Help Painting Metal Minis
Discussion in 'Painting and Converting' started by Lizerd, Jun 26, 2021.
  1. Lizerd
    Lizerd Well-Known Member
    A quick score online landed me some stuff, and notably a vintage metal carnosaur (poggers). However this comes with a problem, I've never painted metal minis. Questions are:
    1. What prep work do I need to do on a metal mini? is it easy like plastic or do you have to preform more elaborate action like with resin?
    2. After painting, do I need a clear coat to make sure paint doesn't chip?
    As for the carnosaur this is the model, probably will require some pinning and super glue
    Noxolotl and Warden like this.
  2. ASSASSIN_NR_1
    1. A standard basecoat is fine. If you want to, the paint is easier to strip from a metal mini.
    2. You absolutely must apply a clear coat to prevent chipping.
    The tail on the carnosaur, at least in my case, was a bit tricky with large gaps, so keep than in mind.
    Also the legs were not on the same plane, so it could not stand perfectly, hopefully you've got a better specimen, but it's something to look out for.
  3. Lizerd
    Damn metal models also get warped? Fingers crossed then
    also good to know on the clear coat, i should have enough of it to cover the carno when its done
  4. ASSASSIN_NR_1
    I Don't think it's so much that they are warped, as it is the molds not always being as well made as you would hope - at least that's my take on it
    Noxolotl and Lizerd like this.
  5. Christopher
    Christopher Well-Known Member
    Building a metal Pentinent Engine from 40K is by far the hardest thing I've done in this hobby.
  6. Tyranitar
    Tyranitar Well-Known Member
    You can paint as you normally would. I'd def recommend pinning the larger pieces otherwise they'll break under their own weight easier, likely just the tail in this case, and maybe pin kroq-gar to the carnosaur. As mentioned, a clear coat is necessary, might not hurt to do several through the paint job. Or at least one after priming and one at the end. Lastly, be extra careful not to drop it onto your plastic minis, it will annihilate everything it touches lol
    Noxolotl, Warden and Lizerd like this.
  7. Warden
    +1 to this. Even with a clear coat they might still chip after a few years of tabletop use.
    I would also recommend pinning in locations where just glue won't hold the model together thanks to the weight of the metal parts. I would not be shocked if you had to do a little pinning in the leg/tail.
    Noxolotl, Lizerd and ASSASSIN_NR_1 like this.
  8. Noxolotl
    Noxolotl Well-Known Member
    I would also maby suggest using epoxy glue for the larger parts of the model. Don't use too much though, as cleaning the spills is not fun.
    Lizerd likes this.
  9. The Red Devil
    I strongly agree, I always use a two-component epoxy together with pinning on metal models. If you do this they will never break apart again, while if you just pin and use superglue they have a tendency to break apart if dropped.
    Noxolotl, Lizerd and NIGHTBRINGER like this.
  10. Lizerd
    How toxic is epoxy glue? I could look into getting some since you guys are speaking so highly of it
  11. Noxolotl
    As long as you don't drink it, set it on fire and inhale the fumes from it, everything should be fine.
    But if we talking safety when using it, i would recommend wearing cheap rubber gloves and mixing it in a small container that can be thrown away. I also suggest applying it with something thin to avoit it leaking from the model.
    Lizerd likes this.
  12. The Red Devil
    As mentioned it is as toxic as most glues we use for the hobby.
    I would recommend getting the epoxy that is ready in a syringe-type of packaging where you just press and get the required amount of each part.
    When doing a model, you only need a tiny bit, so this type of packaging will last longer than the ones with separate tubes.
    Here is a picture of the type I mean.
    https://hanghoiknifemaking.com/images/21005-p.jpg
    Edit:
    There are also different types of epoxy types, for use with the hobby, I would recommend getting one that cures in 5-15min all depending on how fast you normally work.
    Imrahil, Warden and Noxolotl like this.
