AoS Tournament Thunderquake 1500
Discussion in 'Seraphon Army Lists' started by Jatipower, Nov 10, 2018.
  1. Jatipower
    Jatipower Member
    What do you think about this list?
    Allegiance: Seraphon - Mortal Realm: Ulgu
    LEADERS
    Slann Starmaster (260)
    - General
    - Command Trait : Great Rememberer
    - Artefact : Miasmatic Blade
    Saurus Astrolith Bearer (160)
    - Artefact : Incandescent Rectrices
    UNITS
    10 x Skinks (60)
    -Boltspitters & Star Bucklers
    10 x Skinks (60)
    10 x Skinks (60)
    2 x Razordons (80)
    3 x Skink Handlers (40)
    BEHEMOTHS
    Stegadon (220)
    Troglodon (160)
    Bastiladon (280)
    BATTALIONS
    Thunderquake Starhost (120)
    TOTAL: 1500/1500 EXTRA COMMAND POINTS: 1 WOUNDS: 82 LEADERS: 2/6 BATTLELINES: 3 (3+) BEHEMOTHS: 3/4 ARTILLERY: 1/4 ARTEFACTS: 2/2 ALLIES: 0/400​
  2. LizardWizard
    It is always refreshing to see people using alternative load outs of frequently used battalions. The mini war gaming community as a whole tends to put on blinders to other battalions and builds.
    Your list could work well. I personally haven't seen Thunderquake preform well when not at 2k, but I think this is a solid 1.5k version. You would probably be better off dropping the Bastiladon for an other Steggadon and bringing more Razordons or Skinks. Often times when I see the Trog version of Thunderquake Starhost it with two Steggadon & one or more maxed units of Skinks for the steggy synergies. Obviously you can't fit all of that, but I am pretty sure a Steggadon and extra Razordon should have more output than the Bastiladon. Unless your dice are super hot.
    Jatipower likes this.
  3. Jatipower
    Jatipower Member
    The problem is that i have only 2 steggadons so if i use both later i can't summon the engine of the gods so is it worthy?
  4. LizardWizard
    That is very fair. I think the list as it should do alright, I am just always over zealous for Razordons.
  5. Jatipower
    Jatipower Member
    I am totally agree with your advice and I love razordons too xD, they could saturate a lot in big groups with the shoots. If I had 3 steggadons i would follow your advice xD. My first idea was 1 engine ,1 steggadon and 1 bastiladon but it would be 1520 and it would be illegal :'( that's the reason I have chosen the troglodon. I had thought not using the astrolith and with that sacrifice I could use the engine, steggadon and bastiladon but I think it isn't worthy
  6. Aginor
    I have played that exact list a few times and it worked well.
    It probably wouldn't in a tournament, but it sure works in casual games.
    Jatipower and LizardWizard like this.
  7. Jatipower
    Jatipower Member
    I hate this tournament... now they have changed to vanguard and i couldnt use thunderquake :'( maybe i will use shadowstrike but only 2 dinos
