TOW Updated thoughts on the Slann
Discussion in 'Lizardmen Discussion' started by discomute, Jun 29, 2024.
Magic
  1. High
    2 vote(s)
    14.3%
  2. Elementalism
    3 vote(s)
    21.4%
  3. Necro
    0 vote(s)
    0.0%
  4. Battle
    7 vote(s)
    50.0%
  5. Illusion
    2 vote(s)
    14.3%
  1. Manowar83
    Manowar83 New Member
    Hello everyone, coming from the fifth edition of Lizards, where Slaan was the strongest wizard of all. It is still so? How to play? With what objects? With what tactics?
  2. airjamy
    airjamy Well-Known Member
    This is an English only forum.
    Manowar83 likes this.
  3. airjamy
    He REALLY isn't anymore. He is very expensive but has no bonusses to casting. You can make him Ethereal and make him even more expensive,, but that does not give you much. A standard Imperial Wizard costing like 190 points is stronger than our Slann for the points, if i had the option to take one i would.
    I think the best wizards in the game are currently Necromancers. Lvl 4, cheap at like 180 points, and you can get them to +6 or even +7 to cast with Mortis Engines and they revive like 200 points of models per turn.
    skycat likes this.
  4. skycat
    skycat New Member
    Slann + Ethereal = 345pts
    if i had the option to take one i would:
    lv4 Necromancer + Mortis Engine = 355pts
    lv4 Archmage + Griffon = 315pts + 5+regen = 335pts
    lv4 Daemon Prince + fly = 316pts
    lv4 orc wizard + wyvern = 300pts
    lv4 empire wiz + imperial griffon = 320pts
    or
    lv4 mage x 2
  5. MetalTempleGuard
    MetalTempleGuard New Member
    They may not be the dominant force they once were though. It felt as though they used to be a full step above almost every other wizard, and could;
    control the dice pools pretty well,
    Almost perfectly covered from miscasts,
    Bunkered in arguably some of the best melee infantry,
    Greatest spell range,
    Now they are just average/slightly above average in most areas.
  6. airjamy
    Exactly. This shows pretty well how poor our guy is,, the comparison with the Daemon Prince is pretty apt. XD
  7. airjamy
    Reread this, and you think Oaken Shield cannot be cast in close combat? It is a Self spell, so you actually can, makes it a lot better still. Useless on the Slann of course, but strong on Priests.
  8. discomute
    discomute Well-Known Member
    Good call! I did not know that, you can never target a unit in combat unless the spell says otherwise so that's what I had thought. But you're right on that, thanks
    airjamy likes this.
  9. PowerSeries
    PowerSeries New Member
    airjamy likes this.
  10. The bloated lizard
    The bloated lizard New Member
    Battle Magic is easily my first lore choice for a skink priest.
    airjamy likes this.
  11. airjamy
    A column of crystal is impassable terrain per it's spell text. Fly specifically says you can move over impassable terrain with it as long as you do not end in it, so it definitely does not stop movement from flying models. The whole point is that it blocks line of sight, so you still stop the charge, which is why the spell is still good, especially if you can cast it outside of enemy dispell range, which is pretty doable.
  12. airjamy
    I like it as well. Just dislike how Arcane Urgency needs a 10+ to be cast, a priest can't do it reliably.
  13. discomute
    Actually I disagree with this based on the FAQ. It says vortexes are tall enough to effect models that fly. I think that's that... And suddenly dragons are slightly more manageable
  14. airjamy
    I dissagree on that. The FAQ says this:
    Q: If a unit with the Fly (X) special rule moves over a magical vortex that counts as dangerous terrain, is it affected by it? A: Yes. Magical vortexes are considered tall enough to affect even models that are flying high above the battlefield.
    This is about Dangerous terrain. It is not that the Column is Dangerous terrain, it is Impassable terrain, as per the Column of Crystal spell text:
    Effect: Remains in Play. Place a large (5") blast template so
    that its central hole is within 9" of the caster. Whilst in play,
    the template does not move and is treated as impassable
    terrain over which no line of sight can be drawn.
    These are the Fly rules. Pretty clearly they state you cannot end in Impassable terrain, which makes it very clear that they intend for you to be able to fly over Impassable terrain.
    Fly (X)
    Many creatures of the Warhammer world can
    fly, held aloft either by mighty pinions or by
    means of magic, soaring from one side of the
    battlefield to the other.
    A model with this special rule can Fly.
    Models that can Fly can choose either to
    move normally on the ground (using their
    Movement characteristic), or to move by
    flying. How many inches a model can Fly
    varies from model to model, and will be
    shown in brackets after the name of this
    special rule (shown here as ‘X’). Models
    that choose to move by flying:
    • May move as normal (i.e., they may
    charge, march and manoeuvre as if
    moving on the ground), except that
    they are able to pass freely above other
    models, units and terrain features
    without any penalty, and they can
    march whilst within 8" of an enemy
    unit without first having to make a
    Leadership test.
    • May end their movement in terrain,
    but will suffer its effects if they do. They
    cannot end their movement ‘on top’ of
    impassable terrain or another unit, or
    within 1" of an enemy unit.
    Models that can Fly must begin and end
    all of their movement on the ground. A
    character with this special rule cannot
    join a unit without this special rule, and
    vice versa.
    But still, Illusion is fine if your local meta has a LOT of 600 point dragons, because blocking a pivotal charge against a dragon is just worth so much even if you are only blocking its LOS. My local meta is switching over to more MSU/avoidance lists at the moment, so i am kinda going off the Slann Illusion train again and going harder on Battle Magic and Elementalism.
  15. discomute
    Seems clear to me
  16. airjamy
    Yeah well,, they effect them, but there is another rule that mitigates that effect. Without Fly they definitely cannot move over them, but with Fly, it doesn't. It is all very clear and pretty RAW imho.
  17. discomute
    It's clear at this point the TOW guys are pretty bad at writing clear rules. Like, they just put a FAQ about impact hits only effecting the unit you've charged... Okay but what about lance bonuses? Initiative bonuses?
    All your RAW for the rule book is of course correct but I just can't see why you'd interpret the comment "Magical vortexes are considered tall enough to affect even models that are flying high above the battlefield" would only be in reference to magical vortexes that are dangerous terrain. The FAQ overwrites the RAW and not the other way around.
    I absolutely respect people's opinions because... Well because the TOW guys can't seem to make a clear set of rules. But unlike other debates I've had in here (like chief poison on the stegadon, chief firing stegadon, casting magic missile and a vortex in the shooting phase) I really just can't see your point of view. It says clearly that "Magical vortexes are considered tall enough to affect even models that are flying high above the battlefield" so that's that. Whatever the effect the magical vortex has, it is tall enough to affect even models that are flying high.
    At this point I guess we aren't convincing each other so we can agree to disagree.
    airjamy likes this.
  18. - Q -
    Worse than in other Games Workshop games?
    airjamy likes this.
  19. airjamy
    I kinda feel like they went for a more old school style of formatting and writing the rules that is really kinda biting them in the but now. I feel like they really captured the feeling of reading the 8th books back in the day, but because of that the game lacks clarity. I mean if you take a look at how the Fly rules are formulated in 40K, it is just a lot more, staccato, straight to the point and streamlined. I feel like wargamers nowadays are just used to better rules writing and the lack of perceived clarity leads to annoying discussions more than it did back in the day and more than it does for other GW games.
    - Q - and discomute like this.
  20. Gothmog Lord of Balrogs
    Gothmog Lord of Balrogs Active Member
    I think I would like Slann more if I could take 2 of them
