Tutorial Meeting Engagement tactics
Discussion in 'Seraphon Tactics' started by Bartuk, Apr 4, 2020.
  1. xoid
    xoid Well-Known Member
    I've been wondering about this too, so went and found it based on LizardWizard's memory. It is in the Flesh Eater Counts designer commentary, and I've attached a screenshot of the relevant question (sorry for the sloppiness of the edit, I'm on my tablet and don't know of a better way to do it.
  2. Bartuk
    Bartuk Well-Known Member
    It is also in the mawtribes commentary. :pompus:
  3. Überskink
    Überskink New Member
    Thank you! You helped me very much!
  4. Bartuk
    Allegiance: Seraphon
    - Constellation: Dracothion's Tail
    Mortal Realm: Ghyran
    Spearhead
    Lord Kroak (320)
    - Spell: Stellar Tempest
    5 x Saurus Guard (100)
    Main Body
    Saurus Astrolith Bearer (140)
    - Artefact: Godbeast Pendant
    Skink Starpriest (120)
    - General
    - Command Trait: Master of Star Rituals
    - Spell: Hand of Glory
    20 x Skinks (120)
    - Boltspitters Celestite Daggers & Star Bucklers
    Rearguard
    8 x Salamander Hunting Pack (160)
    Endless Spells / Terrain / CPs
    Balewind Vortex (40)
    Total: 1000 / 1000
    Extra Command Points: 0
    Wounds: 59
    I am thinking about this list. What do you think?
    Too many points invested into Kroak?
    Use Kroak as general for d3 ccp?
    I know this list will loose at least 2VP if the enemy slays all skinks in 1 turn or 4VP if he splits the killing into two turns.
  5. Xuil
    Xuil Well-Known Member
    As far as I can tell, there’s very little reason to run Dracothian’s Tail over Fangs of Sotek, for meeting engagements.
    You want to maximise the phases in which you can score points by dealing wounds. Parting shot both adds a phase (their charge phase) where you can score VPs and potentially denies them a combat phase.
    Similarly, it’s one of the few scenarios where Razordons can still shine.
    Kroak is solid. He SHOULD give you enough mortals in the hero phase to score, even using his first slot to summon, which I almost certainly would. Terradons are a mean summon for meeting engagements and you still can’t go wrong with a hunting pack here and there.
    Bartuk and LizardWizard like this.
  6. Bartuk
    I think you are right. I thought about dropping the Skinks and Salamanders around Kroak. But i can just LoSaT them and they will shoot anyway.
    Parting Shot will be really good at protecting the Skinks (and getting some more unexpected wounds before the enemy turn ends if i go first).
    I think the wounds in the hero phase are needed in the first turn because there may be nothing in range going first and not doing a risky teleport.
    I will change the list to FoS, Serpent God dagger will go to the astrolith bearer. If i feel i need more CP's i can go with old and grizzled on him too otherwise i stick with master of starrituals.
  7. Bartuk
    After having played about 10 Meetings over the last weeks, i found this list to be my first go to list for a competetive environment.
    - Constellation: Fangs of Sotek
    Spearhead
    Lord Kroak (320)
    - General
    4 x Salamander Hunting Pack (80)
    Main Body
    - Artefact: Serpent God Dagger
    20 x Skinks (120)
    Rearguard
    Bound Purple Sun of Shyish (60)
    Total: 1000 / 1000
    Wounds: 55
    I will be testing the following changes next:
    1) OUT: Bound Purple Sun / Salamander (Spearhead) IN: 5 Guard (Spearhead) / Bound Quicksilver Swords
    2) OUT: Bound Purple Sun / Salamander (Spearhead) IN: 3 Kroxigors (Spearhead)
    Some things i learned so far:
    • On the small Table (and with the limited casters) Kroak + Astrolith (+ sages staff) are dealing a lot of dmg almost everywhere i needed it.
    • The Skinks have to be within range of a hero to get their overwatch shots (and run away), although they are only 20, they can kill a lot of the other small units in 2 rounds of shooting.
    • The two Salamanders in the rearguard teleported to a weak spot within range of a hero for the RR 1 to hit can have a huge impact in turn 3. (And 160 Points in the rearguard are acceptable.)
    • The Purple Sun can get some lucky kills but is just not reliable enough. I will test the long range of the quicksilver swords next.
    • One Salamander provided look out sir but can fumble with only 3 shots and i most of the time not worth a CP to reroll ones.
    • Kroak was seldom in danger of dying, so the saurus guard may be unnecessary. The 3 Kroxigors with their move 8 may be usefull (even without a skink nearby in the spearhead).
    • Kroak as general is needed for the additional d3 CCP.
  8. Bartuk
    I will update the first post in the next week due to the massive changes od the arrival times.
    Currently i am working on my list. Here are two possible lists:
    Allegiance: Seraphon - Constellation: Fangs of Sotek
    Spearhead
    Slann Starmaster (260)
    - General
    - Command Trait: Arcane Might
    3 x Kroxigor (140)
    4 x Salamander Hunting Pack (110)
    Main Body
    - Spell: Extend Astomatrix
    20 x Skinks (120)
    Rearguard
    Endless Spells / Terrain / CPs Bound Quicksilver Swords (40)
    Total: 1000/ 1000 Extra Command Points: 0 Wounds: 65
    Spearhead
    Lord Kroak (320)
    - General
    3 x Kroxigor (140)
    5 x Chameleon Skinks (90)
    Main Body
    Skink Priest (70)
    20 x Skinks (120)
    Rearguard
    3 x Aetherwings (40)
    - Allies
    Total: 1000 / 1000
    Wounds: 68
  9. Gailon
    Gailon New Member
    Resurrecting this thread a bit. Some friends and I are fitting in meeting engagements as a faster format for when we don't quite have the time for a full game. It's an interesting format.
    We roll randomly for battle plan right before the game, so that one plan with reverse deployment helps to keep us on our toes a bit. One list I am thinking about running is the only one where I could see a battalion being at all viable:
    - Constellation: Koatl's Claw
    Spearhead
    Saurus Oldblood (110)
    - Warblade
    - Artefact: Eviscerating Blade
    5 x Saurus Knights (100)
    - Lances
    Main Body
    Saurus Scar-Veteran on Carnosaur (210)
    - Warblade
    - Artefact: Bloodrage Pendant
    10 x Saurus Knights (200)
    - Lances
    Rearguard
    - Lances
    Battalions
    Firelance Temple-host (160)
    Total: 1000 / 1000
    Extra Command Points: 1
    Wounds: 63
    I am not sure the battalion makes sense. I should probably replace it with a unit of terradons and skinks for objective seizing and screening. The +3" to charge is tempting, but the charge will probably be more determined by just getting the turns.
    I have played two games and ran really different lists:
    Spearhead
    Saurus Sunblood (130)
    - Lances
    Main Body
    Lord Kroak (320)
    10 x Saurus Guard (200)
    Rearguard
    - Lances
    3 x Terradon Riders (90)
    - Sunleech Bolas
    Purple Sun of Shyish (50)
    Total: 990 / 1000
    Wounds: 63
    This one went pretty well. With the smaller table I found the Celestial Deliverance could get in range to a decent amount of stuff and +2 to casting (with the asterism) was sufficient most of the time. Although I rolled pretty well with the purple sun. The Sunblood with an eviscerating blade has the potential to dish out crazy damage if you manage to roll a few 6's.
    The terradon's in the rearguard were great. They can get to a critical spot, and I used them to screen out an enemy unit that was the lynchpin to the win.
    - Constellation: Thunder Lizard
    Spearhead
    10 x Skinks (60)
    - Meteoric Javelins Celestite Daggers & Star Bucklers
    3 x Kroxigor (140)
    Main Body
    Stegadon with Skink Chief (250)
    - General
    - Command Trait: Prime Warbeast
    - Artefact: Fusil of Conflaguration
    - Weapon: Skystreak Bow
    10 x Skinks (60)
    3 x Kroxigor (140)
    Rearguard
    Skink Priest (70)
    2 x Salamander Hunting Pack (220)
    Extra Command Point (50)
    Total: 990 / 1000
    Wounds: 70
    The skinks are just here for screening. The theory was to get the priest on the board with a lot of command points built up and boost the stegadon with the dual command abilities and/or the salamanders.
    This Stegadon with prime war beast and Great Drake is just such an absolute unit, it obliterated anything I could charge into.
    Are people finding some fun lists? Any more thoughts on meeting engagements?
    LizardWizard and Bartuk like this.
  10. Bartuk
    Just a short answer, can go more in depth when i am at home.
    (If you drop the battalion you are no langer allowed 3 units from the same warscroll.)
    This is my current competetive list. Did some changes caused by the new rules from ghb2020.
    Spearhead
    Lord Kroak (320)
    - General
    3 x Kroxigor (140)
    Main Body
    20 x Skinks (120)
    Rearguard
    - Allies
    Bound Geminids of Uhl-Gysh (70)
    Total: 1000 / 1000
    Wounds: 64
  11. Gailon
    Gailon New Member
    Good point on the battalion!
    Do you find that 20 skinks is enough to get value out of the starpriest?
    Ened up playing this list and winning:
    Mortal Realm: Ghur
    Spearhead
    Skink Starseer (140)
    - Spell: Tide of Serpents
    - Lances
    Main Body
    - General
    - Warblade
    - Command Trait: Dominant Predator
    - Lances
    Rearguard
    3 x Kroxigor (140)
    - Starstrike Javelins
    Total: 1000 / 1000
    Wounds: 72
    I had to deploy Main Body first, then spearhead and rearguard. The block of 10 knights with the starpriest is an absolute hammer. 70 attacks at +1 to hit on the charge can proc a lot of mortal wounds. the theory here was to use the Starseer to give the knights a 3d6 charge and hit from far. But I failed on my 15 inch charge (which is pushing it). But I got lucky on priority and got the charge next turn and just erased a couple units. He was able to kill of the knights with his heroes coming in but I held the objective advantage for two turns and won.
    Meeting engagements are fun, but the rearguard doesn't seem to have much impact, and one battle plan where you have 50% chance of deploying in reverse order isn't really enough to incentivize putting anything there. For this list I really should move the kroxigor to the spearhead as body guards for the priests for after the knights charge off.
    Also, eviscerating blade is a devastating artifact with just the tiniest bit of luck.
  12. trungmi102
    trungmi102 Member
    great thread! I looks forward to learn more from this! ty!
    Bartuk likes this.
