' he asked.
    'Myself and four guards. Men I trust implicitly.'
    'Where are they now?' Sigismund's voice was flat—utterly blank. That tone meant danger. It meant that despite his rising fury, he was still thinking, still choosing where to aim that fury.
    And right now, he had no target.
    'Three of them are dead, the last is on death's door. Still hasn't awoken from the blow he took to the head fighting the undead.'
    Gerwin cursed under his breath. 'You might trust them… they might have even proven themselves deserving of that trust. But with witchcraft and sorcery afoot,'—he motioned at the mess—'they might have had the knowledge ripped from their minds. And their dying in the siege was a convenient way of hiding away the evidence of such.'
    'Not that this sorcerer is overly concerned with being hidden.' Sigismund scowled.
    Gerwin's head briefly tilted in agreement yet again.
    Rauscher exhaled through his nose and finally stepped inside. Up close, Gerwin realised the man's girth hadn't dulled his imposing size. He was broader and taller than Sigismund. He stopped between the two Guardsmen, arms folded, glaring down at the remains.
    'Why this fixation on a mere orphan?' His tone made it clear he would accept nothing less than a full explanation. 'Fenchel himself was under the impression it was because of his survival of your keep's chaplain's murder attempt, and how he knew the truth. But I have it on good authority that the chaplain is dead now, along with most of your county. Yet somebody hunted him down even here in the heart of Middenheim. Why?'
    Gerwin leaned forward enough to share a look with Sigismund, then shrugged a single shoulder: Your call. Sigismund rolled his eyes and stood up, turning to fully face the Middenheim courtier.
    'I suppose there is little harm in speaking of it now,' he grumbled. 'Robert Fenchel was the last living member of the Adelbrecht lineage.'
    Rauscher's lips flapped wordlessly, then pressed into a thin line.
    'Adelbrecht as in the Mad Count whose actions led to the Razing of Efror?' the lord asked, dryly.
    'The very same.' Sigismund's stare dared him to speak ill of the name.
    Rauscher bowed his head, frowning in thought. 'I was under the impression that the Feyerabend family carried Adelbrecht blood. That's how they inherited the land and title, isn't it?'
    Gerwin answered this time. 'Of a sort. A daughter married into the Feyerabends—that was the inheriting claim. But eventually a step-son inherited. No Adelbrecht blood left in the name.'
    'And Fenchel?'
    'A bastard. From a bastard line through his father's side.' Sigismund nodded. 'Count Feyerabend couldn't father children. So, he raised him with every intent to legitimise him. To return Efror to the original bloodline.'
    Rauscher's mouth tightened. Disapproval, perhaps at legitimising a bastard… or at reviving a line that ended with madness and fire. Gerwin couldn't say which.
    'It seems somebody has been insistent on hunting the bloodline,' Rauscher finally spoke up again. 'This necromancer has certainly proven himself to be fixated on your county.'
    Gerwin barked a single, sarcastic "hah". 'Fixated might be underselling, m'lord.'
    Sigismund looked like he had just smelt a particularly foul odour. 'Seeing undead wearing our colours has been an Ulric-damned insult.'
    Gerwin glanced down again at the ruin on the floor, the edge of which seemed to have sagged further since they'd entered, and changed the subject. 'Any evidence pointing to who did this, besides the obvious suspect?'
    Rauscher shook his head. 'None. And if it was the necromancer… what would they gain by sneaking into the city—mid-siege—just to kill him?'
    Gerwin blinked, then turned his head to share a look with Sigismund, whose expression had evolved from "foul smell in the air" to "had just swallowed a lemon whole".
    'If it was worth that risk,' Gerwin said slowly, 'then maybe it's not just about wiping out a bloodline.'
    Rauscher's lips stretched into a humourless smile. 'Indeed.'
    Gerwin let the thought hang in the stale air, the weight of it settling over the three men. The wind outside rattled a shutter, the only sound in the stillness. Sigismund straightened and brushed past Rauscher, his boots thudding against the wooden floor with deliberate weight. 'We're wasting daylight,' he muttered, but Gerwin caught the way his gaze lingered on the doorframe as they left, as though committing every grain of it to memory.
    The three men stepped out into Middenheim's streets. The air outside should have felt fresher, but to Gerwin it carried the same stale weight that clung to the ruined body inside. Sigismund strode ahead in silence, jaw tight, the set of his shoulders daring anyone to cross his path. Gerwin followed, trying to shake the image of crumbled flesh from behind his eyelids.
    Middenheim was alive again after the siege—streets crowded, banners snapping in the wind, merchants already shouting about grain and furs as though the undead had never reached the walls. But for Gerwin, the city felt muted, each sound dulled beneath the knowledge of what they'd just left behind.
    Gerwin had never set foot in the heart of Ulric's domain before, where towers bristled like frozen spears against the grey sky, and wolf banners snapped in the cutting wind. Reikland might be the seat of the Empire, but its soul belonged to Sigmar. Efror, though independent from Middenland, had always sworn by the White Wolf. Its people kept the old ways, the colder faith.
    Middenheim, to Ulric's faithful, would always be the true capital.
    It was simply regrettable that this rare occasion for Gerwin to visit was due to a force which had destroyed his home.
    The reports were clear. The County of Efror was gone. Sigismund's orders had saved lives, sending the people to flee while those able to fight were conscripted into the Efror Guard. But that was all that remained now—soldiers without a homeland.
    The last scraps of a dead county. A banner with no home.
    But they still had a purpose.
    They would avenge their home. The necromancer would not be allowed to continue to live. Gerwin knew, without a shadow of a doubt, that Sigismund would have the Efror Guard hunt the necromancer to the ends of the world and beyond to satisfy the need for revenge. And even those who had been conscripted would follow with a righteous fury in their hearts.
    Faith, steel and gunpowder might be the cornerstone of the Empire.
    But fury and blood were what drove its common folk.
    Gerwin breathed in, tempered the fury, held it back. Now wasn't the moment to let it be felt.
    'What's the plan?' he asked instead.
    Sigismund tilted his head, lips pinched together while he considered. 'I'm going to see if I can find anything on the name I was given.'
    'Pugna Textrix?' Gerwin asked, mostly to remind himself.
    'Aye,' Sigismund growled. 'We still don't know who or what that name belongs to. Just that it was the count's final order—to find and kill them.'
    Gerwin frowned. 'I'd assumed it was the necromancer.'
    'Could be,' Sigismund said, exhaling through his nose. 'But it might also be something of Chaos. The timing… it all fits too cleanly. I've already got one… person… digging into it. But I want more than one lead. Cast the net wide.'
    Gerwin frowned, trying to think of who Sigismund could have tasked with researching an unusual name. And when he had had the chance to give such a task.
    'And in the meantime?' he asked instead of dwelling.
    'We continue to hunt the undead with Captain von Eisling's landsknecht. So long as they'll continue to work with us.'
    'I can't imagine that she'll decline the extra swords,' Gerwin said with a twitch of the lips. 'Though I must admit, I find myself curious about her.'
    Sigismund grunted. 'What about her?'
    'How does a daughter of a Reiklandese noble house come to form and command a landsknecht at the command of the Elector Count of Stirland?'
    Sigismund gave a low breath, briefly looking at Gerwin with one eyebrow raised. After a moment, he returned his attention to the streets they were navigating.
    'Not unheard of. Some nobles pledge themselves to the Empire as a whole and form landsknechts. It lets them avoid the provincial bureaucracy when crossing borders.'
    Gerwin shook his head. 'Sure, but she wears the sigil of the Carroburg Greatswords. You don't just dabble in that. She went from that to leading a glorified free company?'
    Sigismund paused at that, then nodded slowly. 'Earn your stripes in formal service, then carry that experience into command elsewhere. It's admirable. She could've spent her life on an estate in comfort.'
    Gerwin blinked. 'You know her?'
    'Not personally. I know the name von Eisling. Horse breeders. Good stock, if the stories aren't embellished.'
    Gerwin, who had never taken to riding, let alone fighting from horseback, had never heard of them. That was noble business—far from his world. But he trusted Sigismund's assessment.
    'How good is good?' he asked instead.
    Sigismund shrugged. 'Good enough that if you want to buy one, you'd need to outbid the likes of the Reiksguard or the Knights Panther.'
    'Huh.' Gerwin chewed on that. 'So she could've been a pampered little princess. Where is she anyway?'
    Sigismund's expression dropped back into a scowl. 'She's talking to Graf Todbringer. Discussing the undead.'
    'Without you?'
    'We're the tagalongs, she was the one tasked by an Elector Count. And as a daughter of a noble house, she's welcome to the politics.'
    The words carried no envy, but there was a tightness in Sigismund's jaw. They turned down a narrow street where the wind funnelled between the stone walls, stirring the faint smell of smoke from some unseen hearth. Middenheim bustled despite the cold, and the all-too recent siege.
    Gerwin glanced sidelong at his companion. Sigismund's gaze was fixed ahead, unblinking, shoulders squared as though walking into an audience chamber rather than a marketplace. There was a weight there, a careful composure that did not belong to a common soldier. It reminded Gerwin of how the man had carried himself in Count Feyerabend's presence—not deferential, but steady, like a man who knew his place had been earned, not granted by birth. That memory stirred others, and before he realised it, Gerwin found his thoughts turning inward.
    The late count had taken Sigismund in, given him purpose and treated him more like a son than he ever had the ward meant to be his heir. Norbert von Feyerabend had never hidden that Robert Fenchel was an obligation, not a child he wanted. Sigismund was the son he'd have chosen.
    Gerwin briefly wondered if it could have been different. If Fenchel had been treated as family instead of an obligation, would the false chaplain have ever tried to kill him in the night? Would anyone have believed the chaplain's accusation without proof?
    And yet… if Fenchel hadn't fled to find his uncle—his mother's kin—in Marienburg, the Efror Guard would have been in the keep when the Chaos warhost came. Instead, the garrison had been little more than the chaplain's own recruits. The county's darkest hour had left survivors only because its defenders were far from home.
    Their walk brought them to the edge of Middenheim, and the long stone road that wound its way down the mountain to the plains. By unspoken agreement, they stopped, moving instead to a nearby stone bench beside the steep descent.
    From their bench, the camp lay far below—two clusters of tents flying the banners of the Efror Guard and von Eisling's landsknecht. The wind teased them into lazy flutters, the details lost at this distance, though Gerwin needed none. He'd grown up under the quartered black and purple of Efror, had sworn his life to guarding it.
    'You ever wonder why Count Orwell Adelbrecht chose purple?' he asked, eyes resting on that distant Efror banner, at the rich shade of purple that very rarely appeared on the tabards of the guard.
    If the question also served to distract Gerwin from the world of what-ifs and could-haves that his mind had drifted into, so much the better.
    'He was determined to make Efror as impressive as possible, but only learnt how expensive purple dye really was only after he'd purchased the first shipment. He quartered it with black to save money.'
    Gerwin coughed up the spit that went down the wrong way in his startlement. 'What?'
    Sigismund gave an amused grin. 'They don't mention that detail very often. Rather diminishes the near mythical standard we hold him to, hearing that he overestimated his finances on declaring Efror an independent ordensstaat.' His hand briefly rested on the pommel of the sword at his hip, the same sword that should have been the Adelbrecht heirloom. 'Then he drained what was left of the treasury on a magical blade to be a symbol of his dynasty's strength. Two grand gestures and the coffers were bare.'
    Gerwin laughed. 'I guess that's how we know he was noble even before he declared independence. If he had been born of the working class, he'd have been triple checking every purchase and being a bit of a miser about spending his treasury.' He paused his laugh as a new thought hit him. 'Wait… is that why the Efror Guard never had black powder weapons? Because he was too focused on a fancy colour and a magical sword?'
    Sigismund's shoulders shook in barely contained mirth. 'Actually no. If what Count Feyerabend told me is accurate, the lack of handguns was because Orwell Adelbrecht was quite smitten with Bretonnia and their knights. To the point that he chose to copy a fair few of their doctrines when it came to training up his new ordensstaat, and his knights in particular, on Bretonnian doctrine. Which was why—pre-razing—Efror had knights who could equal any of the great knightly orders. '
    That stirred Gerwin's memory: Cruniac, beaming like a boy with a prize, showing off the great helm he claimed had belonged to a however-many-times-great grandfather in the old Efror Guard, elevated to the ranks of the Ritterbruder. Its most striking feature had been the pair of curved "wings" sweeping up from either side, like a frozen crest of steel. Different from anything worn in Efror now, or even in the Empire at large. Hearing that the old Efror knights had been modelled on Bretonnians suddenly made that over-polished relic look the part.
    Shame it was probably gone now. Burnt with the rest of the Feyerabend keep.
    'Saying it like that, you make it sound like he wished he could have his knights sip from the grail.' He spoke, partly to distract him from the direction his thoughts had turned. He was enjoying the rare moment of Sigismund relaxed and smiling. Rare enough a state that it was, with everything happening, it was even less likely to happen again any time soon than usual.
    Sigismund didn't appear to notice Gerwin's momentary lapse in mood. Fortunately. 'Be honest, if you had an opportunity to sip from the grail and still be a loyal Ulric-fearing man of the Empire, would you turn it down?'
    Gerwin shook his head with a chuckle. 'Can't say I would. If even half of what they say of Grail Knights is true, no sane man would.'
    Gerwin continued to stare down at the camps in the surrounding fields.
    'What colours would you have picked? If you had been Count Adelbracht the Independent?' He asked after a minute had passed.
    'Blue and white.' Sigismund didn't hesitate. A moment passed, and then he continued. 'Blue field, white cross quartering the blue.'
    'Ulric's colours.' Gerwin nodded in approval, picturing in his mind if history had made that choice. 'Simple, but it works.'
    'Cheaper too,' Sigismund said with a twitch to his lips. 'I would actually have a uniform colour, instead of every other tabard being a different shade of purple from our standards.'
    Both let out chuckles at the dig at Adelbrecht's financial sense. Gerwin's grin slid away after his thoughts naturally drifted from Orwell Adelbrecht, to the count's son, and then his grandson, the mad count who had ruined the county of Efror's prospects forevermore.
    And from that thought subject, his mind segued to the undead army they were hunting. In particular, those within that were wearing the colours of Efror. It beggared the question, what was the necromancer's fixation with Efror? Or was it all just a simple case of the necromancer having found a convenient source of bodies in Gerwin's home? Much the same as how the Drakwald had proven to be a source of bodies?
    Sigismund stood abruptly, hand on his sword hilt, eyes sweeping the crowd. The sudden movement startled passers-by; the shuffle of boots and murmur of voices faltered as people gave the two Efror Guardsmen wary glances.
    Gerwin rose without thinking, scanning faces, the sway of cloaks, the occasional glint of steel at a belt. Nothing that looked like a threat. The wind pressed cold against his cheek, carrying the sour tang of unwashed bodies and woodsmoke from the city behind them.
    After a long half-minute, Sigismund's posture eased, though his gaze kept flicking between strangers as they moved on.
    'I could have sworn I just saw Fenchel in the crowd,' Sigismund muttered. 'Saw his face…'
    Gerwin narrowed his eyes. 'We just saw Fenchel's body. He's dead.'
    'I know that,' Sigismund growled lowly.
    Gerwin shook his head. 'Ulric-damnit. His death is not your fault.'
    Sigismund's lips pressed tightly together, forming a thin line. 'I led the guard, we chased him off believing him to have betrayed the count.'
    'We were deceived. And the moment we suspected something was off, you went back to Count Feyerabend to try and work out what was going on. And Fenchel should have been safe here. If not Middenheim, where else?'
    Sigismund let out a grumble that didn't truly have any words to it. 'Fuck…' he finally let out, hand running through his hair. 'Fighting undead must be getting to me. Never had this problem with the Norscans.'
    Gerwin huffed out a breath. 'Yah, but I would bet that Norsca held its own problems and issues.'
    'Death by attrition. Starvation and freezing are unpleasant ways to go…' Sigismund mumbled. 'Foraging was sparse and never brought nearly as much as was needed, and once the supply train was gone? That was the end of that campaign.'
    Gerwin wrinkled his nose, imagining how frigid the Norscan lands must have been for such a rate of attrition. It was enough to make him re-evaluate whether the campaign in Sylvania was better or worse than the Norscan campaign Sigismund had partook in.
    Sigismund shook his hand and seemed to wrench his hand away from the hilt of his sword, as though he needed to fight against a force that was keeping it there.
    'Come on, let's go back to camp. Maybe when von Eisling gets back, we'll have a new destination.' As he spoke, Sigismund's eyes locked onto something in the distance. 'Hopefully that will be soon.'
    Gerwin followed Sigismund's gaze, and spotted new banners in the distance. Though he didn't recognise most of them, one of them Sigismund had spoken of previously. One that had been present during the siege of the Feyerabend Keep.
    By the looks of it, the lizardmen were approaching Middenheim. Even if they weren't actually enemies, Gerwin understood Sigismund's feelings. Due to their part in what had happened, Sigismund no doubt wanted very much to keep as far from the Outland Legion as possible.
    If Gerwin was honest with himself, he shared in that desire.
  10. J.Logan
    J.Logan Well-Known Member
    Passing Through
    Middenheim - Middenland
    Sharpe took in the camp at a glance, and noted that it was a quick-job, hardly a camp at all. Ingwel was clearly not planning on lingering more than a day. Or at the very least wanted to be able to move out swiftly without much delay.
    A second look, slightly more thorough, he noted the size. Even separated from the Legion as he had been, he had heard the news. Heard about the battle, after a campaign of purging marauding cultists. Loss was inevitable—an unlucky strike, a mistimed dodge. But this… this was heavy. Most of the dead had fallen two days past.
    It wasn't enough to cripple the Legion. He knew the history of the Legion, knew that it had started with far fewer members than it held now, even diminished as it was following the battle. If the Legion had been able to function with barely a hundred to its name—granted, back then the Legion hadn't been called "the Outland Legion" yet—then there was no way they'd falter just now.
    He'd get the list. Names, not numbers. To remember the sacrifices made, in his own way. Remember the names, remember the deeds. Remember that they gave their lives fighting the Great Enemy, fighting to defend the Great Plan. And then move on.
    That was the way of the Children of the Gods.
    About the only difference that came specifically from the Outland Legion's way of honouring the fallen, would be the Last Rites. And the diamonds.
    As if that last thought was a prompt for him, Sharpe moved toward the covered wagon that he knew carried the remains of the deceased.
    Normally, Children of the Gods didn't worry over-much for the bodies of their fallen. Maybe burn them to prevent necromancers from perverting their dead, but otherwise there was a strong mentality of letting the dead feed the lands.
    But the Legion weren't in the lands of their home. And part of the Last Rites purpose was to let those who had dedicated their lives in such a way as to rarely get to see their home again be returned to the soils of their origin.
    Sharpe paused at the wagon, considering. Then, he parted the fabric and allowed himself entry. Instantly he was hit with an air of solemnity. Two metal chests sat within the wagon. He rested his hands against one, felt the chill of the metal, one that had nothing to do with the temperature and everything to do with what they held, what they represented.
    He opened the chest, and felt his breath briefly still at the number of diamonds that lay within. Dim light caught the facets of the stones, reflected and broken. The diamonds were fairly small. But their worth was not in their size, it was in what they were. Each and every one had been made from the ashes of a fallen member of the Legion, compacted into a form that was easy to transport.
    Easier than carrying who knows how many urns.
    Next time they met with Horeo, or any other who might be the intermediary between the Legion and Madrigal, the diamonds would be handed over, and Horeo would bring home the fallen.
    Sharpe picked up one of the diamonds, held it to eye-level. For a moment he reckoned that he could feel a flicker—a moment of who had once been—acknowledging him. Almost believed he felt a ghostly hand on his shoulder.
    'We got lucky.'
    Sharpe carefully replaced the diamond within the chest and closed it, before turning to look at the one to speak. Ingwel stared at him, then jerked his head to the side, to the wagon's exit. Sharpe quietly left the wagon, and then stood, waiting for Ingwel to speak.
    'If a Dawi throng had not arrived when they did, you and your skirmishers would have probably been all that was left of the Legion,' Ingwel spoke after a pause.
    'That would be a sorry state of affairs,' Sharpe remarked, eyes narrowing in distaste.
    Ingwel huffed a breath of faint amusement. 'Quite.' He turned and looked toward the mountain upon which Middenheim was sat. 'Horeo is on his way to dispatch the latest fresh blood for the Legion.'
    'That's a swift turnover… was only a couple of moons ago he dropped off the last batch.'
    Ingwel gave a single nod. 'Apparently things have been stirred up back home, more support for us from the other two slann. But what that means? I've not the faintest idea. Horeo will supposedly explain when we meet him. Just have to decide where that will be.'
    Sharpe turned his head to face in the direction he knew Marienburg to be, on the other side of the Drakwald. Ingwel must have sensed Sharpe's desire to not pass the Drakwald after so recently spending time within the infernal forest, as he rumbled a low laugh.
    'If we had not needed to move south to pick you and your skirmishers up, we'd be going north, to the Nordland coast.'
    'Well, why do we not?'
    'I do not particularly care for moving in one direction and then turning around and marching back the way we came.' Ingwel's voice held his amused grin.
    Sharpe let out a breath, both acknowledgement of the fact, and allowing him to express some humour. 'So, to Marienburg then?'
    Ingwel shrugged a single shoulder. 'Most likely. Though I am planning to talk with somebody before committing to any plans. With the recent wounding of Ursun, we might be going north, to Kislev.'
    Sharpe let the words run in his mind, turned them over and examined them closely.
    'What?' he asked blankly.
    Ingwel hissed softly. 'News from up north about their seven year winter. And the reason for the sky's display a while back.'
    Sharpe scowled, remembering the event in question. "Display" hardly covered it.
    Ignoring the fact that he wasn't happy being the last to find out about the cause—little he could have done to change that, considering his task—he was not eager with the idea of travelling into Kislev. Even at the best of times, it was cold enough to be less than pleasant for Children of the Gods. In the midst of an ongoing winter? No, he held little desire to trek there.
    He would. He wouldn't refuse to do his job just because it was less than comfortable. No self-respecting Child of the Gods would refuse the call.
    But given a choice, he would much prefer not going to Kislev.
    The look Ingwel gave him was one of understanding—none of their race wanted to set foot in a place so cold if they had the choice. But choice wasn't usually a factor in where the Legion went. A threat to the Great Plan had to be fought, be it in the cold of winter, or the warmth of the sun.
    'Easiest place for Horeo to make landfall would be near Erengrad,' Sharpe mused aloud instead of dwelling on his feelings, focused instead on the practicalities .
    'Might be trickier than it ought to be,' Ingwel said, grave of tone. 'Politics within Kislev—Erengrad is currently under the banner of the Great Orthodoxy. While Tzarina Katarin wouldn't have a problem with us, we don't yet know what the Supreme Patriarch's attitude is.'
    Sharpe scowled. 'Human religious figures do not tend to be rational.'
    'Humans in general do not tend to be rational,' Ingwel countered, motioning at his clothing.
    Sharpe let out a guffaw, acknowledging that point. 'So—west, or north and east.'
    Ingwel hummed absently, and turned his attention toward Middenheim. Sharpe followed his gaze.
    'Anything to note?' Ingwel asked after a long moment.
    Sharpe shrugged. 'I did what I could to cull the undead, but I never saw the necromancer himself. Or herself. Had a few lieutenants killed, but that was not enough to remove the animation over the dead under their control, it only made them mindlessly obey the last order they were given.'
    'That is still useful in battle,' Ingwel pointed out.
    'Aye. According to Happy, at least one battle between the undead and the warmbloods went better for Happy killing the wight that was in control of that particular horde. Easier to corral into a bottleneck when the undead are mindlessly moving forward.'
    Ingwel must have sensed something about the chameleon's tone, he turned his attention back to Sharpe, head tilted. After a moment, Sharpe huffed out a breath and let out his thoughts on the siege.
    'They had numbers, aye. An army raised with cunning, hidden in the Drakwald, built from the bodies no one would miss. But the attack on Middenheim? It was blunt. Almost careless. The only thought they showed was spreading out to avoid Ulric's Thunder. Beyond that, it lacked purpose.'
    Ingwel huffed a single amused breath, his eye again lifting to Middenheim, and Ulric's Thunder in particular, even if the cannon itself wasn't visible from where they were standing.
    'Your conclusion?'
    Sharpe shrugged. 'Middenheim wasn't their end goal. If they had taken it, fine. They would have raised the citizens and bolstered their horde, replaced their losses. But the city itself? Not the prize.'
    'What then?'
    'No idea,' Sharpe admitted. 'Might be worth asking the Graf, or setting Iycan to his usual nose-poking.'
    Ingwel's grin sharpened. 'Perhaps. The Graf owes us at least the courtesy of information.' He jerked his chin toward the wagon of diamonds. 'After all, we've paid enough blood.'
    'Resupply too, while we're at it,' Sharpe added. 'Our stores must be running thin.'
    'Barren,' Ingwel said simply.
    Sharpe winced. 'That bad?'
    'Bad enough.' Ingwel's eyes narrowed, his mind already turning. Then he let out a long breath, the tension bleeding away. 'But there's plenty yet to do.'
    Sharpe exhaled slowly. 'Aye. Plenty to do.'
    For a long moment neither spoke. The camp's muted noises filled the silence—the creak of leather, the hiss of a dying fire, a cough somewhere in the dark. Then Ingwel straightened.
    'Get some rest, Sharpe. Tomorrow we decide where the Legion marches.'
    Sharpe inclined his head, though his eyes lingered on Middenheim's silhouette. He knew storms well enough to recognise the shape of one when it was gathering.
    Boney flicked through the thick pages of the book in his hands, his claws rasping softly against the parchment. Each page was crowded with images of Imperial heraldry: banners quartered in vibrant colours, beasts both real and fantastical, symbols twisted with strange geometry, and beneath each, the names of those they represented. To Boney's mind, it all felt needlessly complicated. So many colours, so many emblems, so many crests. At the crux of it all, weren't they simply the Empire of Man? All of them part of the same realm, bound under the same Emperor? Why scatter themselves with so much effort into smaller identities?
    The provinces, Boney could understand in part—he compared them to the domains of the great temple-cities of his own kin. But the divisions did not stop there. Every land within a province had its own symbols, its own proud declaration of difference. And then every city to hold its own garrison. And families, too, demanded recognition, each line drawing up its own banner, and sometimes more than one. They seemed to hand down division as though it were heirloom and birthright both. A family schism might shatter not only their bonds, but the colours that flew above them.
    It was, to Boney, a labyrinth of unnecessary clutter. Yet he could not deny that somehow, through all this complexity, the humans had prospered. They had endured, expanded, thrived. Their endless subsets of heraldry had not broken them, and so he grudgingly accepted that there was a logic hidden to it, even if it was logic strange to him. Oddities could not be faulted if they caused no harm and still produced strength.
    He flipped to the next page and paused, his eyes rested upon the depiction of the now familiar quartering of black and purple, with a stylised boar in the middle. The heraldry of the County of Efror.
    He didn't need the book for that standard—he only had to glance up at the camp nearby. It flew alongside another standard, one Boney was not so familiar with.
    He lifted his eyes, turned to look at those two banners so close, yet still far enough to avoid too much chance of any from the Legion bumping into an Efror Guardsman. Warmbloods could cling to perceived wronghoods, and even if the Legion wasn't responsible for the end result of their capital, some might still take out their vexations on any lizardmen they might stumble across.
    Unbidden, Boney's attention was drawn to that other standard, a banner with a blue, wingless dragon against white—or, according to the book, azure upon argent. He chose not to dwell on the example of humans continuing to make things ever more complicated. Did there need to be different words to describe the same colour?
    But something about the standard was rubbing against Boney's mind as… off, for lack of a better word. Why a wingless dragon? And it didn't look like it was supposed to be a linnorn.
    He flicked through the book's pages, until he finally found the page that held a rough depiction of that standard that had caught his attention so. Except instantly, there was an inaccuracy in the artist's rendition—the book showed a dragon charge, similar to other standards within its pages, only wingless. The banner outside bore something else entirely, its dragon had a distinct design to it.
    Boney narrowed his eyes, the muscles of his jaw tightening faintly. His first impression upon seeing the banner had been that it was an aggradon, familiar and out of place in human hands. The angle of the snout, the curve of the neck, the crouched strength of the body, it all spoke of the beasts bred and ridden by his kin. Yet humans did not use aggradons in heraldry. At least, not according to what he had been told. Their heraldry followed rules, traditions, taboos. The adoption of a creature not native to their world was, if not forbidden, at least unheard of.
    And Boney had been told there was a second volume specifically for Bretonnian heraldry.
    His tail twitched with annoyance. How much effort did warmbloods spend carving themselves into smaller and smaller groups, cataloguing every subset until they were more name than substance? Would it not be simpler to recognise the cities alone, to keep things as unified as the Children of the Gods? But no, that was not their way.
    He mused privately: Can't all be as sensible as the Children of the Gods, I suppose.
    Boney felt somebody approaching him. His tongue flicked out, tasting the air, and identified the scent.
    'Coadmit,' he greeted, even before the sergeant came within sight.
    'Major,' came the answer, a hiss of acknowledgement as Sergeant Coadmit stepped into view.
    Boney blinked. For a moment, he thought his eyes deceived him. In all the moons of their service together, he could not recall a time he had seen Coadmit without his coat. The sergeant was clad only in stone-grey breeches and a waistcoat, the familiar red wool missing. The absence struck him oddly, as though some part of the skink's shape had been pared away.
    It made sense, of course. The garment had been thick with mud during the battle. No doubt it needed a wash. Yet knowing this did not lessen the strangeness of seeing Coadmit so plainly dressed, his form sharper, smaller, without the swathe of colour.
    Coadmit's eyes narrowed the barest amount, tongue flicking. Boney huffed, shaking his head and fighting the amusement that wanted to match the barely veiled humour Coadmit carried.
    'Anything interesting?' Coadmit asked after a pause.
    Boney hummed, considering, then motioned toward the distant banner. 'Does that look like an aggradon to you?'
    Coadmit's eyes widened slightly, then he turned his head to follow Boney's gesture. It was obvious the moment he spotted the standard in question, his head tilted in consideration.
    'House von Eisling?' he mused aloud.
    'You recognised them without looking at the book?' Boney asked, a brow ridge lifting.
    Coadmit shrugged with one shoulder. 'Only from things I heard, some time ago.' His eyes did not leave the banner. 'It looks like an aggradon because it is an aggradon.'
    Boney stilled, eyes fixed on that banner, on the stylised aggradon. He supposed it answered the question of why it simply hadn't felt like a dragon, even if the description in the book, and the artist's inaccurate rendition suggested that it was commonly believed to be such.
    But it felt odd to have a creature that was distinctly tied to the Children of the Gods, to his own kin, and to see its likeness being used by humans, for a human noble house to have adopted it as their sigil.
    Boney frowned, his tongue flicking out thoughtfully. 'That's not a usual choice for humans, though?'
    'Not to my knowledge. But if what I heard is true, House von Eisling took it as their sigil a few centuries back.'
    Boney considered that, eyes narrowed into a frown. 'Any particular reason they chose a creature not native to these lands?'
    Coadmit hummed then shrugged again. 'Couldn't say.' His eyes remained locked onto the standard. 'Maybe they encountered Druchii at some point—the dark elves have taken to using stolen and poached aggradons for their own. Could have stolen one from them and managed to tame it? Might want to ask the colonel about them. Iycan'ceya might be able to tell you the entire family history.'
    'Might just do that.' Boney paused for a moment, then pulled his eyes away from the standard. 'Do you think there will be any issue? Them travelling with the remnants of the Efror Guard?'
    Coadmit exhaled softly, noticeably tracking his eyes from the von Eisling standard to the quartered purple and black. 'Most likely not. Based on what Sharpe's Chosen have been saying, they have dedicated themselves to hunting the undead.'
    Boney suppressed a shiver. 'I almost forgot about them. Then we got here…'
    'And found that while we were in battle with Chaos, this city fought the dead,' Coadmit finished, crossing his arms.
    The pair remained in silence for a period, then Coadmit huffed out a breath. 'The marshal has requested your presence. That's what I came to tell you.'
    Boney hummed. 'Did he say what I was being requested for?'
    The sergeant shook his head. 'I think he is meeting with one of the warmbloods, and wants all majors and both the colonels.'
    Boney let out a soft 'Huh', and clambered to his feet, carefully tucking the book away. 'Thank you.'
    He turned away, tail flicking behind him. The evening light slanted across the camp as he walked.
    Marshal Ingwel watched as the human neared. He quickly recognised him, it was the same human he had spoken with last time he had been in Middenheim, the same that Iycan had spoken to the time before that.
    Rauscher's stride was brisk but wary, his gaze flicking from the campfires to the lizardmen who moved between them, his brow deeply furrowed. Ingwel's attention lingered on the man's hand, resting not idly but firmly on the hilt of his kriegmesser. Last time, it had been worn as a mark of status, a weapon positioned as much for display as for battle. Tonight it was slung differently—lower, easier to draw, the stance of a man prepared to kill without hesitation.
    Ingwel could not fault him. A city that had only just endured a siege by the walking dead was no place for ease. Any man with sense enough to survive such horror would carry its shadow with him for many moons.
    'Councillor,' Ingwel greeted him, dipping his heavy head slightly. His gaze shifted to the six armoured men who fanned out with automatic discipline, forming a loose perimeter around their charge. Their boots sank into the earth of the hastily raised camp, their eyes sharp, hands near their blades.
    Ingwel had considered venturing into Middenheim itself to parley, but the thought of walking through a city freshly scarred by siege, his scaled bulk standing out among grieving, fearful men? No. He had not survived this long by courting mobs. Best to let them come to him.
    Rauscher lifted a hand in greeting, though his eyes never stopped scanning the camp. Behind him, another seven figures emerged from the dark. Six moved with practised efficiency, slipping into place around the councillor like the tightening of a noose. The seventh approached with a faint limp, then paused, lingered at the edge of the firelight, hood drawn low. The others unconsciously left a little space about him.
    Ingwel's eyes caught on one guard as he passed the flames. Broad-shouldered, heavy cloak made from the pelt of a wolf, while the armour beneath was unmistakable.
    Ingwel's eyes narrowed. 'Teutogen Guard?' he noted, curious. 'Have you been promoted to the Al-Ulric?'
    Rauscher let out a quiet laugh, though it was absent any mirth. 'They aren't for me. And there is one other who is afforded the protection of the Teutogen Guard.'
    Ingwel's eyes widened in surprise, and he turned to look at the last human who had arrived, who had not taken up a position as a guard.
    The hooded figure moved then, slow and deliberate. First, the fire's glow struck an angular jaw. Dark facial hair, streaked with grey, framed a mouth pressed into a stern line. At last, the hood fell back to reveal the face. Weathered skin, broken by scars. A patch covered his left eye, while his right glared, cold and grey, burning with predatory sharpness.
    Around him, Ingwel felt—more than heard—the startled shuffle of his majors. Solin and Iycan betrayed nothing a human might notice, but Ingwel knew them too well to mistake their surprise for calm.
    'Graf Todbringer,' Ingwel finally spoke up after allowing his surprise to run its course, dipping his head slightly in a gesture of respect. 'A most unexpected pleasure.'
    The Graf's single eye raked over him, travelling from clawed feet to crested skull. It was not curiosity—it was measurement, as though weighing strength, ferocity, intent. When at last it locked with Ingwel's gaze, it did so without flinching.
    'Marshal Ingwel'tonl.' He finally spoke, his voice gravelled and steady. 'The stories did not exaggerate.'
    He then examined the skinks and saurus within the guard's ring. Some, his attention passed over in a heartbeat, while others drew a longer look, with a flicker of recognition as reptilian faces aligned with stories heard. At last, the eye returned to Ingwel.
    'We have much to discuss, Marshal.'
    thedarkfourth likes this.
  11. J.Logan
    Night Before
    Mort looked up from his shield when somebody approached, rag stilling its motion. His eyes locked onto Sharpe, narrowed in nonplussed disapproval. Sharpe matched the unimpressed glare and stepped forward, revealing another figure behind him.
    At least Boney looked somewhat apologetic, as it seemingly dawned on him whose fire they had just approached.
    ‘Anybody else?’ Mort asked dryly, tilting his body as if to peer around Boney.
    ‘Iycan would have come,’ Sharpe said, ‘but he and Solin are both staying by the marshal’s side while he is talking with the Graf.’
    Mort blinked in surprise. ‘Graf Todbringer?’
    Never let it be said that he was completely ignorant of warmblood politics and persons of interest. He just didn’t typically care, because it wasn’t his role to know or act on such knowledge.
    Sharpe nodded once, then his left eye seemed to notice the shield resting on Mort’s lap. That eye remained locked onto the shield, even as the rest of Sharpe continued as normal.
    ‘Aye, a surprise visit from the Grand ol’ Duke of Midden himself. Speaking of which, you were not with the rest of us majors when he made his appearance.’
    Mort felt the weight of the golden plaque hidden beneath his cuirass, as well as the hidden eyes of the saurus guardians watching over him. He also felt Sharpe’s curiosity at the seemingly out-of-character behaviour Mort had shown by not being there. He exhaled through his nostrils.
    ‘I have a task that requires I not put myself in danger needlessly,’ he explained. ‘One that takes priority over niceties and being a bodyguard for Ingwel.’
    ‘Instead you are the one being bodyguarded,’ Boney said.
    Sharpe blinked in surprise, then scanned the surroundings. Mort knew the instant he spotted at least one of his guardians, the eye that had come across the figure paused its roving movement and narrowed ever so slightly.
    It didn’t surprise Mort that Sharpe was able to spot them. One of his most admirable traits was his keen eye, his ability to spot most anything that was trying to hide, especially if he had cause to look.
    ‘Right then,’ Sharpe drawled, the words carrying a strange mix of curiosity and resignation. His eye drifted back to the shield in Mort’s lap, even as he flicked a twig into the flames. Sparks climbed and died. ‘I am not going to ask.’
    Mort nodded. Another trait he approved of. Sharpe, for all his flaws, had an instinctive sense of when not to dig his snout into matters.
    Sharpe sat himself, cross-legged next to the fire. After a moment, Boney joined the chameleon on the ground.
    ‘So, what brings you both to my fire?’ Mort asked after a pause, though asking didn’t prevent him from resuming his efforts in polishing the shield.
    ‘Cannot a major simply come by for a word with one of his fellows?’ Sharpe retorted, one eye canting ever so slightly in wry amusement.
    ‘I can count on one hand the number of times you have wished to “just chat” with me,’ Mort said dryly, before tilting his head towards Boney. ‘And neither time did you bring company.’
    ‘Then let us say it is partly curiosity,’ Sharpe admitted. ‘I wished to hear what I missed. I know it was bad, judging by the number of diamonds in the chest.’
    ‘Bad enough that the dwarfs were nearly too late,’ Boney muttered.
    Mort inclined his head in agreement with Boney’s comment. ‘As far as I can tell, we did not manage to kill any of the leading champions.’
    He still recalled the moment that the skull-clad champion had been whisked away, denying him the kill. If there were any luck to be had, infection would take that monster’s life. But since when was luck freely given their way?
    Boney shuddered, possibly remembering the same champion. Or maybe just fighting the lingering nerves that would likely be plaguing him after his first battle of such a scale. Hard to say.
    Sharpe frowned. ‘I suppose that would have been too much to hope for. Did we learn anything about them?’
    ‘That the skull-wearing champion does not like magic,’ Boney commented wryly. ‘And magic apparently does not like him. Never thought I would see the day somebody could just walk off being struck by lightning.’
    ‘Fought like he was a Khornate berserker. Maybe he was one, once.’ Mort snorted.
    ‘Can Chaos champions switch gods like that?’ Boney asked, head tilting in confusion.
    ‘Ordinarily, I would say no,’ Sharpe replied. ‘The gods of Chaos are notoriously possessive of what they claim as theirs. Of the four, Khorne is said to be the most… permissive, so long as blood is being spilled. He does not often care whose blood it is, nor whose hands do the spilling.’
    ‘And as for this warhost… we know little of Malice beyond his opposition to the Four,’ Mort said with a shrug. ‘I can see them welcoming disillusioned champions, if only to spite their former masters.’
    Sharpe’s eyes narrowed. ‘Once Chaos has touched you, there is no escaping it. A god of Chaos who despises Chaos itself… a haven for those who regret their original choice, yet have nowhere else to go.’ He leaned back, both eyes lifting briefly to the night sky. ‘Not that it would save them. They are still marked. Still tainted.’
    Mort let out another breath, watched as it misted as it hit the cool air. Though, he noted quickly, the misting was thinner than the last time he’d exhaled, which meant his body was cooling quicker than he’d anticipated. In response, he shuffled himself slightly closer to the fire.
    ‘Dratted warmblood lands and weather,’ he muttered sourly. ‘Changes from hot summer nights to autumnal chill far too quickly.’
    Sharpe and Boney both seemed to take Mort’s action as permission to likewise pull themselves closer to the heat of the fire.
    ‘I hope we are not going north,’ Sharpe admitted. ‘But with Kislev being in its current state…’
    Mort couldn’t help the shiver at the very idea. ‘Here is hoping that Graf Todbringer is charging us with a task that takes us away from Kislev.’
    ‘You will be thankful to hear that we aren’t going to Kislev,’ a new voice spoke up.
    Mort turned his attention away from his shield, looking up as Iycan approached.
    ‘Chat with the Graf finished then?’ he asked.
    Iycan narrowed his eyes in a faint smile. ‘My part, yes. May I?’ He motioned at a space between Boney and Mort.
    Mort shrugged then waved a hand in wordless permission. The skink sat himself and held out a hand toward the fire, sighing in relief as the warmth hit him.
    ‘Todbringer gave us a task?’ Sharpe asked once he’d deemed that Iycan had been given sufficient time to warm himself.
    Iycan nodded, and pulled off his cap, holding it to the fire’s heat. ‘He needs to travel to Altdorf, so he has asked us to accompany him.’
    ‘What does the Graf of Middenland need an escort for?’ Mort asked, scowling.
    ‘Well,’ the colonel shrugged. ‘We are going in the same direction regardless.’
    Mort paused in the polishing of his shield, noted that Sharpe had directed both of his eyes at the senior skink. Boney’s reaction was a contrast, confusion, but at the reaction of the other two majors, not at the words the colonel had spoken. Mort recognised that the younger skink hadn’t yet learnt the lay of the land. He didn’t realise that going to Altdorf meant moving away from every threat they knew about.
    It felt to Mort like a retreat—there were the remaining members of the warhost, there was the undead, there was a scheme of a daemon prince in Kislev, that was three separate issues that the Legion should be hunting down, and instead they were… what? Going south? Moving away from those issues that they ought to be purging?
    Retreat. The word tasted like ash. He ground it beneath a heel and kept his face blank.
    Iycan raised his hands in a gesture of faux-surrender. ‘Graf Todbringer wasn’t exactly thrilled about being used as a messenger. But apparently we have been summoned.’
    ‘Summoned?’ Mort repeated, incredulous. ‘And who, exactly, thinks they have the authority to do that?’
    ‘The Emperor himself,’ Iycan replied. ‘Karl Franz’s seal was on the missive Todbringer passed along.’
    Mort’s jaw snapped shut. The fire cracked. For a moment, nobody spoke. Mort’s hand tightened on the shield-rim until he felt his knuckles pop, before relaxing. Silence hung for a moment before Sharpe exhaled roughly and gave Iycan a wary look.
    ‘Last time the Legion dealt with an Emperor, a city burnt and we only have to look over there’—he waved a hand in the direction of the other camp, with the remaining members of the Efror Guard—‘to see that over a century later we are still their villains.’
    Iycan’s look flattened into one of irritation. ‘I’m well aware of our history. But ignoring the summons of one of the most powerful men of the region would be pointlessly antagonistic. And while humans don’t nurse their grudges in quite the same manner as the Dawi, they do still hold to them. Best not to chance making an enemy out of the entirety of the Empire, no?’
    Mort snorted. ‘Humans hold grudges worse than the Dawi. A Dawi will carve a grudge in stone and leave it as it is. Humans carve theirs in smoke—and somehow it always grows darker, larger, and further from the truth the longer it lingers.’
    He exhaled sharply, eyes fixed on the fire. ‘And if we are being summoned only to be tasked with a job we will not do? Then we make an enemy regardless.’
    ‘At least that way we aren’t the ones at fault,’ Iycan retorted, though for a moment it felt as if he wasn’t paying attention to them, focused on his cap as he was. ‘And I trust Ingwel to minimise any ill feelings. He’s certainly experienced enough at it.’
    As he finished speaking, Iycan clearly deemed his cap sufficiently warmed by the fire, as he returned it to his head. It looked as awkward as ever, competing for space that his finned crest dominated.
    ‘What do we know about this Emperor? Karl Franz?’ Boney spoke up, though the way his eyes were shifting from face to face, Mort got the sense he was asking less about genuine curiosity and more about distracting them.
    Iycan made a show of thinking about his answer.
    ‘By all accounts, despite the usual arguments the Empire have had with their emperors for the past two centuries, he’s considered to be one of the better ones.’
    ‘Ah.’ Boney tilted his head, confusion flickering in his eyes. ‘What are these “usual arguments”?’
    Mort answered before Iycan could. ‘The Empire worships many gods, but two hold primacy—Ulric and Sigmar. Their followers have argued for centuries over which is the Empire’s true patron.’
    ‘Sigmar was the one who forged the Empire, then became a god, was he not?’ Boney asked. ‘Surely that settles the matter?’
    ‘You would think so,’ Iycan said. ‘But Sigmar himself prayed to Ulric, and some claim that means Ulric should remain supreme. Others see Sigmar’s ascension as proof of his right. The Empire has been divided over it ever since.’
    ‘That… is a stupid argument,’ Boney said bluntly, grimacing. One hand drifted to the tattoos hidden under his sleeve. ‘That would be like Madrigal’s cities fighting over which Old One should outrank the others. Different domains, same importance. Even if Xa’litza is Madrigal’s patron, we don’t say she is above Chotek or Quetzl…’
    ‘Humans are not exactly rational,’ Sharpe drawled, smoke in his tone.
    ‘Exactly,’ Iycan agreed, though whether with Sharpe or Boney, Mort couldn’t tell. ‘In any case, since Magnus the Pious, every emperor has been a Sigmarite. Ulric’s followers have grown used to being slighted.’
    ‘So Karl Franz is Sigmar’s man?’ Boney asked.
    ‘Born and raised in a Sigmarite city,’ Iycan said. ‘Plenty thought Graf Todbringer would be chosen this past election—he had the support. But he was an Ulrican. Many whisper that that was enough to deny him the throne.’
    ‘If that is so, then it was incredibly short-sighted,’ Mort muttered, glaring into the fire. ‘Sooner or later, the Ulricans are going to tire of being slighted. If the faith of the emperor had been to-and-fro each succession, it would have felt fairer.’
    ‘But Magnus broke that balance,’ Iycan said. ‘And by favouring the Sigmarites, giving the Cult of Sigmar power over the Ulricans in the election of a new emperor, he gave the Ulricans a wound they’ve never forgotten. Certainly not forgiven.’
    Boney stared at the fire, expression twisted into something best described as baffled irritation. He then turned to look at Sharpe. ‘You were right: humans are not rational in the slightest.’
    Sharpe grinned, clearly taking some pleasure in having his opinion agreed with.
    Boney shook his head and turned back to Iycan. ‘So, aside from a history weighed down by stupidity, Karl Franz is…?’
    ‘Considered to be a fair emperor,’ Iycan said with a nonchalant shrug. ‘Managed to stay on good terms with Bretonnia, hasn’t done anything to deliberately upset the Ulrican faith, to my knowledge. From Todbringer’s grumblings, I got the impression the Graf is actually on his side—though he makes a show of bitterness about losing the throne to him. Perhaps he respects Karl Franz, but resents being bested by a Sigmarite.’
    Boney muttered something Mort couldn’t make out. Probably another gripe about human madness. Mort agreed, of course, but at least he had the sense not to voice it like a Dawi lost in his beard.
    ‘So,’ he elected to shift the subject back to its original course. ‘We are going to Altdorf then?’
    Iycan nodded, a single bob of the head. ‘And then assuming all goes well, we’ll wait there.’
    ‘Wait?’ Mort’s eyes narrowed into a frown.
    ‘Horeo can dock at Altdorf, or near enough,’ Iycan informed them. ‘So we stay put. Do drills. Take jobs that keep us close to the city.’
    ‘And after?’ Sharpe asked.
    Iycan’s head tilted so that he was gazing at the star-laden sky, and he exhaled a long breath which misted against the cool autumnal air. ‘Unless something important comes up, we’ll find a place to hole up for the winter. Perhaps a village near the Grey Mountains. Or we lend swords to Helmgart.’
    Sharpe grunted in consideration. ‘Is there much need for extra bodies at Helmgart? The Empire’s not at war with Bretonnia.’
    ‘Axe Bite Pass is never safe,’ Iycan replied, tone idle though his eyes glinted with calculation. ‘Whole caravans have gone missing, if the rumours are true. Greenskins, trolls, or something worse—who knows? Extra blades at Helmgart mean more patrols. We keep busy, and we stay warm.’
    Boney shifted uneasily. ‘Just how bad are winters here, if hunkering down is the sensible option?’
    ‘Snow that blinds. Winds that cut through your scales. Cold enough to freeze rivers solid,’ Sharpe said, ticking each off on his claws.
    Mort gave a slow nod. ‘This chill? Nothing. Winter makes this feel like a warm breeze.’
    ‘And yet,’ Sharpe added with a sarcastic slant to his eyes, ‘even that is still preferable to going into Kislev.’
    ‘Kislev,’ Iycan said, his voice softening, eyes distant, ‘where even the warmest summer day… is what we currently have here and now.’
    From the way Boney’s tail twitched, Mort guessed he was picturing it.
    ‘And where that summer,’ Iycan went on after a beat, ‘has not been seen for seven years.’
    ‘Got to give the Kislevites credit where it is due,’ Sharpe murmured. ‘They have endured far longer than many would be willing.’
    Mort snorted, a rough, grudging sound. Of course they had. Kislevites were stubborn bastards—prideful enough to spit in the face of the gods themselves if it meant standing their ground. They didn’t endure the cold—they defied it.
    He looked down at the shield resting in his lap. Even in the fickle light of the fire, he could see his work was done. The metal gleamed as much as it ever would, save for the deep scars that no amount of polishing could erase. Those he left untouched. They were part of its story—reminders of battles fought, and survived.
    Mort rose, slung the circular shield across his back.
    ‘I am turning in,’ he said, and walked away from the fire.
    He felt, more than saw, his guardians slip after him into the dark.
    As he examined the map, Ingwel’s tail coiled in silent warning. He would allow his spawn-brother one verse, and then if he didn’t stop… Even if the origin of the song that was apparently stuck in Solin’s head predated Boris Todbringer by centuries, recent history meant that many connected the song to the man.
    The Grand ol’ Duke of Midden,’ Solin sang under his breath.
    Ingwel’s tail tightened.
    ‘He had ten thousand men. He marched them into the Drakwald, and he marched them out again. When they were in, they were a’feared. When they were out, they bled. And when they stood just halfway in, they turned around and fled.’
    Ingwel’s tail uncoiled, releasing the tension wound into it, and slapped against Solin’s thigh. The other saurus grunted, but his eyes still narrowed into a grin. Thankfully, he took the hint and resorted to humming the tune in the low pitch warmbloods couldn’t hear. Warmblood ears couldn’t catch those low notes—one reason they’d never understand High Saurian, missing entire syllables as they did.
    Even with the warmbloods retired for the night, Ingwel didn’t want to risk someone overhearing and taking offence.
    Ingwel shook his head, but allowed himself a moment of amusement. ‘Try not to sing that where the Graf can overhear.’
    Solin gave him a look of mock-offence. ‘I know better,’ he protested.
    Ingwel’s dry look had his spawn-brother chuckle.
    Solin continued after a moment. ‘If he doesn’t like the song, he should stop acting like the punchline.’
    Against his better judgement, Ingwel snorted in amused agreement. The song had first been sung in Riekland, after a Grand Duke of Middenland’s ill-fated attempt to cleanse the Drakwald. It had enjoyed a resurgence in recent years—coincidentally around the time Graf Todbringer took the eye of the beastman Khazrak, and lost his own in return. Rather than praise Todbringer’s victory, his rivals preferred to mock the retaliation he’d suffered and the fact that the beastlord still lived.
    Thus was born the rivalry between Graf and beastlord, and Ingwel couldn’t tell whether Todbringer’s anger burned hotter over the loss of his eye or over becoming the new face of that song.
    He shook his head and absently shooed a raven from the map. The corvid gave an irritable caw, then flapped to a nearby tent and glared down at him. Ingwel returned the courtesy by ignoring it.
    ‘Your thoughts?’ Ingwel asked after a long pause spent studying the map.
    ‘Altdorf is large enough to house everyone within the city. Plenty of empty warehouses and abandoned buildings we can take over for however long it takes Horeo to arrive,’ Solin said, his good cheer fading. ‘Especially in the East End.’
    ‘And the Emperor won’t complain about a mercenary company taking up residence inside the city walls?’ Ingwel asked.
    Solin shook his head. ‘Unlike Middenheim, Altdorf is a trade city first. Its nature makes armed escorts and free companies far more accepted than in a fortress-city like Middenheim.’
    That matched Ingwel’s own conclusions. He wouldn’t be surprised if they drew scrutiny; even diminished, the Outland Legion had more than earned its “legion” moniker. But even at full strength, it would hardly be an overwhelming force against a city as vast and cosmopolitan as Altdorf.
    They would also be arriving with the implicit approval of the Graf of Middenland. Rivalries aside, that still carried weight. Boris Todbringer wasn’t the sort to let the Empire suffer simply because the crown hadn’t gone to him. He’d never have been a contender for the crown if spite alone could make him turn on the Empire.
    Ingwel’s gaze narrowed, tracing the route that would be taken for the umpteenth time. ‘Even with the Graf’s desire for us to make good speed, that’s a four cycle trip. At least. That’s going to be a moon spent travelling.’
    Solin huffed out a breath. ‘It’ll be five. Human endurance is good, but comes at a price. Either they push themselves and require longer rest periods, or they go at a slower pace and recover more quickly.’ His eyes rolled up, narrowing in consideration. ‘I’ll wager that he’ll want the slower but steadier pace.’
    Ingwel’s attention drifted to another map laid out. ‘And it takes Horeo between two and three moons to sail from Madrigal to Marienburg, depending on the weather. Add another cycle for the journey up the River Reik. Even if we take our time, we’ll be waiting for a moon.’
    ‘If Karl Franz’s summons doesn't hold us up, we can always just go to Marienburg to wait there. Should arrive within the same cycle as Horeo.’
    Ingwel shook his head softly at Solin’s suggestion. His thoughts drifted to the missive, sealed with wax bearing a sigil he had made a point of memorising. It bore not just the crowned griffon, but the Imperial Cross itself. This was not a summons from Grand Prince Karl Franz Holswig-Schliestein. This was a summons from Emperor Karl Franz, first of his name.
    Ingwel’tonl—the Outland Legion as a whole, in truth—might not be beholden to the Empire, but only a fool would ignore a summons marked with the Imperial Cross. And so, bound by neither oath nor law, they were still going south, to stand before the latest in a long line of emperors.
    ‘Tempting, but I’d rather err on the side of caution with our rendezvous. We don’t know why the Emperor has summoned us. If Horeo sails for Altdorf, we can remain in the region—if not the city itself.’
    Solin hissed out a sound of agreement. ‘Fair enough.’
    Ingwel’s gaze drifted to the looming silhouette of Middenheim, its vast form swallowed by night, betrayed only by the flicker of lights within.
    ‘Besides,’ he mused aloud. ‘I would prefer we be at the south of the Reik Basin when winter hits. At least that way we’ll still be able to drill the new blood. And then, we have our pick on which direction to go. North, if they still need help that way. Or we can track down the undead if they’re still lingering.’
    By all reports, those undead that hadn’t simply dropped like stringless puppets at the battle's end had moved in a southerly direction when they withdrew from Middenheim.
    Solin noticeably glanced in the direction of the other camp, eyes narrowed in a display of wariness. ‘Let’s leave that to them.’
    Ingwel huffed, chanced a look in that direction himself. Alas, the night swallowed the neighbouring camp and its standards, so he saw even less than he did of Middenheim.
    ‘Get some rest,’ he finally said, grabbing the maps and carefully rolling them up. ‘Tomorrow we leave.’
    Solin patted him on the shoulder as he walked away, humming that tune yet again now that their conversation was over. Ingwel didn’t bother telling him to stop, even when he caught the words uttered.
    ‘The Grand ol’ Duke of Midden. He led them bold and loud. But the Drakwald cares for no man’s name. None march out unbowed.’
  12. J.Logan
    The Border of the Border
    Coast of the Black Gulf - The Border Princes
    In times long since passed, in the age of antiquity, there was an empire. This empire was a vast, powerful realm, but it grew too large to be sustainable, so at some point in its existence, it was decided that the empire would be split in two, rulership of each half given to different sons to inherit. Two halves of a greater whole.
    They believed the Reman Empire would reign eternal—east and west—expanding ever outward.
    Time made a liar of those who made such bold claims.
    The Reman Empire fell. It fractured beneath its own weight. Senatorial intrigues, civil strife, and would-be warlords convinced of their manifest destinies. Greenskin hordes pressed at them while marauders swept down from the mountain clans, beastmen howled through the forests, and Dark Elf raiders bled their coasts dry.
    Over time, the weight of all this strife caused the Reman Empire to collapse, its foundations worn away and rotted. Any hope that might have come of reunifying the Tilean peninsula and restoring the once powerful empire was further crushed by the Black Plague, leaving behind a region ruled by a myriad of city-states.
    Thus ended the Reman Empire. The Western Reman Empire.
    What many people did not know was that the Reman Empire lived on in its eastern counterpart. It had since renamed itself, had become the Aurean Empire, but it was a widely accepted truth within the Aurean Empire, that they were the inheritors of the Reman Empire, the continuance.
    There was pride. They were the continuity of the Remans, but they were also proud because they had a purpose.
    If Kislev was the Northern Bulwark of the Old World, the first line of defence against the invasions of the Chaos threats from the inhospitable north, then the Aurean Empire is the southern shield of the Old World—or so every child of Aureosthal is taught. A shield long since dulled, but not yet shattered. Their capital, the city of Aureosthal, also known as the Golden Citadel, was positioned as an immovable bastion against those that would come from the Badlands.
    Yet time gnawed at the Aurean Empire as it had its western twin. In the end, only the name remained. A hollow empire. A ghost wearing a crown of gold.
    The former territories of the Aurean Empire, like its western twin, had been chipped away; warlords carved out their own fiefdoms, only to be devoured by the next within decades. Thus was born the region known to the rest of the world as the Border Prince Confederacy. All the while, the city of Aureosthal, all that remained of the once proud “Golden Empire”, was left constantly fending off the threats that would arrive from the south. Time and again, they fended off those threats.
    Trade withered. Provinces fractured. Warlords rose and fell in a single generation. Greenskin tribes swept from the Badlands. Beastmen hunted the wilds. Vermin swarmed beneath the earth. Even Tilean merchants turned their gaze elsewhere.
    It had become clear that theirs was not going to be a glorious end. Theirs was to be the slow death of attrition. A thousand cuts had been endured, a thousand chips in the walls that had never been broken. The Golden Citadel endured every cut. A thousand cuts. A thousand more. But walls, like empires, remember every blow. And walls, like empires, can bleed.
    Within the Border Princes, sellsword companies were a common way of life. Only half of that was due to the constant need to fend off the threats that skulked the lands. The other half, the original reason for the common sighting of mercenaries and sellswords, was the Golden Citadel itself. With territory lost, manpower and reserves were likewise denied to them. As more lands were lost, more often were free companies hired to bolster faltering manpower.
    Like many things in the world, this noble intent has long since been perverted by other less righteous causes. The Border Princes took to using the mercenaries crossing their lands for their own purposes, be it to cling to their own power for just a little longer, or to try and remove a rival prince and expand.
    But despite this, the Aurean Empire remained a constant source of coin for those willing to fight for it, for no matter how dry the pool of employment was, the Aureans were always in need of blades to man their walls, to patrol their lands.
    To help fight off the next Waaagh.
    Crossbow bolts sailed the air, pointed heads piercing through flesh. Bodies dropped, tripping those behind as the bolts cut them down. But those further back had seen enough—they didn’t stop.
    Then came the trampling. Crushed, forgotten. Swallowed in the green tide.
    Captain Lorenzo della Falco scowled, tutting irritably. He turned his attention from the front of the charging mass, taking in the greater whole, brow creasing in thought. It was a passing thought, one that was quickly shuffled aside in favour of more pressing concerns.
    ‘Pikes, forward,’ he roared.
    There were times that he wished he had the means to arm his men with handguns. Unfortunately, handguns were expensive. As a company of sellswords, and a company that wasn’t particularly famous at that, black powder weapons were a luxury that he could ill afford to equip in number.
    A single cannon was all he could justify. And the cannon had to be weighed each time—was it worth bringing to a given job, or held back for a more pressing need?
    Technically, this fight wasn’t part of any contract. This wasn’t a patrol, or a hunt. This had been a moment of getting ambushed while in transit to their next employer. Which meant that this was a fight that they weren’t going to get paid for.
    As it stood, the cannon was positioned in such a way as to fire at any greenskins that tried to circle the formation now forming a particularly pointy wall.
    The pikemen who advanced at Lorenzo’s order were clad in heavy armour, all veterans who had survived long enough to earn their steel. Those eighty men were the iron spine of the company, the image that Lorenzo wanted people to think of when they pictured the Golden Griffon Company.
    The iron phalanx advanced between the two crossbow units and lowered their pikes, bracing. The greenskins were simple of mind, but not wholly stupid. Those at the front of the charge were aware of the danger that came of rushing headfirst into a braced pike formation. Unfortunate for them, the rear ranks hadn’t realised the danger and kept pushing those at the front ever onward.
    Despite the discipline of those pikemen, the long hard-earned experience, there was an air of nervousness. Lorenzo didn’t need to see the faces behind those sallet helms to know that it was not stoicism that painted their expressions, but nerves, trembling anticipation of the moment green met their pikes.
    One pikeman muttered a prayer. Another spat. A third shifted nervously with knuckles doubtlessly white from how tightly he gripped the haft.
    The swarming tide of green met the thorned wall with a crash. Greenskins yelled, warcries mixed with wails of pain as bodies were run through. Despite the shoving of those further back, the tide was stemmed, held at bay.
    The crossbowmen loosed more bolts at the greenskins, angled to hit the side flanks of the mass that was pushing against the pikes. Bolts thudded out again, cutting into green flesh. Then the crossbowmen dropped behind their pavises, hands moving fast to crank, load, breathe, repeat.
    Given time, the greenskins would start spilling out, their mass losing its blocked ‘formation’ as those at the edges saw a chance to circumvent the pike wall and charge at the crossbowmen. Even less barbaric races would lose formation coherency in such circumstances. Nobody wanted to just stand there and take ranged fire at the sides.
    Fortunate then, that Lorenzo wasn’t solely dependent on the one unit of pikes. The moment the initial clash of greenskin versus iron pikemen was met, the other two pike units moved forward, passing the sides of the ranked crossbowmen. Unlike the iron phalanx, these pikemen were not so heavily armoured, simple brigandine rather than plate. But that was to their benefit at that moment, allowing them to move swiftly, to form the hammers with which to crush the greenskins against the anvil.
    The “battle”—if such a one-sided slaughter deserved the term—ended quickly. Those greenskins that hadn’t been part of that single mass that had charged were run down by Lorenzo’s cavalry. Spears ran through the goblins, and those that weren’t skewered were crushed under thundering hooves.
    The green field was left littered with blood and the soon to be rotting carcasses of greenskins. Already the scent of shit and gore was wafting up.
    Carrion birds circled overhead. They would feast before nightfall. For the dead, mercy came faster than coin ever did.
    Lorenzo scowled. A fight without pay, and greenskins rarely left anything worth picking from their corpses. No spoils, no bounty. Still, no dead on his side. That softened the blow. Crossbow bolts were cheap enough to replace. Men were decidedly not.
    With a grunt, he barked orders to comb the field. Greenskins rarely carried anything worth the effort, but “rare” wasn’t the same as never. Some nob might have looted a trinket once upon a time—or, gods forbid, a magic blade.
    Lorenzo grimaced at the memory. Urgat Rip-Eye—an orc warlord who’d stumbled across an enchanted axe, only to find it did the wielding, not him. Controlled like a puppet until Morgan Bernhardt shattered the damned thing during the campaign that had made the Grudgebringers a name worth remembering.
    A useful reminder: sometimes treasure killed quicker than any orc or goblin could.
    While his men did as ordered, Lorenzo turned to look at the young lad he had taken on as a squire. An ill-fitting title, truth be told. The lad did far more than fetch and carry. Apprentice might have been more accurate, but calling him a squire offered a little protection, and protection was rarer than gold in their trade.
    Even “lad” was stretching the truth. If he hadn’t reached his second decade, he was close enough to taste it.
    ‘Notice anything odd?’ he asked.
    The squire lifted the beaked visor of his helm. Amber eyes glinted beneath—sharp, unblinking, unsettling. He narrowed them in thought, gaze sweeping the corpse-strewn field.
    ‘They weren’t organised,’ he said at last. ‘And not just in the usual greenskin way. The sudden, stupid charge you get when they smell a fight.’
    A monstrous screech briefly echoed in the air, followed by the sound of flesh being ripped apart. Both Lorenzo and the squire spared a brief glance in the direction it had originated, but then turned their eyes back to each other.
    ‘That was my thought as well,’ Lorenzo said. ‘Even greenskin battlelust doesn’t explain that mindless charge.’
    The lad looked over the field again. ‘It felt like they were fleeing something. And we just happened to be in the way.’
    Lorenzo let out a breath of amused acknowledgement.
    ‘It did, didn’t it?’ He looked not to the field, but the direction that the greenskins had come from. ‘Now what could possibly scare greenskins into such a retreat?’
    ‘I can’t think of anything that would be good for us.’
    Lorenzo’s jaw tightened. He’d seen greenskins break before. Usually when crushed, when leaderless, when starving.
    ‘See to the men,’ he said at last, voice low. ‘Make sure they’re braced to march quickly. We won’t linger.’
    The squire dipped his head in acknowledgement, lowering his visor again. The beak snapped shut with a metallic click, and for a brief moment Lorenzo wondered whether the lad realised how much that sound reminded a man of talons locking around prey.
    If there was any mercy in the world, whatever had spooked the greenskins would remain in the Badlands, would only be a problem for the local greenskins and not for those living in the lands of the Border Princes. There were enough issues without outside threats involving themselves.
    Still… greenskins bolting north in numbers would explain the Aurean Empire’s renewed request for mercenary companies to bolster their crumbling walls.
    And if desperate goblins were the worst of it, then the Golden Griffon Company was about to earn its easiest purse in months.
    For all their rot and corruption, the Aureans had never once cheated a hired blade. Pragmatism, no doubt. When your armies had dwindled to a shadow of their former glory, and mercenaries kept your last city breathing, stealing pay would be the surest way to hear your empire’s funeral bell.
    The Aureans might be out of touch and corrupt, but they weren’t suicidally stupid.
    He drew in a slow breath, tasting iron and dust. A buzzard wheeled overhead. Somewhere out on the field, a dying goblin gurgled and then fell silent with a wet crunch that was decidedly avian in origin.
    ‘Enough daydreaming,’ Lorenzo muttered to himself. ‘We aren’t paid to stand about thinking grand thoughts.’
    He raised two fingers and cut them through the air, signalling the sergeants. Orders rippled down the line. Pavises lifted. Pikes angled. The steady clatter of discipline replacing the hush of uneasy aftermath.
    Time to move.
    Whatever had driven the greenskins north, he wanted his men behind stone walls before they met it. With a contract signed. Payment guaranteed. Gold preferred. Silver tolerated. Exposure, glory, and “future considerations” strictly rejected.
    Because knowing his luck, and the grudge that the gods seemed to delight in levying upon him, what had spooked the greenskins was a bigger, meaner greenskin that they did not want to serve under. And he was not fighting what could become a Waaagh without an iron-clad promise of coin. He’d bled enough in his life to know that glory didn’t pay wages. Coin did.
    The city of Aureosthal. Captain Lorenzo della Falco had spoken of visiting often in his life. The Aurean Empire—such as it still was—had long been a reliable source of coin for sellswords. Whenever the company coffers ran dry in the Border Princes, a march to Aureosthal usually filled the chest again, enough to fund a return to more profitable fields.
    It had, however, been some years since Lorenzo’s last visit to the city that clung to the vestiges of its former glory.
    Jarek Griffson was not impressed.
    Even the walls betrayed a people too enamoured with their own reflection. The gilded ornamentation gleamed in patches where the sun struck, but beneath the paint and polish lay cracked stone, uneven plaster, and repairs so crude even fresh paint couldn’t disguise them.
    Why did they bother? Were they truly so obsessed with appearance that they’d waste gold to hide scars instead of fortifying them? The banners draped across the walls did a better job of concealing damage—and for a fraction of the cost.
    At the gates, a line of guards manned a checkpoint. Not that there was much demand for entry. The Golden Griffon Company were the only ones waiting, and there was no sign of anyone leaving.
    Fear, perhaps. If talk of a coming Waaagh had reached the city, the merchants were likely sheltering behind their walls. The farmers too, maybe. Jarek frowned at the thought.
    There must be farmers. A city that didn’t grow its own fields made little sense to him.
    Importing food? The very notion was absurd. Luxury goods, fine wine, silks; those he could understand. But the necessities of life? Depending on others for survival was weakness.
    Behind him, he felt more than heard his mother slowly stalk up behind him, snorting softly. Sometimes he wondered if she was able to hear his thoughts, because that was a well timed snort for the trek that his mind had taken.
    At the gate, one of the guards broke off mid-sentence, his gaze drifting lazily past Lorenzo before freezing on Jarek. Or more precisely, on the creature behind him.
    ‘Myrmidia bugger me!’ the guard yelped, stumbling back.
    Lorenzo didn’t miss a beat. He turned, expression deadpan.
    ‘Please don’t request divine buggerings while looking at my squire.’
    ‘But that’s a bloomin’ gryphon!’
    The guard’s voice pitched somewhere between terror and outrage, but the way he mangled the word made Jarek blink.
    ‘Gryff-un?’ he muttered under his breath, brow furrowing as though the guard had personally offended his sense of linguistics. Behind him, his mother gave a low, disdainful huff. It was a sound that suggested she agreed entirely.
    He had learnt, just through talking with the company, that accents varied, but that was a horrible mangling of the word.
    Lorenzo rolled his eyes and pinched the bridge of his nose.
    ‘Did you think we called ourselves the Golden Griffon Company because we admired the last two to use the name?’ he asked. The tone made it clear it was rhetorical.
    Rhetorical—a word Jarek had learned only recently while squiring under Lorenzo. One of many, in fact.
    Even if the captain’s tone hadn’t given it away, Jarek knew better than to answer. The truth was, the griffon was a recent addition to the company, and even then, only barely counted as part of it.
    Jarek’s mother nudged his shoulder and then stalked away, no doubt bored of the guards.
    A few chuckles rippled down the company line. Barely stifled relief disguised as humour. The guard did not laugh, he looked like he was struggling not to wet himself.
    ‘Captain della Falco,’ came a new voice from beyond the gate. It was smooth, nasal, and trying very hard to sound important rather than nervous. It perfectly matched the expression of the man to speak with such a tone. ‘If your exotic… entourage is quite finished terrifying my sentries, the Prokletariat Office stands ready to process your company’s arrival.’
    Lorenzo exhaled the weary breath of a man who had survived battle only to be ambushed by parchment and pomp instead. Jarek had learned in his time as the captain’s squire that bureaucracy truly was worse. Paperwork was a foe that would not be felled by axe or bravery.
    ‘Wonderful,’ he muttered. ‘From greenskins to gilded quills, all in one march.’
    He jerked his chin at Jarek.
    ‘Come along, lad. Keep your mother close.’
    ‘Bold of you to assume that I have any say in how close my mother stays,’ Jarek mumbled under his breath.
    Lorenzo snorted, which had Jarek wonder whether the captain had heard regardless of his lowered volume. Lorenzo’s lips twisted into a grin that promised nothing good.
    ‘Come along,’ he repeated.
    Beyond the gate, the city looked just as hollow in its vanity as the walls had been. True, there was less sign of slapdash repairwork; if enemies had ever breached the walls, it had been long enough for every trace to be scrubbed away. But that almost made the decay all the worse. Paint was not a recent addition, leaving buildings looking worn and faded with time. The clothing worn by the people of the city were clearly supposed to be rich and exotic with vibrant dyes, and yet like the paintwork over the buildings, the colour had long since been muted to dull hues.
    Lorenzo cast a look at the official, who seemed to have relaxed once back on the inside of the city walls, straightened his posture and carried an air of stubborn pride. After a moment of staring, he turned to look at Jarek with a stern expression to his features.
    ‘Right lad, this is your first time here. Things for you to remember. Don’t disrespect the religion of the Aureans, they’re very… particular.’
    Jarek tilted his head quizzically. ‘Usual Tilean and Estalian gods? That one guard mentioned Myrmidia…’
    But already Lorenzo was shaking his head. ‘Myrmidia isn’t a goddess here, she’s considered a divine saint. And I wonder whether that was a concession made to avoid issues with how many Tilean and Estalian mercenaries come here. No, the Aurean Empire worships the Gods of Law.’
    ‘The who?’
    Lorenzo’s teeth bared in a mirthless grin. ‘Aye, that’s about the usual reaction. The Gods of Law… but don’t mistake that for being a wholly good sort. Law without compromise. They are not forgiving gods.’
    Lorenzo frowned for a moment as some thought or another hit him, and then spat on the ground.
    ‘Law without mercy isn’t good—it’s just cruel with rules.’
    ‘Anything I need to know in particular?’ Jarek asked, eyebrows raised at the uncharacteristic display Lorenzo had just given. ‘Their names?’
    ‘Solkan will be the main one. The one to watch. You’ll see his symbols everywhere.’ He gestured toward a nearby banner of red and gold, the sun emblazoned at its centre. ‘Any mention of the sun—that’s him.’
    ‘Solkan, the sun god,’ Jarek said, committing it to memory. ‘And why’s he the one to worry about?’
    ‘Because among his titles are “Father of Vengeance” and “The Merciless”. His is the punishment for any infraction—divine retribution without care for circumstance.’
    ‘Sounds… pleasant.’
    ‘If you see robed figures in gold masks,’ Lorenzo went on, his tone sharpening, ‘turn around and leave. They’ve got “divine authority” to be judge and executioner. They are the law here.’
    ‘And if some zealot does start reciting law at you,’ Lorenzo added quietly, ‘don’t argue, don’t speak, don’t breathe unless told. Folk vanish in this city for less than back-chatting a cleric.’
    As if summoned by the words, a solitary robed figure passed at the end of the street, a featureless gold mask turning fractionally toward them before gliding on. The crowd pretended not to see.
    Jarek swallowed. ‘They sound… well-adjusted.’
    ‘Oh they are,’ Lorenzo replied dryly. ‘Perfectly balanced. That’s the problem. Law sharpened to a fine edge. If there’s so much as a nick on it, it cuts you to the bone.’
    Jarek cast another look around the street. The people hurried with heads bowed, clothes faded like forgotten murals. Banners fluttered proudly, yet the fabric frayed at every edge. A city propped up by memory and stubbornness, refusing to surrender dignity even as it crumbled in its grasp.
    Aureosthal smelled of incense and rust, old pride and quiet fear.
  13. J.Logan
    J.Logan Well-Known Member
    The Redcoats are Coming!
    Altdorf City Gates - Reikland
    Konrad Kruger sighed, boredom gnawing at him like a persistent rat. Guarding Altdorf’s gates was safe work—too safe. Reikland hadn’t seen a real war in years. Skirmishes with beastmen and the odd Chaos cult hardly counted. So he stood, day after day, halberd in hand, watching nothing happen.
    So, guarding the city gates? Not a station that brought with it a terrible risk to his life. The most action he had ever had was that time that a band of drunken scoundrels had tried to urinate upon his leg. Those same cads swiftly found themselves on the ground, hands cupping their nethers, and dragged to a cell where they could sober up and then pay a fine for “attempted assault of a member of the Altdorf City Watch”. Apparently the law had made that point very specific some time a few centuries ago.
    Which begged the question of what was happening at the time that warranted a specific legal definition for urinating on a member of the city watch. Though honestly, Konrad was most concerned with the fact that the ruffians in question weren’t scrappy young lads, but older men who really should have known better.
    Were there times that Konrad regretted joining the City Watch instead of something more prestigious or respected, such as the army? Well, when his leg was soaked in the urine of a man old enough to be his father, then certainly. But most of the time? Not particularly. He had never felt the need to explore the lands, never felt the urge to set foot outside of the city within which he had been born and had lived his entire existence.
    The Watch suited him. Service without glory, duty without travel. A comfortable rhythm. Some called it dull. Konrad called it home.
    And ignoring the long stretches of nothing, he did get to see interesting people as they came and went. Altdorf was the centre of the world, people from all over came to Altdorf at some point or another. And as the guard stationed at the gates to the city, he was in a place to see them, to wonder what their lives had been like before that moment they stepped through the gates.
    But those moments of seeing and greeting (for a given meaning of the word) interesting folk was always interspersed with long stretches of nothing. Standing stoically, halberd held at rest, eyes forward and scanning for anything untoward. The only relieving element being that he was stationed with a partner, and there was nothing stopping from the two of them chatting.
    But after years of standing guard together, there was not a lot that they had left to speak of. Anything new in their lives was typically spoken of early in the shift and then that was that. Back to debating the same old subjects. Or re-hashing the same old jokes.
    ‘Why are we here?’
    ‘Isn’t that one of life’s great mysteries?’ Konrad asked, lips twitching in amusement.
    He felt the side-eyed glare that held no real heat, unlike the first time when he had missed the point of the question and waxed philosophy that he didn’t understand, using words he’d overheard from people that seemed far more learned than he in an effort to sound like he did know what he was talking about.
    ‘You ever think about asking to be re-assigned?’
    Konrad shrugged the shoulder not attached to the arm holding his halberd up. ‘To what? Road scout? I can’t even ride.’
    ‘Yeah… same.’ Pause. ‘But it would be interesting. News from the world before anyone else hears it.’
    ‘Fascinating,’ Konrad drawled. ‘We’d see them from a distance, wave, then gallop back here to tell the gate captain that someone is coming. Either merchants with paperwork to check, or raiders with banners, so they need to lock down the gate and ring the bells.’
    ‘Sigmar, but you are boring.’
    ‘I’m content.’ Konrad tapped the butt of his halberd softly on the stone. ‘I know my place in the Empire. And that place is here. At this gate. Listening to your prattle.’
    A distant clatter broke the quiet—slow at first, then sharp and urgent against the paving stones. Konrad looked to the source of the sound, and spotted the approaching rider, clad in the uniform of a road scout of the Altdorf Watch.
    ‘What news?’ Konrad called out, once the scout had slowed his horse to a canter.
    ‘Travellers on the road,’ the scout answered, gently coaxing his mount into coming to a complete halt. ‘An army.’
    Konrad tensed. ‘An army?’ he repeated.
    ‘Aye. I didn’t recognise most of the standards, but amongst them was the banner of the Grand Duke of Middenland’s personal troop.’
    Konrad relaxed slightly. ‘We were told to be on the lookout for the Grand Duke. He’s late, but he has been expected.’
    ‘Which is why I’m not calling for you to seal the gates,’ the scout huffed. ‘But he’s not travelling with just his guard.’
    Konrad’s partner tapped the butt of his halberd against the ground in a rhythmic pattern. ‘The roads are dangerous between here and Middenland. Are you surprised that he’s got more than a single company of guards? Even the Elector of Wissenland travelled with a battalion, and they’re right next to us.’
    The scout scowled. ‘I’m saying they aren’t Middenlanders. Not just extra guards.’
    Konrad tensed anew. ‘How can you be certain?’
    ‘They aren’t human.’
    ‘Oh, well, that explains everything and nothing at all.’ Konrad rolled his eyes, quashing down the instinctive revolution at the the idea of anybody spending time with non-humans. ‘Dwarfs? Elves? Gnomes?’
    ‘Giant green lizards,’ the scout said flatly, as though the words themselves tasted wrong. ‘Wearing red coats.
    Konrad blinked. Stared at the scout. Blinked again. ‘Erm…’ The sound escaped him. ‘That sounds even less likely than gnomes.’
    He tried to picture it—lizards in red coats—and failed. His mind supplied something absurd, not remotely real. Yet the scout did not look like a man inventing stories.
    ‘You mean Lustrians?’ Konrad’s partner asked. ‘Mind, aren’t they usually blue? And naked?’
    The scout shrugged, looking baffled. ‘I wouldn’t know. I don’t know anybody who has been to Lustria, so how am I supposed to know what colour Lustrians are?’
    Konrad coughed into his fist, then looked to the scout. ‘The Middenlanders were travelling with them, yes? Willingly?’
    ‘Willing enough, from what I saw. No chains. No blades at their backs. Just… lizards and Middenlanders walking together. And singing. Though I dunno if the Middenlanders were involved in that.’
    ‘Singing?’ Konrad’s voice rose in disbelief.
    ‘Some marching song,’ the scout elaborated, though he sounded exasperated. ‘Not any I know. “O’er the hills and far away” or some such. Didn’t exactly hang around to listen.’
    ‘Of course not,’ Konrad mumbled to himself. The scout had made the current call to just leave and report the travellers. He let out a sigh, and turned to his partner. ‘Go get the captain. I’m not dealing with this…’
    He ignored the snort, and returned his attention to the scout.
    ‘How far off are they?’ he asked.
    ‘About six… maybe seven miles. In their numbers, they’ll be here around sundown.’
    ‘Good. Gives time for the captain to get here and take any responsibility out of my hands.’ He let out another breath. ‘Stable your mount. Stay close. When the captain arrives, he’ll want the report from your mouth.’
    And by that point, all responsibility would be taken from Konrad’s hands. Praise Sigmar.
    The air echoed with the steady beat of drums, backed by the alien music generated of bagged air pushed through piping. Voices were singing to the tune generated, the words were Reikspiel, but the lyrics were unknown to the people of the Empire.
    There was a sense of tired cheer to the voices singing. Triumphant, but tired. It was the voice of an army that had fought constantly, but now had a respite in clear view.
    ‘Through smoke and fire, shot and shell,
    Clashing in the halls of Hell.
    Yet stand we shall, come what may,
    Over the hills and far away.
    O'er the hills and o'er the main,
    Past Bretton, Karak, and Reik's domain.
    Annat’corri's call, we shall obey,
    When darkness falls and night is deep,
    Through haunted woods, our vigil to keep.
    With each step, we'll face the fray,
    Annat’corri's might, our arms display,
    Over the hills and far away.’
    The Outland Legion
    Will Return
  14. J.Logan
    I figured this was a good place to close out. End of the proverbial book 1. I was planning to make it a nice, rounded 50 chapters, but I realised that the final chapters would have been literally nothing to contribute to the Legion's story. And that wasn't even taking into account how the interlude of the Golden Griffon Company was growing beyond my expectations. Well, that and I really wanted to close out this tale before Christmas.
    As to the Golden Griffon interlude... will probably delete that post so I can tweek and put it with its own entry, it's very much becoming its own thing even if in the same setting.
    For now, I shall take a small break, write out the Golden Griffon Company's story as an actual story and not just a world-building interlude, and plan out the next saga of the Outland Legion. And going forward, the Efror Guard will likely also be relegated to their own side stories.
    I'll try to make future stories more focused and concise. As in, "this is the arc for this story" boom, boom, boom. This particular novel-length tale suffered from early plans to be an anthology of shorts rather than a single narrative, and the result was three plot threads in separate directions. Go figure, it's like actually having a plan would be to my benefit. XD
    I do have a roadmap now.
    Behind the Scenes Trivia:
    Why did I go with 1700's British Redcoats for a lizardmen faction? So, when I first got interested in collecting Warhammer, I really wanted to do something unique to me. There was no doubt that I was going to collect the lizard bois. But I really wanted to get away from the Mesoamerican vibe, since it felt like 80% of lizardmen in fiction went that route. At first, I was going to convert my lizardmen into Romans, or ambiguously Greco-Roman. I didn't have access to 3D printing, and quickly learnt that the only Roman-styled minis I could use to convert into lizards (that I knew of) were the Elder Scrolls Empire figures... who are also a touch small for saurus despite being 32mm scale. I still have the 12 (13 if you count Major Zak) figures converted from such.
    I can't remember the exact moment I decided on redcoats. I remember between the Romans and redcoats I had a thought of every squad using a different era of arms and armour; to show them slowly progressing up the historical influences. But I think it was the access to 3D printing that I could use for saurus, while historical figures would fit skinks perfectly, and the realisation that Warhammer Fantasy had no British Empire analogue. We have Albion, which is pre-Roman British Isles, but no Britain post-Norman Conquering. And let's face it, redcoats are fashionable, so hey, I have a look that would be uniquely MY lizardmen.
    Though, I have kept the Greco-Roman element as the normal Madrigal lizardmen aesthetic. XD
    What is up with the Efror Guard? Just as the Outland Legion is my lizardman army project, the Efror Guard is my Empire project. Though they are deliberately anachronistic enough that they could double as Bretonnian; which is also explained narratively by the Count Adelbreckt being a Bretonnian fanboy and modelling his county's armed forces on the Bretonnians. Admittedly, they were originally planned to be written out of the story after the siege on the Feyerabend Keep, but because the Undead are still a presence, I kept them around as a narrative reason for the undead to not be rampaging while Chaos was rampaging.
    Boney: Boney was actually very different from my original conception. I always planned for him to be Skink Napoleon the artillery commander of the Legion, but in his original draft, he was actually already a veteran. I changed him to a newcomer so that I had somebody that could function as the voice of the reader in having details explained to them.
    Such and such character didn't show up or make more than a brief cameo!: Despite being a fan of Warhammer, I will be the first to admit I don't know the canon characters all that well. And if I don't feel like I would be able to write them properly, I try to avoid writing them at all. Boris Todbringer, for example, I know the details of his story, I know he got into a fight and lost his eye, but I don't know his personality and quirks enough to justify trying my hand at writing him in more than a brief appearance.
    If I can't write a canon character accurately to canon, I won't write them.
    Feel free to ask me questions; I shall do my best to answer in a timely manner. I hope you all return for the continuation.
    And question for you all: Here on Lustria Online, should I write the continuation in this thread, or create a new thread for the next part and any side-stories? Wondering if people would prefer the convenience of it all in one place or not.
