Tk'ya'pyk
Well-Known Member
Seek casts Izema a toothy grin as he ties off the rope around his waist. "Ah, lovely (pleasure)! You already know how this works (delight? amusement? joking?)!" A moment later Seek grabs the mast with both hands and uses his feet to gently, but firmly, shove you off of the mast and over the side of the ship! You sail over the side, easily clearing the railing and the hull! But instead of dangling limply at the end of the rope, you hit a point level with the ship's deck, sink down about ten feet below it, and with a motion that makes your stomach lurch you suddenly reverse direction and go back upwards! You clear the deck again, going up until you're about eight feet over it, then sink back down again with another lurch to your digestion. Down, then up, then down, then up again, until your momentum is lost. You bob a little as you level off, floating even with the deck. Ever so slowly, you begin to drift outwards, away from the ship.
That's when the rope stops you.
Swinging down from the mast, Seek uses the rope to slide down to the main deck, and gently tugs you back towards the ship. Once you get close enough, he reaches down, grabs your hands, and hauls you back onto the ship. "My apologies (sincere) for the method of explanation," he says, untying the rope from your waist. "Over the years, we have tried many other methods of explaining how the gravity plane works (exasperation? annoyance?), but for some reason this is the only method that actually sticks in the minds of those new to spelljamming (delight? amusement?)! Apparently, it is something that must be experienced to be believed (extreme amusement). Now, had you slid out far enough to pierce the air envelope (serious), then we would have a problem."
