Funny thing, all the minies in the box are snap fit and won't need any glue. I wonder if this will be a thing that will happen too other, newer, figures as well.
I believe this is because of this box being friendly to the newcomers, as all starters are "glue free"
They're also a tad easier to glue as they're less fiddly. No stupid arms that refuse to keep pointing upwards and keep falling down. Having em stick together helps a lot with frustration for that.I still glue them usually, otherwise you get little gaps.
But it is kinda nice if a newcomer can put them together without putting glue everywhere.
It's a neat box, but I'm confused by 1 thing. The hell is up with the weird amount of models? 8 Sequitors, 3 Evocators, 4 grimghast reapers. None of those seem like appropriate unit sizes for the given models.
The unit sizes seem Somewhat odd, but that might just be how they are sized. One thing i find really weird is the additional boxes of sequitors and glaivewraiths. The sequitors has three models, and that won't add up for the soulwar box. The glaivewraiths has four models, and that won't add up either.
Maybe in the new edition you can pay for single models instead of paying for a new unit entirely. That would be neet.
It would be great if they brought that Fantasy mechanic in, but I don’t expect it will be likely![]()
Those other boxes where designed before matched-play was a thing though. Or at least the ones I know of.To be honest:
The truth may just be that the box content isn't playable in matched play.
Same with other boxes by GW that give you odd numbers of models. You are supposed to either play the game in open or narrative play, or buy more boxes.
I'm not sure if that'd be such a good idea. I could imagine certain "abusive" tactis could pop up then, like fielding 20 units of 1 clanrat so that your opponent wastes 99% of his attacks as the wounds can't spill over to the next unit. 40K doesn't seem to field the same degree of hordes and fodder like AoS seems to so I think it probably works better there.The unit sizes seem Somewhat odd, but that might just be how they are sized. One thing i find really weird is the additional boxes of sequitors and glaivewraiths. The sequitors has three models, and that won't add up for the soulwar box. The glaivewraiths has four models, and that won't add up either.
meh, I suppose it could work if you only do it for the more "elite" units, preferably ones that don't have special weapons. The minimum size wouldn't matter much and adding 1 additional liberator or saurus guard is actually usefull as opposed to adding 1 clanrat.Minimum size unit so you can't just have one on it's own.
where'd you find that out?The new nighthaunt Chainrasp horde has any number of models.
Which would imply points per model..
To be honest:
To be honest:
Exactly, so GW can get MORE MONEYYYYYY!!!!!!![]()
mhwa, could just be bad phrasing. The Tzaangor warscroll claims you field em per 5 and the GHB immeadiatly made that 10, so not like warscrolls are all that reliable even if they're new.
