AoS Using teleport twice on same unit
Discussion in 'Seraphon Tactics' started by Jatipower, Aug 29, 2018.
Tags:
  1. Jatipower
    Jatipower Member
    I want to know if you can use the teleport twice on the same unit. For example:
    You couldnt teleport your astroltih bearer because your dice was 1-2 so... could you use it again? I guess not but i prefer to ensure
  2. Aginor
    There is nothing saying you cannot teleport the same unit twice.
    So yeah you can.
  3. Jatipower
    Jatipower Member
    I dindt expect that answer xD
  4. LizardWizard
    You could even teleport your mage up, cast an endless spell, and then teleport him away. There are many amusing tactics available with Great Remember.
  5. Seraphage
    Seraphage Well-Known Member
    1-2 : "The unit cannot move or charge this turn" technically you might say so but it doesn't make sense to me :p
  6. Putzfrau
    I don't believe the seraphon allegiance ability counts as a move.
  7. LizardWizard
    You are correct. It does not count as movement. Technically you can teleport a Slann on Balewind without losing the Balewind. As the Balewind states it is consider part of the model. This might be errated to say that models on a Balewind cannot move of be removed and replaced on the table while on a Balewind Vortex.
  8. The17thYak
    The17thYak Active Member
    I see no reason why you can't, and I've toyed with the idea myself, my one concern would be failing the "return" cast and having a unit very exposed
  9. PJetski
    PJetski Active Member
    I don't think this is the case. The balewind and the wizard riding it are treated as a single model after you cast Balewind.
  10. LizardWizard
    You definitely can do it. I have done it at tournaments. They might errata it away, but for now it is legal.
  11. PJetski
    How is it legal? They are treated as a single model, so you can't teleport off it because you would teleport the Vortex along with you.
    "I've done it at tournaments" isn't an argument...
  12. LizardWizard
    The Balewind Teleports with the model because they are treated as one model. It doesnt matter that the model loses its move characteristic because LoSaT does not make use of the move characteristic. You can use a Slyvaneth Wildwood to teleport Slyvaneth wizards who are ontop of Balewinds as well.
    Putzfrau and Canas like this.
  13. PJetski
    My mistake, I thought you meant that you could teleport the Slann off the vortex and replace him with another model.
    I'm not sure why I read it that way.
  14. LizardWizard
    That is my bad. I was not very precise in my initial statement.
