AoS AOS CAMPAIGN WARBAND
Discussion in 'Rules Help' started by KROQ-GAR and GRYMLOQ, Aug 1, 2016.
would you like to see a campaign warband allegiance comepetition to be held?
Poll closed Aug 5, 2016.
  1. yes, necessary
    4 vote(s)
    100.0%
  2. no, unnecessary
    0 vote(s)
    0.0%
  1. Bowser
    I still think the competition idea is great and we should do that, see what others come up with. Maybe they go a skink route with troglodon instead of carno, or eternity warden and sunblood instead.
    KROQ-GAR and GRYMLOQ likes this.
  2. KROQ-GAR and GRYMLOQ
    KROQ-GAR and GRYMLOQ Member
    yea otherwise why dont we use your one as an example/template
  3. KROQ-GAR and GRYMLOQ
    When do you think we should host this como I can get the stuff organized by the end of August. But I wonder if I might be interfering with other comps
  4. Bowser
    Yeah lets go end of August beginning of September. Give people a week or so, that way there's minimal interference with other comps.
  5. Ecozh
    Ecozh Active Member
    It's a shame my Local store just decided not to play a path to glory Campaign, else this would have been exactly what I was looking for.
    Curious how your Campaign will work out!
  6. KROQ-GAR and GRYMLOQ
    All right followers of the old ones GW has issued a Generals handbook which includes different types of play the Seraphon can participate in any of the types of play except for Narrative Play, this includes The campaign mode where you can set up a War band and campaign against the other factions of the AOS. To tackle this issue and prevent us from waiting for an official to come out (if there will ever be one) we want a community created Warband table for all the Seraphon players to use and to prevent being kept away from the fun! Now we are hosting a competition as too who can create the best (and the fairest) warband campaign table, the rules are as stated below.
    · The warband table must require only seraphon units
    · The warband table cannot exceed the strength of the other races
    · One is required to have red the Path to Glory chapter of the Generals handbook from the GW
    · The follower’s reward table and the champions reward table must have a connection to the seraphon.
    · All warband plans must be posted before the deadline the 30th of September
    · And finally let your creativity Flow!
    what do you think of it?
    Ecozh and Bowser like this.
  7. Bowser
    Alright changed up my original a bit for the contest, and may enter a Slann based or Skink based one later.
    Champion table:
    Champion Followers
    Oldblood on Carnosaur 5 units
    Scar-Vet on Carnosaur 6 units
    Scar-Vet on Cold One 7 units
    Sunblood 8 units
    Oldblood on Foot 8 units
    Followers Table
    D6Followers
    1- skinks
    2- warriors
    3- guard
    4- knights
    5- chameleon skinks
    6- kroxigor
    Monster Followers
    D6 Followers
    1- 2 1 unit of 2 razordons or salamanders with handlers
    3 1 unit of 3 terradon riders or 3 ripperdactyl riders
    4- stegadon
    5- bastiladon
    6- troglodon
    Hero Followers
    D6 Followers
    1- skink star priest
    2- skink priest
    3- scar vet on Cold Ones
    4- eternity warden
    5- starseer
    6- astrolith bearer
    Followers Reward Table
    D6 Reward
    1 Recalled From Memory: At the beginning of the game you may choose not to set this unit up instead in any movement phase you may set up this model any where on the board more than 9 inches away from an enemy model.
    2 Unstoppable: this unit doesn't take battleshock
    3 Starlight Weapons: if the wound roll for a celestite weapon carried by a model from this unit is 6 or higher and it charged in the same turn, the attack inflicts an additional mortal wound.
    4 Hard Scales: in your hero phase you can declare hard scale defense. This unit can not take any action during the movement phase, this turn when you make save rolls for models in this unit, ignore enemy's rend characteristic unless it is -3 or better and re-rolls failed save rolls.
    5 Savage Memories: models in this unit add 1 to their damage characteristics.
    6 Meteor Shower: for every enemy unit within 3 inches of this unit, roll a die for each model in that unit or units. On a 5 or more that model suffers a mortal wound.
    Champion Rewards Table
    2D6 Result
    2 Shady Memory:
    If the champion is slain you lose D3 glory points (to a minimum of 0) And lose all rewards this champion has gained so far in the campaign.
    3 Predatory Instinct: in each hero phase roll a d6. A result of 3 or lower the champion must charge the nearest enemy unit subtract 1 from all hit rolls and add 1 to all wound rolls. On a 4 or more the champion re-rolls all failed hit and wound rolls.
    4 Primal Roar: Once per battle you may use the primal roar. If they do so add 1 to the hot roll for the champion and all units from the warband for the rest of the turn.
    5 Savage Strength: Add 1 to all wound rolls for attacks made against models with a wound characteristic of 7 or more.
    6 Weapon Of The Gods: Choose one weapon used by the champion (it can not be a weapon used by the mount if the champion has a mount) Increase the damage characteristic of that weapon by 1.
    7 Scales Like Steel: Add 1 to the wounds characteristic of the champion.
    8 Unbreakable: Add 1 to the bravery characteristic for the champion and all units from the warband that are within 8 inches of the champion in the battleshock phase.
    9 Celestite Star Shield: Reroll all failed save rolls for the champion.
    10 Terrifying Advance: Add 2 to all charge or run rolls made by your champion.
    11 Unseen Benefactor: In one of your hero phases choose 3 enemy units. Deal D3 mortal wounds to each of those units. Can only be used once per battle.
    12 The Bright Constellation: Once per battle in your hero phase, you can heal all wounds on your Champion. Or if your Champion is slain roll a D6 on a 5 or 6 the champion is set up on the battlefield anywhere more than 9 inches from an enemy unit. This counts as their move for the following movement phase.
    Bracnos likes this.
  8. KROQ-GAR and GRYMLOQ
    alright! but we need to start a page for the comp
  9. KROQ-GAR and GRYMLOQ
    and advertising
  10. Bowser
    Oh oops! My mistake, I didn’t even think of that. Thought we were posting them here and then putting up a voting thread after. Alright do you want to start the thread?
  11. KROQ-GAR and GRYMLOQ
    ya can u think of advertisisng?
  12. KROQ-GAR and GRYMLOQ
    is there a special forum for comps?
  13. Bowser
    We can ask a mod to pin it, ask for it to be on the banner now that the voting is over for the golden serpent. Throw out a couple of flickers about it. I think it's good to keep it in the AOS discussion board though.
  14. KROQ-GAR and GRYMLOQ
    Who do i request this to be on the banner?
  15. KROQ-GAR and GRYMLOQ
    http://www.lustria-online.com/threads/aos-campaign-warband-competition.18400/
  16. Bowser
    I think you would ask @The Red Devil if they can update the banner with this and maybe the visual art contest.
  17. The Red Devil
    We can put an announcement for the voting, please send me a PM with the desired text you would like on the announcement.
  18. KROQ-GAR and GRYMLOQ
    would it be possible to advertise the competition itself?
