8th Ed. New Lizardman army book and info
Discussion in 'Lizardmen Discussion' started by Rikard, Aug 21, 2012.
  1. A Total Newb
    A Total Newb New Member
    Pinktaco, I think it's against the forum rules to post exact point values. I'd guess 15-25 points.
  2. Pinktaco
    Sorry about that. :)
    It have already been answered though, but thanks anyway.
  3. rothgar13
    rothgar13 New Member
    Just post it in Skavenslaves like everyone else does. What's the base cost of a Skink Priest? Has that changed at all?
  4. sirkently
    sirkently Member
    Unchanged for both 1st or 2nd level skink priests.
  5. beardedgecko
    beardedgecko New Member
    just surious why i dont see any new lists with salamanders, heard they only went up 5 pts since 7th
  6. sirkently
    sirkently Member
    Can't march and shoot. Template is now strength 4 but only uses the -1 armour save from that. No autopanic.
    The interesting thing now is that there isn't a cap on unit size. So you could run one unit of 5 or 6.
  7. GCPD
    GCPD Active Member
    There's still auto panic. It's under the rules for fire throwers in the brb, which salamanders now use.
    S4 isn't much change. It's actually just as good vs Chaos Warriors as -3as. It's also better at lower quality troops. It's is of course much worse about getting vast armour better than 4+.
  8. Vukodlak
    Vukodlak New Member
    How would you guys operate a Slann with the new book,
    putting it with tons of upgrades into a temple guard with razor banner, is cool, but costs tons of points.
    Then again the etheral discipline is also quite expensive, and a lot of armies have magic warmichines.
    I still play with the idea of fielding the Slann on its own even without etheral.
    What would you suggst?
  9. GCPD
    GCPD Active Member
    Probably the same as before; slann with 24+ temple guard. Don't bother with the razor.
  10. Vukodlak
    Vukodlak New Member
    I tend to agree about the razor thing,
    with halberds they get chaos warriors to a 6+save (if they use halberds as well), that should be enough.
    I also play with the idea of fielding 2 25er Saurusblocks with Spears and provide them with a Scar Vet (with only limited magical gear). Statistically they should be able to take on juicy enemies as well
    Any thoughts on that?
  11. rothgar13
    That's what I've ended up with as well. I'll also point out that my list has 2 Sallies, to my slight chagrin. I hate those models - anyone got conversion ideas?
  12. GCPD
    GCPD Active Member
    Kroot hounds, flesh hounds...
  13. beardedgecko
    theres a guy who makes dimetrodon models of the same scale, can't remember his name although hes on facebook.
  14. Mahtis
    Mahtis New Member
    Salamanders are now more better anti-infantry than before. Against cavalry and anything with better AS it's now worse, so I'm worried what we can use against cavalry.
  15. Rettile
    Rettile Active Member
    wow, it would be awesome run 2 units made by 5 salamanders!
  16. GCPD
    GCPD Active Member
    Stegadons. And surprisingly rippers for the non monstrous kind.
  17. Mahtis
    Mahtis New Member
    Personally I'd probably use High magic Slann and switch one spell to searing doom :D But Stegadons would do great, even against monstrous cavalry now thanks impact wounds doing d3 wounds (with an upgrade). Still would have hoped that we'd have something specialized taking cavalry and monstrous cavalry. Razordons would have been nice, maybe lowered it's barbs strength but giving no as (or something) ^^
  18. Why
    Why New Member
    Sounds like the only new models I will be buying are two stegadons.
    Does the bastiladon really have strength 4? Seems odd that a skink chief could carry as much weight as that tank of a creature.
  19. eppe
    eppe Member
    Yes it's only S4. The only good thing about it... or useful... is if you want to run Jungle Swarms.
  20. LogicalUnit
    LogicalUnit New Member
    Yep, and while it only gets 3 attacks, one of them is S10 and has to be used against an enemy in the Basitiladon's rear arc.
    Not great.
