AoS Regarding rule of 1 save dice roll in new GHB2020
Discussion in 'Rules Help' started by Dreamkeeper, Jul 13, 2020.
Tags:
  1. Dreamkeeper
    Dreamkeeper Well-Known Member
    Hi everyone!
    I just manage to get my hands on new GHB2020 and while reading the COALITION OF DEATH page I've found this strange "Special rule" in the corner of the page (p.98):
    "SPECIAL RULE
    The following rule applies to all
    matched play games
    You cannot make more than
    1 dice roll (excluding re-rolls)
    to negate a wound or mortal
    wound that has been allocated
    to a model. If you could use
    more than one ability to negate
    allocated wounds or mortal
    wounds, you must pick which
    ability you will use."
    Does that mean, that Kroak can't use his FNP 4+, after nearby Saurus Guard unit tries(and failed) to soak up wound from him?
  2. ILKAIN
    ILKAIN Well-Known Member
    no, that is not a "negate" roll but rather a "allocation" roll
    Selfless protectors:
    Roll a dice before you allocate a wound or mortal wound to a friendly slann while it is within 3" of any friendly unit with this ability. on a 2+ you must ALLOCATE that wound or mortal wound to a friendly unit with this ability that is within 3" of that SLANN instead of to that SLANN
    that is the rule that prevents multiple Ward saves from being used against the same wound.
    once the wound is ALLOCATED only one NEGATE ability may be used
    LizardWizard, Imrahil and Dreamkeeper like this.
  3. Dreamkeeper
    Oh, I see. Then, while we're on this topic I have another question. What about re-rolls? What if you can re-roll all save rolls on one unit while it has re-roll 1s on save? You must choose one of these 2 or you can re-roll all save, then after that re-roll all 1s in that 1st re-roll? I had a game where StD buffed his Chaos Warriors with re-roll save of 1, while they have their own re-roll all save.
  4. xoid
    xoid Well-Known Member
    There is a general rule that you can only reroll any die once, so that would cover the saves situation.
  5. Dreamkeeper
    Oh yeah, I remember that. Thanks.
    LizardWizard, Imrahil and xoid like this.
  6. 4idvet
    4idvet Member
    How would this affect bonereapers FNP?
  7. Canas
    they get 1 FNP roll, if they have multiple FNP they have to choose which 1 to use.
    Similar to how Kroak can't use both the FNP from an astrolith & his own FNP.
  8. Putzfrau
    Harvester's specifically doesnt count as an FNP tho, so you'll still get a harvester roll in addition to their death save.
    Canas likes this.
  9. ILKAIN
    uh.... what harvester FNP?
  10. Canas
    it's not a FNP it's a ressurect.
  11. ILKAIN
    right, which is why I am confused....
  12. Putzfrau
    Was just clarifying that that would stack because its not a fnp.
    ILKAIN likes this.
  13. ILKAIN
    ok no worries, just seemed out of context and threw me for a loop.
    Putzfrau likes this.
