AoS Troglodon. What to do with this.
Discussion in 'Seraphon Tactics' started by Byte, Jul 23, 2019.
Tags:
  1. Byte
    Byte Member
    Hello, everybody.
    New question. I have bought another "start collecting" box. My intention is to assembly a Toglodon. Why? Because I like too much the model.
    My doubt is, worth it? Because to use It in Range I think is better 3 salamaders or 3 Razordons. And to use It in melee maybe I should build another Carnosaur.
    What do you think?
  2. Aginor
    It is a pretty good monster to summon as it is more likely to make the charge.
    It is relatively cheap.
    Against unarmored hordes (like Skaven or so) it can actually do decent damage, and it hurts their bravery so they run away more easily.
    It can be used as an arcane vassal by the Slann to cast spells through it.
    It can be commanded by a Skink Alpha from a Stegadon (because of the Skink keyword)
    It looks scary so it might act as a so-called "distraction carnifex"
    It can lead a cheap Thunderquake if you need to save points.
    You can build the Saurus on foot from the kit, to use as a Sunblood, Astrolith Bearer, Oldblood, or Eternity Warden.
  3. RageCage
    RageCage Member
    Yeah I have used it the most to summon or to cheapen Thunderquake for something else. At 18 summoning points its a monster to bring in charge and as said distract.
  4. GuaDan
    GuaDan Well-Known Member
    Well It is a very good summon. Not as realiable as a bunch of skinks but bumch more fun and extremely cost-effetctive.
    It has to be my favourite summoning choice balancing effectivenes (very high) and fun (extreme).
    Moreover, everyone who is not used to playing seraphon will likely overestimate the troglodon's power, especially after seeing the spit+charge, and that helps more than a lot.
    Lizerd, LizardWizard and RageCage like this.
  5. LizardWizard
    The Troglodon only being 140MPP makes me much more interested in taking it. The only real issue is that 3 Razordons are only 120MPP and more effective. The Trog's biggest shortfall is a complete lack of rend.
    Like others have said, it is still great choice for summoning. I generally view it is as a roadblock that has a high likelihood of making a successful charge.
    knave, Dr.Doom, RageCage and 2 others like this.
  6. Vexcor
    Vexcor Well-Known Member
    in my experience the biggest upside of the troglodon is this size. it has such an psychological effect on the opponent.
    He looks like a real badass like a carnosaurus but in reality its more like a small crawler :D
  7. ILKAIN
    ILKAIN Well-Known Member
    Distraction troglodon is real
  8. Byte
    Byte Member
    Analasing all your andwers, It's a good idea to assembly a Troglodon, mainly because is cheap to summon It and because is a "psichological" weapon.
    Thanks to evereyone.
  9. GuaDan
    Then again the model looks SO good.
    LizardWizard and Aginor like this.
  10. Aginor
    It really does.
    I love mine.
    LizardWizard and GuaDan like this.
  11. Jason839
    Jason839 Well-Known Member
    Can you still arc spells through the skink on the trog?
  12. ILKAIN
    yes, just not endless ones
    Dr.Doom and LizardWizard like this.
