AoS 2k thunder quake small event
Discussion in 'Seraphon Army Lists' started by forlustria, Feb 4, 2019.
  1. forlustria
    forlustria Well-Known Member
    So its a fun list not fully competitive but i think its ok.
    Astrobearer
    Eotg
    10skinks
    10skinks
    10skinks
    4 salamanders
    Skink handlers
    Trogolodon
    5 chameleons.
    Thunderquake
    Probably the eotg in tq . trog just teleporting and taking out chaff. Summoning will be used to get more skinks .
  2. Aginor
    Very few wounds on the table sounds risky, make sure you summon some rather early.
    Other than that...
    I am not quite sure if the five Chameleons will pull their weight. That can be used to harass, but quite often just five of them will not do a lot of wounds.
    They can however disturb enemy movement and/or shooting for a turn or two, which might work against alpha strike lists.
  3. Furnus
    Furnus Member
    In my experience the Trog sadly does nothing but disappoint.
    I don't have the points in my head, but if you're looking for a teleport alpha, maybe an idea could be to drop the Trog and the camo's for a Stegadon.
    You can teleport the Stegadon and then use Skink Alpha for a D6 move to make the charge easier. Then you hit the enemy with our only -3 rend attack. That should put the hurt on anything :)
    Also, I definately agree with Aginor, you've gotta summon more bodies to the table quickly.
    Have a great game!
    GuaDan likes this.
  4. Robertxtrem
    Robertxtrem Active Member
    I'd drop the trog and the camos for 50 more skinks to be honest. More bodies.
