AoS 2k lists of skinks, and only skinks
Discussion in 'Seraphon Army Lists' started by Iblitz, Mar 13, 2020.
  1. Batch
    Batch Active Member
    Seems like the RAI maybe I'm just being nitpicky xD
  2. LizardWizard
    You only have use the FoS Command Trait if you take a Saurus as your General. K.O have several subfactions that function the same way.
  3. Iblitz
    Iblitz Well-Known Member
    So, where is the "for saurus général only" ?
    LizardWizard and Batch like this.
  4. LizardWizard
    It says it directly about listing the command trait:
    "A Fangs of Sotek Saurus General must have this command trait instead of the one listed on page 57"
    -Seraphon Battletometome 2020 pg64. Top Right column of Fangs of Sotek Abilities.
    Which means only a Saurus general must have the FoS command trait. However, it doesn't say that a Saurus must be your general. So, if you pick a Slann or Skink then you still pick your general's command trait from their respective list.
  5. Batch
    Batch Active Member
    I think what hes asking is that a Saurus must have that trait fair enough, but what's stopping other non-Saurus generals from taking it?
  6. LizardWizard
    Nothing in RAW. Based on the flavor text and the bold restriction test it is pretty easy to see the langue is identical to the command traits from the Saurus section.
    I think a strong argument can be made that a Skink or Slann is able to choose the command trait if they wanted. Not sure all TO's would buy that, but enough of them would.
    Batch likes this.
  7. Iblitz
    It's weird that the only skink focused bataillon has a Saurus warlord trait...
    LizardWizard and ILKAIN like this.
