AoS FAQ is out. Bastiladon is god
Discussion in 'Seraphon Discussion' started by crazyhorse1321, Mar 30, 2020.
  1. LizardWizard
    Very much yes to the Purple Sun. Not only does it outright slay, but a lot of Fyreslayer armies won't be able to unbind or dispel it once it is on the table.
    Agreed. DoT is the main draw to play Coalesced for me at the moment.
    LordBaconBane and Putzfrau like this.
  2. LizardWizard
    It is clearly stated that attacks can deal MWs in the Mortal Mound Subsection or the Core Rules. You are arguing over a semantic interpretation of the attack sequence rules. Not all attacks have to filter through part or any of the full sequence. Weapon profiles which have a rule amendment to change the normal attack sequence are still weapons. The rules for attacking with missile and melee weapons makes this clear:
    "When a unit shoots or fights, it makes attacks with the weapons it is armed with. A unit attacks with all the weapons it is armed with, including any used by its mount. The weapon options a model has are listed on its warscroll. Missile weapons can only be used in the shooting phase, and melee weapons can only be used in the combat phase."
    This lays out that attacks are found on a warscroll's weapon profile. Some weapons ignore the standard sequence of attacking, but are none the less attacks. Having a dashed phase which says see "x" doesn't change it from being a weapon which interacts with the the game via a declared attack. If you have to declare you are attacking and it is on the warscroll's weapon profile then it is obviously an attack.
    Grotpunter and Carnikang like this.
  3. PJetski
    PJetski Active Member
    All of those weapons say "Do not use the attack sequence". They are obviously not an attack.
    If you have an ability that activates on a hit6 then the ability deals the mortal wounds and not the attack.The attack did not cause the mortal wounds, the associated ability caused them.
    It's obviously not semantics because the developers just told you in their commentary that there is a distinction!
  4. Alladin the Paladin
    This could all be fixed by adding the wording “This rule does not apply to damage caused by Mortal Wounds.”
    Cuetzpal Pilli and LizardWizard like this.
  5. ILKAIN
    ILKAIN Well-Known Member
    run
  6. Canas
    The developers did not say there was a distinction, they simply stated that mortal wounds don't count period.
    And regardless of where the developers stand on the definition of an "attack" it remains a discussion in which one side is basing their arguments on semantics and the definition of an "attack" whereas the other side would like to see it being grounded in some sort of logic based on what the various abilities & weapons are supposed to represent....
    Don't get me wrong, going by semantics and the arbitrary defintion the game makes about what is and isn't an attack is fine and all, but confusing messes like this is part of the reason why WFB died off.
    Seriously, just for fun, show the rule for scaly skin to some random people and then show various abilities and attacks and ask if they can say if it's applicable or not. The majority will probably naturally assume it applies to the various abilities, spells, attacks exploding into mortal wounds etc. because the distinction between what is and isn't an "attack" is wholly arbitrary and purely a question of semantics within the game.
    The connecting scaly skin to "attacks" was a mistake, and I hope they realize this before they start to introduce more rules that rely as heavily on semantics for "correct" execution.
  7. LizardWizard
    Not using the attack sequence doesn't mean it isn't an attack. You still have to declare that you are attacking with those weapons. At which point the weapon profile allows it to skip the standard sequence.
    Putzfrau likes this.
  8. ILKAIN
    and I thought I was thick headed
    IggyStarhost and LizardWizard like this.
  9. Putzfrau
    Exactly. The core rulebook clearly outlines what functions as an attack.
    Ignoring the attack sequence or not doesn't ignore the definition of attack as laid out by the core rule book.
    Lizerd, Canas and LizardWizard like this.
  10. ILKAIN
    so for those wondering, I was only half joking. our mobility out shines the FS by FAR. use it. mobility and shooting and sheer volume of ranged attacks will drop them.
    Lizerd, IggyStarhost and LizardWizard like this.
  11. Alladin the Paladin
    I hate to point out the obvious, but does any of this even really matter? We are talking about hypotheticals and the now distant past. The reality is how the FAQ states it.
    Even if the core rules said “MWs from attacks are attacks. Therefore, if we one day release a battletome that reduces damage from attacks, these MWs will also be reduced. We promise!!!”
    Then, a tome is released and the prophecy is fulfilled.
    Then, they FAQ it to negate their promise. FAQ wins. Scaly Skin loses. Sorry guys. I’m bummed too.
  12. LizardWizard
    Exactly this. The attack sequence is not what defines something as an attack. It is only how we resolve a declared attack. MWs can augment the sequence in part of in whole. However, the definition of an attack is not tied to the sequence for resolving said attack.
    Lizerd likes this.
  13. PJetski
    If they were attacks that caused damage then Scaly Skin would reduce them. According to the people who write the rules it doesn't reduce them, so they're not attacks.
    It was a clarification, not an errata; nothing has been changed, you were just playing the game wrong.
    We can spend all day arguing about this, but until the developers say otherwise there's nothing else to say on the matter.
  14. LizardWizard
    That is an assumption of intent, not an actuality of how the rules are written. Agreed, that is does not matter in terms of how scaly skin currently interacts or how it was intended to interact. However, attacks can deal MWs as stated by the GW published rules.
    Asamu, Putzfrau and Canas like this.
  15. ILKAIN
    its a good conversation to have for future rules distinctions. plus Pjetski is just horribly wrong and im enjoying people correcting him and seeing him stand his ground.
    I can respect a fellow stubborn ass lol
    Canas, Lizerd and LizardWizard like this.
  16. Alladin the Paladin
    Haha... I am normally one to gravitate toward endlessly cyclical philosophical arguments, but the last few days have seen me adopt a more pragmatic and straightforward approach. Maybe it’s due to the weather we’ve been having....... hmm.
  17. PJetski
    My argument is entirely based on the FAQ released today.
    Feel free to contribute something to the discussion, though
  18. Asamu
    Asamu Well-Known Member
    People are making a big deal over mortal wounds not counting for scaly skin...
    It's really not a big deal, and coalesced Seraphon is still looking to be a top tier army. Saurus still compare favorably with basically any comparable units in the game. Salamanders are still fantastic, and most abilities/spells that caused multiple mortal wounds didn't come from attacks, or caused many instances of single mortal wounds (like warpfire throwers) anyway.
    This really only matters against other Seraphon running multiple units salamanders, FS running pikes on hearthguard, when most run axes anyway, Terrorgheists ( guess. 6-5 mortal wounds wasn't a huge deal anyway), Jezzails, and SCE paladins (specifically retributors); also a few hero models, but attacks that cause multiple mortal wounds really aren't that common, and are almost always only triggered on a hit or wound roll of 6; so the majority of damage from such units will still be affected by Scaly skin.
  19. LizardWizard
    Top 3 Fyreslayer players in the world all run Polearms. But yes, it is over all minor.
    ILKAIN, Carnikang and Lizerd like this.
  20. ProllyaCrow
    ProllyaCrow New Member
    Didn’t the designers commentary say that exactly?
    ILKAIN and LizardWizard like this.
