Drmooreflava
New Member
Walgis said:Drmooreflava said:Seems like it but, swarms are just bleeding combat res and points that could be better spent else where. Unless you build bastilidons around your swarms, I don't see it working.
Sounds like the bat swarms from VC, great in theory, difficult to execute properly in practice.
if you use swarms corectly they will be gold if you charge with them in middle front or middle of flank you will have a bad time. you need first to charge with saurus and then swarms that they would touch maximum 1 model.
There lies the difficulty of actually pulling off the tactic.. Assuming that your opponent will not deny you such an easy opportunity and that the terrain is in such a condition that you may actually execute the maneuver. Anyway, this seems off topic.
