AoS bastiladon save question
Discussion in 'Rules Help' started by Slikus Vaw, May 23, 2021.
  1. Slikus Vaw
    Slikus Vaw Active Member
    So I got a question with the bastions save. So when it’s getting attacked and it goes down a tier and it’s for say being attacked with a multi attack hero and it goes down a tier halfway between the attack sequence of the triggered unit does the save characteristic stay until all the attacks go through or does it change right away?
  2. Slikus Vaw
    im thinking it stays the same cause all the attacks trigger at the same time as in when picking different targets you have to declare what attack is going where before dice are rolled
  3. Tav
    Tav Well-Known Member
    Yes, nothing changes until after the units activation is finished. You do all the attacks, all the saves, then only at the end do you allocate damage, which affects the damage table
    Slikus Vaw likes this.
  4. Kakalou1
    Kakalou1 Member
    Do you know in which FAQ they say that it IS immune to rend when he is full life ?
    I read it on the forum but cant find a proof
  5. Tav
    Battletome seraphon designers commentary. Faq section on the warhammer community site
    Erta Wanderer likes this.
  6. chefofwar
    chefofwar Well-Known Member
    once you get past that first wound bracket, normal rend affects the saves correct?
  7. Erta Wanderer
    yep
  8. Killer Angel
    ...and that's why it's good to have the ability to heal your basti!
