8th Ed. STEGADONS
Discussion in 'Lizardmen Tactics' started by fnorrll, Nov 2, 2010.
  1. rammramm
    rammramm New Member
    But in that case no amount of saurus will block TLoS from an enemy in front of them since they stand behind one another and there will allways be a thin line in between the files that will be posible to see through. Cant be the way the rule is intended though.
  2. ryan88
    ryan88 New Member
    So I was looking in the book about wether or not a skink chief can lend his sweet balistic skill to the crew, and I didn't see anything saying he can't, to m this makes sense since unless they're in combat the chief may as well make himself useful... but i want to know if i'm right, if so reg stegs just got wayyy cooler to me.
  3. HoverBoy
    HoverBoy New Member
    The answer is in the FAQ, and sadly it's a "no".
  4. walach
    walach New Member
    yeah, i mean it's hardly like it would make a chief on steg a good idea if you COULD use his BS! basically the only reason you would is to take a good magic weapon in there (typically warspear), even then it's very expensive.
  5. ryan88
    ryan88 New Member
    If you could use his BS, which reasonably you should, i would always take one, why not? you hit on like 2+ with a bolt thrower, and you get a decent support monster.
