  2. This is just a notice to inform you that we will move the forum to a new server sometime during the next few weeks. The actual process should not last more than a few hours; during this process, we will disable replying and creating new posts. As soon as we know the date for the transfer, we will update with more information.
7th Ed. Skink Chiefs. How, what, when?
Discussion in 'Lizardmen Tactics' started by erians, Jan 29, 2010.
  1. Sebulba
    Sebulba New Member
    Haha, the skink chief in a group of 18 saurus with FC and some armor ends up being 343 points. 38 str 4 attacks later (yes, the skink chief is a strong as a kroxigor...) with hatred against skaven clanrats should statistically hit 26 times, wound about 16 times and kill off 13 to 14....
    Of course, this is based on you getting charged and not losing anyone. That alone, plus the 3 ranks, banner and bsb gives you 18 to 19 combat res...
    It would certainly be a fun unit to run sometime. It isn't that spendy either so you could conceiviably get a Saurus Char to run with some CoC with the BBoC set up.
    Some skirmishers and maybe a salamander or to plus another small saurus unit if you have the points. Could be a fun list to play.
    Frenzy helps out against other armies too, in case you're thinking about using this in a tournament or something.
  2. Xulotl
    Xulotl New Member
    What about Skink BSBs vs. Saurus BSBs? Skinks are quite obviously cheaper, but is there anything else? Especially in 1000pt games (mostly what I am playing now).
  3. erians
    erians Active Member
    Their base cost difference is 30 pts. For those 30 pts the Scar vet gains a massive stat increase (+2T, +1S, +1A, +1WS, +1LD), at the cost of Move, which won't matter as you are almost always on a cold one or flying or in a unit with m4 anyway, -5 BS which doesnt matter cause the saurus cant get any ranged weapons anyway, and -3 In which is a shame but the scar vet stat line is still light years ahead.
    Not only is the Scar vet a faaar superior fighter but also have much better defensive stats. Without magic items a skink can get a 5+ save at best while the scar vet has 1+ save if you mount him on a CO. Resilience is a very important part of a BSB and the chief BSB just doesnt have it unless you put him on a stegadon with some ward save item.
  4. Chaq Mundi
    Chaq Mundi New Member
    I've found that for character hunting, a good combination is this:
    -Terradon
    -LA
    -Shield
    -Bane Head
    -Piranha Blade
    If you wound him even once (provided that that's the character you chose for Bane Head), he'll take 4 (!) wounds!
    What do you think?
  5. Bibamus
    Bibamus New Member
    actually, the saurus can get the staff of the lost sun, but he needs 7's to hit without applying penalties!
    also, a skink character hunter can be nice on papper, but when you need to cause 4 wounds to kill a character its probably one that will not be easly wounded by 3 S4 attacks, if at all...
    he might be a good mage hunter with piranha blade but he's probably good at that without it. also the bane head is usally more usefull on the slann if he gets lore of metal
  6. Angelus
    Angelus New Member
    No he can't since he has a BS of 0 which means that he can't use a ranged weapon. Se page 5 of the (small) rulebook under "characteristics of 0"
    I have used a skink on a terradon with light armour, sword of might and shield as a warmachine hunter and he has done pretty well.
