Lord Agragax of Lunaxoatl
Eleventh Spawning
There are lots of different interpretations of the 9 alignments. Since it's a pretty fictional system of splitting up the cosmos there is not right answer.
The biggest change occured in 3rd edition. Neutral used to mean a midway point between good and evil, but Neutral turned into "Diet Good." Neutral characters want good things for other people, and they oppose evil, but they do not make major sacrifices to help others oppose evil without some other incentive.
Then there is an assumption that all nine boxes must be filled. In which case you find the best possible fit for every box. In which case both @NIGHTBRINGER and @Lord Agragax of Lunaxoatl 's interpretations are valid.
But I would argue that by the fluff, most of the blocks should be blank. Given that the Chaos Realm drives fluff so heavily, there is a lot built around Law versus Chaos. There are not many Warhammer factions that would qualify as Neutral with regard to Law and Chaos, and all of the Neutrals in this regard are Neutral Evil, Dark Elves, Skaven, Vampire Counts. Maybe Wood Elves could qualify as True Neutral. Her is my take.
- Beastmen Chaotic Evil
- Bretonnia Lawful Neutral with good tendencies
- Chaos Dwarfs Lawful Evil
- Daemons of Chaos Chaotic Evil
- Dark Elves Neutral Evil with Lawful tendencies
- Dwarfs Lawful Neutral with Good tendencies
- Empire Lawful Good
- High Elves Lawful Neutral with Good tendencies
- Lizardmen Lawful Neutral
- Ogre Kingdoms Chaotic Neutral with Evil tendencies
- Orcs & Goblins Chaotic Evil
- Skaven Neutral Evil with Chaotic tendencies
- Tomb Kings Lawful Neutral
- Vampire Counts Neutral Evil
- Warriors of Chaos Neutral Evil with Chaotic tendencies
- Wood Elves True Neutral with Lawful tendencies
- Dogs of War (who most people don't count) True Neutral with Evil tendencies.
I'd personally swap Empire and Bretonnia around - the Empire is more like the "soldier following orders" to the letter because of the Emperor's dictatorship, whether the Emperor is good like Karl Franz or corrupt like several rulers they had, while Bretonnia is obviously the "righteous knight" - and would put Dwarfs and High Elves in the good side of the spectrum, otherwise you're pretty much spot on I'd say.
