Let's Get Motivated - November 2022
Did not get anywhere near my goal for November.
Finished the build and magnetizing for the EotG.
Got all of the guard models started. But only finished 6/15.
Didn't even touch the Slann to finish him up.
Hopefully I will free up some time in December!
My end of the month recap:
- finish painting 5 skinks with blowpipe (shields and bases left to do)
- finish painting 4 Mordor Orcs
- finish some Gondor Scenery I started last month
- Specify plans I have for more Gondor Scenery
- Have a game night with my brother to start/testplay our new campaign
- Read and vote on the Short-Story competition(write some form of review as well)
- And of course the workshop that I gave
- And the stray projects that I did
I forgot to mention the extra 11 Mordor Orcs and 2 Morannon Orcs I got done last week :)
Um... I got one of my big squigs turned into a Squigga Kan, and then got sidetracked working on 3rd edition Predator/Rhino/Vindicator tanks for a Chaos Marine Armored Company I came up with... so... hobbying got done, but not what I'd intended?
Okay so Im a little bit late but here's my recap:
  • The skinks are based and ready for priming. I didin't prime them because I found out the hard way that the sparay I was using melts the type of plastic that GW models are made of.
  • I managed to at least finish the base for that gryph hound since sadly that was the reason for my spray discovery. At least it was a model that I can get cheaply online and not one of the skinks. (but on the bright side, now I have a broken gryph hound statue terrain piece/objective marker)
  • I finished painting the seraphon inspired terrain, It could've turned out better, but it was mainly done to test out some paints and ideas as well as being usefull for games. I also finished my trees made out of crudely melted sprues and a small extra terrain bit
:wideyed: what primer were you using that melts Polystyrene that easily!
In hindsight, the solvent in most rattlecans will melt styrofoam, but I am impressed if it is enough to take off injection molded polystyrene as well.
Well done on your progress!
That is tough stuff. From what distance did you spray the miniature?
I'll have to look into it, but there is a possiblity thay may have sprayed a too close to the model
Back
Top
