AoS Rules moove restriction / charge
Discussion in 'Rules Help' started by General Grivious, Aug 8, 2020.
  1. General Grivious
    General Grivious Member
    Hi all, :)
    Rules questions in that case?
    1) If a unit is on a piece of terrain like in the pic, can another unit move down there, or it has to be 3" away that piece of terrain (horizontal/vertical) ?
    2) The maw Krusha in that case cannot charge the LoC? because the terrain is to litle
    3) if the Mawkrusha charge the flamers and ends charge moove 3" horizontal of LoC, then they are in combat but nobody can pile in and attack because 3" vertical?
    Thanks for making it clear o_O
  2. ILKAIN
    ILKAIN Well-Known Member
    I think you have run into an issue where you are using 40k terrain (which has very specific rules for vertical engagement zones) on an AOS game, in which this scenario is far less likely.
    essentially the answer cant be answered without knowing what terrain type you are using the ruins to "count as"
    Imrahil and LizardWizard like this.
  3. xoid
    xoid Well-Known Member
    I think it can charge, just say it is at an angle and set it aside. Don't forget AoS movement rules specifically call out the possibility you'll be stuck halfway up a wall if you run out of movement.
  4. Flo
    Flo Well-Known Member
    Exactly, you can end movement at any point on terrain when climbing, you do not need to be able place the model unless you agreed to something else can be found in the Designers commentary of the core rules
  5. Putzfrau
    I mean, mawkrusha's also have fly so it ignores all vertical distance when making any kind of move.
    Essentially it will have no problem charging the LoC.
