AoS vanguard battalion ability
Skaven Slave
chefofwar
Clan Mors
Messages
173
Likes Received
362
Trophy Points
Is it correct that I could use the "free" all out attack as well as the regular command point cost to have 2 all out attacks in one phase?
Q: If an ability allows a unit to receive a command without the
command being issued and without a command point being spent,
does the restriction that you cannot use the same command ability
more than once in the same phase still apply?
A: Yes.
Thanks, that checks out then.
If that is the case, and that restriction beats all, seems like a wordy way to describe the battalion ability?
"once per game you may use the All out attack or all out defense command ability for free"
I have not come across situations of cause and effect of triggers when a command is "issued" or "received", I guess they may exist
well, there are some benefits (other than the free cp):
- if you're out of range from a hero, you can still issue the command
- if a monster's roar stops a unit to being issued a command, you can bypass the limitation
this bypasses roar? I did not know that
I'm re-readin it.
the unit "can receive the All-out Attack or All-out Defence command without the command being issued"
with roar, "that unit cannot issue or receive commands"
technically, the unit receives the command, but the command is not issued. But roar refers to what the unit can or cannot receive, so probably the command is stopped anyway.
Back
Top
