AoS Homebrew Mount Traits
Discussion in 'Seraphon Discussion' started by Lizerd, Dec 9, 2020.
  1. Lizerd
    Lizerd Well-Known Member
    As we all know, the battletome was pretty solid, but it lacked the almighty mount trait, the hallmark of a modern AoS army. So, after a little bit of thought, some ideas "borrowed", I can somewhat provide for that severe deficit. as always with homebrew stuff C&C would be greatly appreciated
    special credit to @PabloTho and @Nart for writing out their own traits, many of them were worked into this list
    General Mount Traits
    Loping Gait- reroll run and charge rolls
    Old and Grizzled- reroll failed save rolls
    Unmoving- when this model attacks, it counts as having full wounds for the purposes of its damage table
    Carnosaur Mount Traits
    Apex Predator- add one to the attacks characteristic of this models claws and jaw
    Razor Talons- improve claw rend by -1
    Jaws of the King- if an unmodified wound roll of 6 is made with this model's jaws, that attack inflicts an additional d3 mortal wounds
    Stegadon Mount Traits
    Ferocious Charge- add one to the damage characteristic of this models horns if it made a charge
    Unflinching- 6+ ward save
    Massive Crest: armored crest always applies to this model if it is in melee combat
    Troglodon Mount Traits
    Bottomless Bile- flat 3 attacks for spit
    Improved Senses- you may add 2" to the result of any charge roll this model makes
    Resilient- heals a flat 3 wounds
    Cold One Mount Traits
    Pack Leader- Reroll hit rolls for cold one's snapping jaws for units wholly within 6"
    Swift footed- this model has a movement characteristic of 12"
    Horned One- roll a d6 when this model successfully makes a charge, on a 4+ it inflicts d3 mw to target unit
    Terradon & Ripperdactyl Mount Traits
    Slicing Jaws- improve the rend characteristic of jaw attacks by -1
    Fast Target- grants a -1 to be hit for attacks directed at this model in the shooting phase
    Expert Glider- this model may run and still charge
    Dragvindel, PabloTho and Ryanj4043 like this.
  2. Dread Saurian
    Unmoving is absurd to the max degree. Get the realm of ghur ability without spending cp what the hell? Put that on an old blood with carno and you got a way more efficient and useful dread saurian.
    Lizerd likes this.
  3. Tav
    Tav Well-Known Member
    Having something like move up the damage table by 1 would be good, that way you have damage 5 or 4 for longer on the jaws and it doesnt go below 2
    Lizerd likes this.
  4. Lizerd
    so simply have the damage table bumped up by 1? gotcha
  5. PabloTho
    PabloTho Well-Known Member
    OB on Carnosaur in a Thunder Lizard Sunclaw Temple-Host with Prime Warbeast, +1 Attack Asterism and Apex Predator would be nuts.
    He'd start with 3 Jaw attacks at -1 rend and 5 damage...
    +1 attack for Coalesced
    +1 attack for Prime Warbeast
    +1 attack for the Asterism
    +1 attack for Asterism
    +1 rend for Sunclaw Temple-Host
    Leaving him with 7 attacks at -2 rend and 5 damage. He's also got a pretty good melee weapon in the Sunstone Spear.
    I play a lot of Mawtribes as well, and this statline would basically make him kind of like a squishier Frostlord on Stonehorn, which would be awesome. If you piled on his own CA and the CA of a Scar-Veteran then there's probably not a lot he couldn't munch through.
    Dragvindel and Lizerd like this.
