7th Ed. how do you transport your army
Discussion in 'Lizardmen Discussion' started by shahryar, Dec 15, 2009.
  1. Kurlin
    Kurlin New Member
  2. Buhallin
    Buhallin New Member
    I have a large (12"x17"x5") clear plastic case, that I epoxied a large piece of sheet metal to the bottom after cutting it to size. With rare earth magnets (or 2) in the base of each model, I can barely get them to move if I try. They hold vertical, upside-down, you name it. I could probably use it as a standard suitcase if I wanted to. I don't, but I could :) It's a relatively cheap solution - about $18 for the box, $4 for the sheet metal, and the magnets are $0.17 each. I used to use Sabol, and still do for a lot of other stuff, but counting the number of trays I'd need for a hundred-strong army... <shudder>
    I've got some of the flex steel on the way from Litko to line my movement trays with, and depending on how the magnets interact I may magnetize the bottom of the trays too... Magnets magnets everywhere! :)
  3. Exodial Hunter
    Exodial Hunter New Member
    Search KR Multicases, they do gw style trays with hard cardboard cases for £20. That gives you 144 slots for minitures. THey also do a pick'n'mix selection where you can choose what trays you want. Eg. a double depth, single depth and a double depth push out layer for monsters etc.
    They do also sell hard cases, and i swear by them, never failed me once.
  4. JohnMavrick
    JohnMavrick New Member
    I actually use the army cases. On cavalry and my other bulky models I cut out some of the foam walls in order to fit them. As for the slann/carnosaur/stegadon I have one of the red warhammer cases with the large foam insert.
  5. Arsenal
    Arsenal New Member
    I second that, I have several KR multicases and they are amazing. You can get them in North America for around 25$ from FRP Games in California. Cheap, super easy to modify and customize, you can write directly on them to label them easy, and even though they are cardboard they are damn sturdy. I highly recommend these as well.
  6. Exodite
    Exodite New Member
    Yeah KR multicases have served me well, quick delivery good price and helpful staff.
