Contest Golden Serpent 2016
Discussion in 'Painting and Converting' started by The Red Devil, May 31, 2016.
Thread Status:
Not open for further replies.
  1. Bowser
    Make a wet pallette and thin the paint out a bit. Should go on slightly better.
    Xlanax_lot likes this.
  2. SlanntaClause
    I think the paint is too wet as it is its a layer paint and just thinly spreads itself everywhere i'll try use a pallet though see if that helps I need to do a second layer because my hit rate was about 50% the first try :p
    Xlanax_lot and Bowser like this.
  3. Bowser
    Which colour did you get thatis causing so many problems? And what did you prime it with?
  4. SlanntaClause
    White primer and auric amour gold? its behaving like the ink stuff I used to use to use for lord of the rings way back - you know a wash maybe? where u let it seep into reeceses for effect?
  5. Xlanax_lot
    Xlanax_lot Well-Known Member
    Gold and white are always troublesome colors, the best advice I can give u is patience, and by this I mean dont expect to cover the area using a single layer, for this paints do the following instead:
    1. Don't overload the brush with paint (to avoid pooling and covering the details of the model)
    2. Paint using many thin layers instead of a single thick one. I know it is frustrating and even if the first layers appear to be transparent, keep going. The finall result will be worth it
    3.for the gold, you can mix it with a bit of brown, yellow, orange, or silver depending on what is closer to what you want the color to look in the end. This will help with the coverage
  6. SlanntaClause
    Thanks both :D the only other colour I had is a silver so maybe I will mix them :p
    Bowser and Xlanax_lot like this.
  7. Crowsfoot
    And make sure you mix it well in the pot!
    NIGHTBRINGER and Bowser like this.
  8. Bracnos
    Bracnos Well-Known Member
    @SlanntaClause oh ya if you primed in white and then trying to.do any metallic is a pain took my like 12 layers for the gold to look right when I did that
  9. SlanntaClause
    Thanks maybe I chose the wrong primer then I have a grey one and a white only at the moment :p - I don't wanna give too much away about my entry so wont say what other colours ill get in the future but it'll be a limited colour scheme I think. I've got a month to layer it on :D
  10. ASSASSIN_NR_1
    Well you are not the only one who have had problems with that particular color. Maybe it is just that that color is more susceptible to being too thin.
    But your problem should be solved with the advice of the painting pros.
    SlanntaClause likes this.
  11. SlanntaClause
    Honestly I should have asked on here before asking the Warhammer shop guys advice on it he wasn't all that helpful or interested to be honest - I might try borrow my brothers paints he got a few when we were in the shop together. Its a tiny distraction from my conversion model - I have steps planned but for some reason haven't done any to it for a day or so.
  12. Rokanos
    Rokanos Well-Known Member
    @SlanntaClause - put a layer of Leather (medium to light tone) brown down before you do gold. This will help it be a more true gold color. Then I'd mix a bit of the same brown in with the gold 1scoop of brown to about 2-3scoops gold if it's as thin as I'm picturing. Or - take the pot back, show him how awful it is, and get Balthasar gold base instead. You can then mix it with varying amounts of silver to get your highlights (thin it out on a wet pallet for this or it'll be too thick for layering)
    Hopefully starting on my entry tomorrow - provided my stubbornness lets me put what I'm working on on hold :p
    SlanntaClause and Bowser like this.
  13. Crowsfoot
    I try to work with limited colours, I tend to be around 5ish so you don't need loads of paints to get a good effect, just choose them carefully.
  14. SlanntaClause
    Thanks once more I was considering taking back the pot - this was after stiring it in for a few mins the stuff just returns to the top and makes it hard to gauge if you actulley get any gold on your brush when you dip it in:
    It was all the way to the top when I opened it its like a milky substance - oh well the first layer turned out okayish so maybe just re-layering a few times is the way to go
  15. Rokanos
    Yeah...id take that back. It shouldn't look like that at all.
  16. BeardyGecko
    BeardyGecko Well-Known Member
    That looks pretty dodgy to be honest. I tend to base in leathery browns and build up through copper colours for gold. It worked pretty well with Grey knights anyway.
  17. neveroddoreven
    neveroddoreven Well-Known Member
    Yeah, that's the reason I gave up on metallics, all the ones I bought were like that. I did try out the Vallejo ones and they're much more consistent.
    Is it ok if I put an entry into the Lizardmen painting category? I've just come from a big win in another competition and I want to see if I can get a streak going.
  18. Bowser
    You should definitely enter!
    Why wouldn't you be allowed to? Of course you should enter. That's why the master tier was created... gives us mere mortals the opportunity to (enviously) watch the divinely skilled painters of this forum battle it out.
    Jorgik, ASSASSIN_NR_1 and Bowser like this.
  20. Xlanax_lot
    You should definatelly enter!! Just Dont forget to take a pic with the wip paper!
Thread Status:
