AoS is a roll of 1 a fail?
Discussion in 'Rules Help' started by Vexcor, Jul 27, 2018.
  1. Vexcor
    Vexcor Well-Known Member
    Hi guys,
    there was a rule which said a "1" is a fail, right?
    so two examples:
    A Carnosaurus hit with his claws, so he get +2 to hit with his bite, which is a +1 to hit at the end.
    Does he hit automaticly?or is a "1" still a miss?
    Saurus guards have with an warden and battalion a +2 to save. in cover they have +1.
    Is this an autosave for them or is a "1" still a fail?
  2. Flo
    Flo Well-Known Member
    Depending on the roll itself but yes a Hit/Wound or Save Roll is always a fail
  3. Vexcor
    Ah ok thx
  4. Aginor
    No, he doesn't hit automatically, a hit roll of 1 _before modifiers_ is still a fail.
    In the same way, a hit roll of 6 _before modifiers_ is always a success.
    Mentioning the modifiers is an important thing, because it plays an important role in some situations.
    You might think a +2 on hit doesn't make a lot of sense, but it changes a few subtle things.
    The sequence is:
    1. You roll a dice. If it shows a 1, then you missed, regardless of buffs and debuffs.
    2. If you have rerolls (from an Astrolith Bearer for example) then you can now reroll. Otherwise: End of the attack.
    3. If you rolled a 2 or higher, you add 2 to the result. If your opponent debuffed your hit rolls in some way, you substract that.
    4. If the final result after modifiers is equal or higher than a 3, you can now move on to your wound roll.
    So as you see the 2+ makes sense because even if your opponent debuffs your Carno, when he hit with both claws then his jaw attack will still hit on a 2+.
    Here is a example for the auto-hitting 6, btw:
    You play some Skinks with Javelins, and get into melee. Those guys have a 6+ to hit.
    You attack an enemy hero bearing a Miasmic Blade, which gives you -1 to hit. Now, that would mean that you have to hit on a 7+, which can never happen without modifiers. But unmodified rolls of 6 will still hit.
    Same as above, a 1 before modifiers is still a fail. But the +1 from cover can still be useful, for example when your enemy debuffed your save in some way, or has a rend of -2 or better.
  5. Vexcor
    thx for the explenation, really helps a lot
    Aginor likes this.
  6. Canas
    To be honest this is one of the weirdest and most confusing aspects about this game. It's impossible to prevent your opponent from hitting cuz a natural 6 will Always hit, but you can completly negate that special "on a 6+ do stuff"- ability. It's rather weird,.
  7. Seraphage
    Seraphage Well-Known Member
    Totally makes sense to me @Canas, gives debuffs the important impact they should have imo !
  8. Canas
    It's inconsistent though, which is what makes it weird. Though I guess the issue is that without natural 6's and 1's automaticly failing/hitting it'd be too easy to completly defang certain weak units as 1 (de)buff could make em always fail/succeed
  9. Vexcor
    if the 1´s wouldn´t be an automaticly fail, then Saurus guards in a battalion are nearly indistructible in cover.
    a carnosaurus would bite everything to death when he gets his claws on somebody
  10. Aginor
    Yeah there would be quite some units that have stats like a 6+ hit so they could easily debuffed to hit nothing at all, and on the other side there would be several who could always hit.
    Canas likes this.
