AoS Balewind vortex 2 rules
Discussion in 'Rules Help' started by theodoris, Jul 8, 2018.
  1. theodoris
    theodoris Member
    The Balewind Vortex has 2 rules.
    the one in the new rule book,
    and the one on the site, when you go to the GW site to buy the model and can download the rules for free.
    the one on the site says no models can`t move 3" near the balewind vortex,
    but the one in the rule book says you can charge and attack the balewind vortex
    which one do i use?
    I think we need to use to rulebook rules, but this could be confusing when you go to an tournament
  2. MinhoAbernathy
    MinhoAbernathy Member
    I use the ones from the Malign Sorcery warscroll card which are the ones where you CAN go within 3" of it and it gives your wizard an extra spell. I'm sad for the loss of the +1 to casting though.
  3. Aginor
    The PDF is still the old one I think. The most recent one doesn't block movement within 3" and it doesn't double the spell range anymore.
  4. Flo
    Flo Well-Known Member
    Exactly, new BWV is from Malign Sorcery Ruleset, the PDF warscroll is out of date and no longer used
    New rules are
    -8" more range for spells
    -1 additional spell per hero Phase (including the hero Phase where the Vortex is set up
    -+1 save for the Wizard on top
    theodoris and Aginor like this.
  5. Aginor
    +1 important thing: The BWV and the wizard become a single model
    Crowsfoot, Flo and theodoris like this.
  6. Crowsfoot
    So it can’t be dispelled by anyone apart from the caster?
  7. Flo
    It can be dispelled like any other endless spell
    You even need to be careful! If it gets dispelled you need to Place the caster i Think within 6" of the BWV and also more then 3" away from enemy Models, if this is impossible the caster is slain!
  8. Aginor
    Correct. It also means that the caster becomes "bigger" so it is easier for him to be in range of something. His footprint becomes huge.
  9. Vexcor
    Vexcor Well-Known Member
    let get this correct:
    a Slann can cast 3 spells a turn, casting the vortex does not count as a spell as written in his warscroll.
    SO if you get him up, you can cast and unbind 4 spells in turn 1, right?
    or get 13 summoning points
  10. Flo
    Casting the Vortex does count as a spell, it was the old warscroll where you didn't need a spell Slot for it
    You can cast the Vortex and 3 additional spells afterwards or generate 9 points
  11. Pallys
    Pallys New Member
    Can you move on the BwV?
    Edit: NVM I'm blind, no you can't move
  12. Aginor
    But you can teleport. :)
    Dr.Doom and Pallys like this.
  13. Pallys
    Pallys New Member
    Big brain moves!
    Dr.Doom likes this.
  14. Workschmock
    Workschmock Member
    Is there a faq or designer's commantary that supports this? Because the balewind's warscroll says "as long as the balewind vortex remains on the battlefield.." and our Lords of Space and Time rule removes a model from the battlefield to set it up sonewhere else.. I'd argue that at the moment you remove the vortex from the field, the wizard and the vortex cease to be one model, they split up. Although the wizard is not slain, what would dispell the vortex automatically.. err.. confusing..
    Dr.Doom likes this.
  15. Aginor
    AFAIK it has been done in official tournaments and was ruled OK, I don't recall if there was a FAQ about it.
    But that's a good point you have there! By the pure words we could either argue either way I guess.
    Dr.Doom and Workschmock like this.
  16. Workschmock
    Workschmock Member
    Dr.Doom and Killer Angel like this.
  17. Aginor
  18. Ustyk
    Ustyk Active Member
    Can wizard on bwv can be attacked by mele ?
  19. Killer Angel
    Yes.
    Gone are the days of the old warscroll
  20. HelloBear
    HelloBear Member
    Came for this, so if now the vortex and guy on top are counted as one model, someone in base contactcan "reach" the wizard as you aren't measuring to the base of the model on top? Just want to confirm, about to use it for the first time Wednesday.
