AoS Starblood stalkers ambush
Discussion in 'Rules Help' started by MackiMac, Apr 26, 2022.
  1. MackiMac
    MackiMac Well-Known Member
    Do the starblood stalkers chameleon ambush count as 1 or 3 drops?
    Kilvakar and Bowser like this.
  2. Killer Angel
    Unless there's a faq somewhere i'm not aware of, I would say they are different units with a single drop, as the unit and the 2 characters that must be set up in the same moment (end of move phase) in the described way.
    Kilvakar, MackiMac and Bowser like this.
  3. MackiMac
    Sorry, my question was not clear. I meant when the players are deploying the armies.
    Do I deploy the starblood stalkers in hiding, then my opponent deploy one unit then I deploy Kixi-taka with the stalkers, then my opponent deploy again and then I deploy Klaq-trok? Or do I deploy all three at the same time?
    Thanks
  4. Killer Angel
    Ah, ok.
    Of course it could have been written in a better way but i believe it's the same: "place them on one side" , so you place them as reserve all at once (plus, you are forced to set them in reserve, as it seems you simply cannot place them on the battlefield, even if you wanted to)
  5. Kilvakar
    Kilvakar Well-Known Member
    I think it says you *can* set them up in reserve, not that you *have* to. So during setup you can choose to deploy the whole team on the board or in reserve.
  6. Killer Angel
    Yep, you're right.
    But still it's a single block.
